Question about American Standard Home
American Standard toilet constantly runs
My American standard toilet was working fine for about 6 months and then all of a sudden is constanly runs at the bottom of the fill valve and runs every minute. We replaced the fill valve but it still runs. Any thoughts or suggestions?
    President:
  • 3,433 Answers
The rubber cork thst lifts when you press the handle is leaking by and causes the water level to drop below shut off level so it trys to maintain the the shut off level every minute or so. Replace the cork with one made with the red rubber. good luck
Posted on Jun 20, 2009
American Standard Carlyle Series toilet is refilling about 10 percent of the water in the tank every 20 minutes. Do I need to replace the flapper or the entire flush valve?
Start with the flapper. They tend to dry up especially with water that contains chlorine. Purchase the American Standard flapper if available for that toilet. Works better than generics.
Sep 20, 2013 | American Standard 2004.014 - Champion...
Why does my toilet suddenly fill the tank?
Usually seeping is from under the flapper. Replace flapper with one designed for that model. Avoid generic flappers.
Nov 17, 2012 | American Standard Home
My toilet doesn't flush every time I flush it! It only flush If I pour a little more water into toilet bowl while water coming down toilet bowl! I've checked water level in tank and it was full...
I think the problem with your toilet bowl is in the tank fitting of it..you better check if the fittings are proprerly working..You also check the flapper and also the fillvalve.
If it is not good already you can replace it by buying the tank fittings at the hardware store..And you better also be check it to your plumber for the second thought..
Jun 17, 2011 | American Standard Home
I have a american standard toilet mode 4112 that keeps running.....any suggestions on how to fix it?
The flapper ball may be contaminated and not sealing or the float level has changed and needs adjustment. You should be able to see if the overflow has water flowing into it continuously.
Mar 07, 2011 | American Standard 4112 Bone Toilet Tank...
I bought a toilet from homedepot in toronto 6 months ago. from yesterday, it keeps to refill the tank like every 10 seconds. but i can not see where the water leaks
There are a few likely causes for a toilet to leak and refill. The most common is the flapper not seating properly. Usualy on an American Standard it is a disc. Either way, they are fairly easy to replace. One test I use to see if the leak is comming from the flush assembly is to put a couple drops of food coloring in the tank and wait a few minutes to see if it appears in the bowl. If so, there is a leak in the flush assembly, usualy the flapper. Hope this heps. Please vote to let me know.
May 12, 2010 | American Standard 2860.334 Enfield Two...
Not flushing
take the lid off the tank and make sure that the chain is still conected from the flusher handle at the top of the tank to the plug at the bottom of the tank
Dec 09, 2009 | American Standard 2002.014 - Champion4...
I have the American Standard Champion 4 toilet. Water is leaking from the tank to the bowl causing the toilet to refill. I've replaced the flapper and cleaned the surface the flapper contact. Nothing seems to work.
Nov 09, 2008 | American Standard 2002.014 - Champion4...
Home Logo
374 people viewed this question
Top American Standard Home Experts
Mike
john h
allphase tech
Level 1 Expert
Are you an American Standard Home Expert? Answer questions, earn points and help others
