Question about Microsoft Office Standard for PC
HOW I CAN DELETE MY.FREEZE.COM FROM MY COMPUTER????
    Scholar:
  • 92 Answers
Download CCleaner and run it.
CCleaner has four main sections which can be selected using the 4 icons in the left-hand navigation panel.
(The Cleaner section is selected by default.)
Cleaner
This is the main feature of the program, which will allow you to optimize your system, by removing unused and temporary files. It also protects your personal privacy by removing traces of the websites you have visited and the files you have opened.
(It's important to point out that it does this without removing any files you'll still need!)
Click on the "Run Cleaner" button.
Download Malwarebytes
Use the link to download Malwarebytes Anti-Malware. After a few seconds a box or a light yellow bar should pop up asking you what you want to do with the file, click "Run" and then "Run" again. After you go through the install proccess the program should open up.
Look at the top row of tabs and click on the "Update" tab. Click on "Check for Updates". After it updates click on the "Scanner" tab and click "Scan". When the scan is complete click on "Show Results". I like to save the log file to my desktop so click on "Save Logfile" and save it where ever you want. Now click "Remove Selected". You should be clean, if your still having problems open up the log file you saved and start googling how to remove the different programs if found.
Posted on Jun 16, 2009
How to uninstall deep freeze 6 and where to find the files to delete
hi
Here the small tricks to disable or unintal Deep Freeze ver 6 without password:
  1. Boot your computer from Windows XP Installer
  2. After appear “Enter to Setup” option, Press Enter then press F8.
  3. Selected R to repair Windows system ( Repair Setup)
  4. Continue repairing/installing windows untill finish.
  5. Prepare the Deepfreeze v.6 installed, open the file like you want to install the software.
  6. it’s will show “Uninstall Deep-freeze” options. Uninstall the software, after uninstall finished reboot your computer.
  7. Now the Deep-freeze has removed from your computer.
Note: I tested this method on Windows XP only, on another windows version maybe this method does not work.
Jun 27, 2010 | Dell Computers & Internet
My computer seems to freeze. it has frozen severa...
You computer seems to be performnig slow, you can download CCleaner, and clean the garbage files.
You can go to Start-Run-%temp% and delete all the files.
You can go to Start-Run-Temp and delete all the files
You can run disk cleanup and select all the options which is available in the list.
You can go to your Internet Explorer-Tools-Options-Advance-Reset
You can also uninstall any unused program and delete the files you dont need.
These will get your computer back in track.
Regards,
Shrey
May 14, 2010 | Computers & Internet
How to disable deep freeze without a password
How to Uninstall Deep Freeze for Windows 2000/XP/Vista without the password.
Note: Without a complete uninstallation you may not be able to reinstall Deep Freeze on your system.
What we are going to do is edit the registry and delete the startup references to Deep Freeze. This will prevent the Deep Freeze driver from starting up the next time you boot. (c:\windows\system32\drivers\deepfrz.sys)
1. First we need a way to edit the registry. The way to do this depends on your situation. If your computer is thawed you can simply use Regedit. If your computer is frozen or if it doesn't boot you'll need to find another way. Here are some alternatives:
If you have a multiboot computer with another copy of Windows 2K/XP you can boot from there. Or, you can physically mount the disk on another computer that uses Windows 2K/XP.
You will probably use a tool that lets you boot and edit the registry. A good example of this is PE Builder that lets you build a Windows PE CD and boot Windows from there. Or use Bart's, http://www.nu2.nu/pebuilder/ or Winternals ERD Commander. There are several, including some USB memory sticks capable of booting like a CD. The goal here is to boot separately from your hard drive and access it while it is "asleep".
2. If your computer is thawed run Regedit. If it's not thawed follow one of the alternatives described above, and run Regedit (or Regedt32 on Windows 2K).
3. On the Find dialog box type UpperFilters and check only the Values checkbox. Then click Find Next.
4. The program will find a value with the name UpperFilters. Open this value and if there's a line with the name of the Deep Freeze driver (DeepFrz or DepFrzLo) delete it including the return, leaving the rest of the lines intact. Also, if you are using ThawSpace and you want to get rid of it delete that line too (ThwSpace), if you want to keep the ThawSpace leave it there. Press F3 to find the next match and repeat the operation until you have fixed all the UpperFilters values inside the HKLM\MySystem key.
5. Navigate to HKLM\MySystem\Select and check the value with the name Default. It has the number of the control set key that the system will use when booted. If it is 1 the control set is ControlSet001, if it is 2 the control set is ControlSet002, and so on. We'll assume the control set is ControlSet001 but you should use the one specified by the value Default.
6. Now go to HKLM\MySystem\ControlSet001\Services and delete the keys with the name of the Deep Freeze drivers (DeepFrz or DepFrzLo and DepFrzHi). Also, if you decided to get rid of the ThawSpace delete the key with the name of the ThawSpace driver (ThwSpace).
7. That's it. Now reboot and Deep Freeze will not load.
QUESTION: What if the BIOS settings prevent me from booting from CD or USB? Answer: Deep Freeze prevents you from decrypting the BIOS password, but it does not prevent removing it, if you have the right tool! Most of the BIOS hacking programs will not work to remove the BIOS password on a Deep Freeze protected computer, but CmosPwd by Christophe Grenier does.
You'll need to know how to use a command line and install the driver. Yes, it uses a driver to remove the BIOS password. But it works, even on Deep Freeze protected computers. Use CmosPwd to remove the BIOS password and reset the default BIOS settings. Then you'll be able to boot from CD or USB and edit your computer's registry and remove the DeepFrz, DepFrzLo, and DepFrzHi references which start Deep Freeze.
Now here is a little known secret: Faronics (the makers of Deep Freeze) uses a special driver to remove broken or malicious Deep Freeze installations. They do not have any backdoor passwords, so they use a special driver to remove a Deep Freeze installation where the password is not known or that someone is having trouble with. Will they send it to you, or even admit to you that they have it? I don't know. But, even if you do have it, you will still have to boot separately from the hard drive and replace the existing Deep Freeze driver with the special one and reboot. And after that, you need to use a Deep Freeze installation file to fully uninstall Deep Freeze (it will be thawed when you boot up with the special driver). If you want to re-install Deep Freeze, you'll have to first delete the special driver too.
Only a few people have this driver. It is the only solution Faronics has for those who need to remove Deep Freeze without the password. And, like I said, you will have to be able to boot from CD or USB and access the NTFS hard drive. If the boot-up order is locked (hard drive first and only) in BIOS settings, use CmosPwd to reset BIOS and boot order. Then you can boot from CD or USB.
Booting from CD or USB and removing the registry references works also, but then you should uninstall Deep Freeze with an installation file once you are able to boot thawed.
If you are dealing with a trial version of Deep Freeze, just forward the BIOS date past 60 days and then restart.
If anyone is wondering if Deep Freeze has ever been hacked, the answer is "yes" it has, several times over the years. Most of the time these were weaknesses that Faronics was able to quickly fix or prevent. However, there was one hacker that really, REALLY gave them headaches. His name was Emiiano Scavuzzo from Argentina. He was really good at low level programming and used OllyDbg to come up with about five versions of his "Deep Unfreezer" which gave Faronics their greatest challenge to date. Deep Unfreezer now only works on older versions of Deep Freeze.
Faronics is doing very, very well right now (as of 2008). They sold Apple Computer their Mac version of Deep Freeze, which, if you know how to look for it in the Applications folder on a Mac, is used in all the Apple Stores on both their desktops and their laptops. So, if you're ever in a Mac store playing around with PhotoBooth or whatever, and the computer settings are all messed up, just restart the Mac and thank Deep Freeze.
Apr 11, 2010 | Computers & Internet
How do i remove myfreeze as the first thing i see. i don't ever want to deal with them again!!!
How to delete My.Freeze.com files in Windows XP and Vista:
  1. Click your Windows Start menu, and then click “Search.”
  2. A speech bubble will pop up asking you, “What do you want to search for?” Click “All files and folders.”
  3. Type a My.Freeze.com file in the search box, and select “Local Hard Drives.”
  4. Click “Search.” Once the file is found, delete it.
How to stop My.Freeze.com processes:
  1. Click the Start menu, select Run.
  2. Type taskmgr.exe into the the Run command box, and click “OK.” You can also launch the Task Manager by pressing keys CTRL + Shift + ESC.
  3. Click Processes tab, and find My.Freeze.com processes.
  4. Once you’ve found the My.Freeze.com processes, right-click them and select “End Process” to kill My.Freeze.com.
How to remove My.Freeze.com registry keys:
warning.gif Because your registry is such a key piece of your Windows system, you should always backup your registry before you edit it. Editing your registry can be intimidating if you’re not a computer expert, and when you change or a delete a critical registry key or value, there’s a chance you may need to reinstall your entire system. Make sure your backup your registry before editing it.
  1. Select your Windows menu “Start,” and click “Run.” An “Open” field will appear. Type “regedit” and click “OK” to open up your Registry Editor.
  2. Registry Editor will open as a window with two panes. The left side Registry Editor’s window lets you select various registry keys, and the right side displays the registry values of the registry key you select.
  3. To find a registry key, such as any My.Freeze.com registry keys, select “Edit,” then select “Find,” and in the search bar type any of My.Freeze.com’s registry keys.
  4. As soon as My.Freeze.com registry key appears, you can delete the My.Freeze.com registry key by right-clicking it and selecting “Modify,” then clicking “Delete.”
How to delete My.Freeze.com DLL files:
  1. First locate My.Freeze.com DLL files you want to delete. Open your Windows Start menu, then click “Run.” Type “cmd” in Run, and click “OK.”
  2. To change your current directory, type “cd” in the command box, press your “Space” key, and enter the full directory where the My.Freeze.com DLL file is located. If you’re not sure if the My.Freeze.com DLL file is located in a particular directory, enter “dir” in the command box to display a directory’s contents. To go one directory back, enter “cd ..” in the command box and press “Enter.”
  3. When you’ve located the My.Freeze.com DLL file you want to remove, type “regsvr32 /u SampleDLLName.dll” (e.g., “regsvr32 /u jl27script.dll”) and press your “Enter” key.
That’s it. If you want to restore any My.Freeze.com DLL file you removed, type “regsvr32 DLLJustDeleted.dll” (e.g., “regsvr32 jl27script.dll”) into your command box, and press your “Enter” key.
Did My.Freeze.com change your homepage?
  1. Click Windows Start menu > Control Panel > Internet Options.
  2. Under Home Page, select the General > Use Default.
  3. Type in the URL you want as your home page (e.g., “http://www.homepage.com”).
  4. Select Apply > OK.
  5. You’ll want to open a fresh web page and make sure that your new default home page pops up.
Nov 26, 2009 | Microsoft Office Standard for PC
A program called my.freeze.com that i cant delete
http://killbox.net/
load this software , Gently, Please!! Type complete path into the box and press Kill ! Make double sure you have typed the correct path .if it doesn't get it first time , then click remove on Reboot. click OK!
Have A Great Day
Nov 20, 2009 | Computers & Internet
HOW DO I GET RID OF MYFREEZE.COM
Uninstall from Add/Remove Programs. Delete the folder from C:\Program Files. Go into the registry (Start>>Run>>Regedit), and delete the following keys:
HKEY_LOCAL_MACHINE\Software\FREEZE.COM
and
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Uninstall - Look for the folder that says FREEZE.COM and delete it.
Nov 11, 2009 | Microsoft Office Standard for PC
Help
http://www.fixya.com/support/t231952-computer_program_freeze_com
i downloaded a clip art program, yahoo is taking over my computer with a program called my.freeze.com, how can i remove this program. i tried to delete all free programs associated with the clip art download, but the yahoo my. freeze.com program is still there.
As posted on fixya, (see above) add and remove program will not fix it either.
I recommend to do a back-up. Save all your documents, pictures,and music.
Lastely, do a Reformat.
Good Luck.
Aug 28, 2009 | Microsoft Office Standard for PC
My.Freeze.com is causing me many problems
I recommend to do a back-up. Save all your documents, pictures,and music. You will have to re-install all 3rd party progrmas.
Good Luck
Jun 28, 2009 | Microsoft Office Standard for PC
My.freeze.com
freeze is full of adware and other bugs and trackers too. Many FREE products on the internet are. My search, free emoticons (u no the 1) and many gadgets are this way.
Aside from backing up your personal files and doing a recovery, it is very hard to remove them completely for your computer.
(XP)Disconnect from the internet(unplug line)then you can use add/remove in control panel. Then go into file system...open a folder and then hit show folders in the command bar above the main viewing area. The files will show to the left. Click plus sign next to My Computer,then next to local disk. Then programs. Look for and delete the folders that are obviously from freeze. If it won't let you then open those folders and delete the items inside, one at a time.
Now, go run a search for freeze and tell it to look in hidden and system folders. Delete the stuff you find, being carefull not to delete some part of another program.
Now, go back to filing system, to below program folder and click plus sign next to Windows. Scroll down to Prefetch folder and open it. Click edit, select all and delete those files. Restart
Jun 27, 2009 | Microsoft Office Standard for PC
Computer program my.freeze.com
Freeze.com is a known producer of Spyware that downloads and installs along with all of their FREE programs and screensavers etc.
You need to install update and do all the tweaks on a recognised anti-spyware program.
 If you have an anti-spyware program installed make sure it is NOT listed on 'The Spyware Warrior List of ‘Rogue/Suspect Anti-Spyware Products & Web Sites’
http://www.spywarewarrior.com/rogue_anti-spyware.htm
Those are "anti-spyware programs" that install their OWN spyware, while 'supposedly' removing everything else.
Use instead "Ad-Aware 2007", "Spybot - Search & Destroy", "SpywareBlaster" are three good ones. Beware of imitations and name similarities. Install and update then run them weekly after doing the latest updates.
Lastly, to stay OFF of Weird and Strange websites!  ;>)
Install McAfee SiteAdvisor.
Oct 24, 2007 | Microsoft Office Standard for PC
Microsoft Office Standard for PC Logo
353 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
