Question about Craftsman 42 in. Precision Cut Plus 24hp Lawn Tractor
MOWER WILL NOT GO VERY GOOD WHEN IT GETS WARM AUTOMATIC
I HAVE A CRAFTSMAN 42 IN. 24HP WITH A AUTOMATIC TRANS. AFTER IT GETS WARM,THE MOWER WILL NOT GO VERY FAST. IT USUALLY GOES FASTER TYE FATHER YOU PUSH THE HANDLE FOWARD. BUT NOT AFTER GETS WARM ??? IS THERE ANY ADJ ?. OR DOES IT NEED TRANS FLUID ? OR THE TRANS BELT TOAST ???? PLEASE HELP THANKS DB
  • 32 Answers
It probably is not getting cooled enough.
Posted on Jun 21, 2009
Why is mower making sound like blade hitting deck?
when does it do it ??? Only when you are driving the mower ??? if its a rear drive mower I would suspect the axle/trans/drive wheels are making the noise.
Sep 11, 2014 | Craftsman 675 Torque 190cc 21" Briggs ...
Craftsman 56" lawn tractor auto trans dose not drive forward or revers. tryed purging trans no go checked engagment rod ok, belt seems good. I can push the mower by hand as if the trans were not connected...
somehow did the little freewheel lever get pulled in the rear of the tractor to disengage transmission?..usually out is disengage and in is engaged. look around the back panel behind the rear axle for a small lever you can pull or push in.
Aug 18, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Have a craftsman dyt4000 riding mower and it will not free wheel, backed off the brake but still will not move. Any suggestions on what else I can do.
if it has the automatic trans you need to pull the rod on the rear of the machine that if for free wheeling the machine
Jun 23, 2012 | Garden
Mower starts and runs, blades turn but will not move, what could be the problem?
the blades and the trans use 2 different belts also is it a automatic drive and the release lever that you pull out to push it?
Apr 05, 2012 | Craftsman Garden
Craftsman riding mower model 917-273223 automatic trans, when I put it in gear fwd or rev it does nothing
first check and see if transport lever is not pulled up knob by seat this disconnects gear so it can be pushed around also check cable sometimes breaks --check drive belt and last trans pulley has a tendency to loosen and pop --easiest way to look at all above is to remove the back plate only 4 bolts
Aug 21, 2017 | Garden
1991 f350 , 460 ci , automatic wont go into overdrive when the tranny gets warm
ok chech the water hosed in the radiator (both) because if the trans oil is over heat the trans got problems. The trans oil runs trough the radiator.
Oct 21, 2010 | 1991 Ford F350
Craftsman 21hp, 48" lawn tractor, electric start, automatic trans
The alternator is built into the starter. Check with a volt meter to see if you have at least +13v while mower engine is running. Could be a bad battery.
Jun 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My deck is way too low. How do I adjust it?
Your mower should have a lever on it that you move to raise or lower your deck. The lever will normally have the slots that it locks into numbered like the trans gears if yours is not automatic.
Nov 06, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman mower shuts off when gets hot
Could has than one reason caused this problem.
Have you ever remove the plug to verify the bobin still delivery a good spark right after the unit shut-off? The aging bobin could loose a high voltage section [short out] when the temperture rose.
Jun 18, 2009 | Craftsman Garden
Craftsman 42 in. Precision Cut Plus 24hp Lawn Tractor Logo
204 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
