Question about Estate TEDX640JQ Electric Dryer
Last load dryed fine now it won't even heat up. Can it be a fuse? If so what amp and where?
  • chris weier May 11, 2010
    will the motor turn on? is there 220v to the dryer?
  • 653 Answers
I have never seen a fuse on a dryer, but if there was one, it would be a 230 volt, 30 amp fuse. I think your problem is actually the heating coil. Check with a meter for continuity, and replace if needed. If that is not the problem, check the temperature sensor in the duct and replace if that is shot.
Posted on Jun 16, 2009
Gas dryer won't heat
check to see if it heats up for the first 2 minutes if it does then i would replace the coils on the valve if not check the thermal fuse on the blower housing
Feb 24, 2013 | Maytag Neptune MCG8000AW Gas Dryer
We have an lg dle3777w dryer and it doesnt seem to get very hot to dry the clothing...it takes many cycles to get one load dry...any ideas???
Hello & Welcome to FixYa
As everything in your dryer is working fine apart from it heating properly so the recommended repair will be thermal fuse/thermostat replacement. However, you can also test its continuity before replacement. Please get back to me if you have any other questions.
Kevin
Dec 02, 2010 | LG DLE3777 Electric Dryer
I have a kitchenaid dryer that worked fine all day and then my last load to be dryed no heat not at all
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 23, 2010 | KitchenAid KGYS750LQ Gas Dryer
Dried a load fine, next load tumbles wont dry. still cant get heat
Make sure front of dryer is not blocked, air flow is needed to dry.Check that the lint filter and exhaust duct is clean.
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, If one is blown, the dryer may still operate but not heat. Alternatively, the dryer may heat, but it may not heat up as hot as it should. Replace the Fuses or reset the circuit breaker.
Another common cause of a dryer failing to heat is a faulty Heating Element. You will need to replace it.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jul 02, 2010 | Kenmore 63942 Dryer
My Fisher & Payel smart load dryer is not
Hi
Thanks for using FixYa. No Heat issue in an electric dryer is usually caused due to three things mainly: Thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the Thermal Fuse which ismounted inside the back cover panel to the exhaust duct and is mounted in white plastic housing. If thats fine then the Heating Element should be checked. Please do revert for further assistance.
Thanks
Rylee
Mar 18, 2010 | Fisher and Paykel Dryers
Ge dryer only dries small load
either your heating element or your limit switches are going out
Feb 04, 2009 | GE DHSR333EV Dryer
I have an older 70 series dryer. I was working fine and then my last load of clothes didn't dry. The dryer did not get hot.
Based on your complaint; "I have an older 70 series dryer. I was working fine and then my last load of clothes didn't dry. The dryer did not get hot,"
Temperature Switch:
Make sure a positive heat selection has been made. Then check these:
This information is for an electric, generic model dryer only!
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 15, 2008 | Dryers
Estate TEDX640JQ Electric Dryer Logo
122 people viewed this question
Top Estate Dryers Experts
Tim Whalen
Mike
John Tripp
John Tripp
Are you an Estate Dryer Expert? Answer questions, earn points and help others
