SOURCE: Marantz SR5200 - front speakers not working unless direct
If you try and unplug it at least 12 to 24 hours and it does the same thing, then its time to take it in to the shop.
SOURCE: Marantz SR5200 receiver works only with remote not manually
Check for a stuck/jammed switch, press each switch if one doesn't make a normal click sound or it doesn't move at all that's your problem.
If that's not it check the owners manual for how to reset the receiver (not all manuals will tell you how to reset it) Another way to reset it is to short the memory cap, but that is better left to a tech.
SOURCE: No sound out of speakers (Marantz SR5200 receiver)
sounds like you might need to open it up and check the speaker wires that you plug your speakers up to it might be lose or something else like that cause it happened to me before and that was it.
SOURCE: my marantz sr5200 powered off and won't turn back
try to reset the memory circuits, the info on them may be corrupted, try this:
1 disconnect the plug from the AC line supply
2 wait 10 minutes then, reconnect the plug to the AC
outlet
3 try to operate the equipment.
now.. if above does not work you may have to contact the manufacturer as
the issue could be related with the internal circuitry.
good luck!
SOURCE: my marantz sr5200 dont reproduce dobly digital
I have the Marantz SR5200, unable to get the Set-up / t.tone button to work, don't have the instructions,
