Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
FRSS36AF25/3 with exactly the same problem
I've removed the in-door ice-bucket, and tried again. No motor spinning. Switched between cubed and crushed nothing. I can hear a slight clicking noise when I push the dispenser (to get ice), and the light goes on, but no ice...
  • 331 Answers
Ok it sounds like the motor or it may have spun the gear... if you go here www.techray1.com and click on the guru guy. it will take you directly to repair clinic where you can ID the part needed.
Since you have the ability to tear it apart. replacing the part will be easy..... let me know if this helps
Posted on Jun 16, 2009
Ice crusher stuck on crush
your ice solenoid is frozen. It is located behind the ice bucket next to the auger motor. It will need to be removed, unfrozen, and squirt a little wd40 to prevent it from happening again
Mar 19, 2014 | Frigidaire FRS26H5AS Side by Side...
Dispenses crushed ice only, not cubed
remove the dispenser bucket where the ice drops into inside the freezer and get a Tupper ware bowl,remove the bucket and dump this ice into the bowl,then rinse with the dispenser bucket with warm tap water to melt any ice on each end of this ice maker,then wipe dry and replace into freezer where you removed it to get cold again and leave empty till the next harvest of ice,this can be normal on some units after so many weeks,as it will not let the blades retract so as just to dispense only cubes,once bucket is cleaned of ice jams the solenoid and blades will again retract for cubes only
Feb 10, 2013 | Refrigerators
When I choose either cubes or crushed on my icemaker, my unit only crushes the ice. I already had the water inlet control valve replaced and there are plenty of cubes in the bin. It is a dispensing issue...
this manufacture makes 2 seperate style ice buckets one in the door and one in freezer with a large ice bucket and auger screw that turns... first we will explain the one up on a shelf in freezer side up top... if you pull your ice bucket completely out of freezer... there should be a small bar coming out of rear toward bottom of ice bucket assembly now put it back in where you got it but this time watch where the rod goes... there is a solenoid in the rear of freezer actually called cube/crush solenoid and what this does is if switched to crush will raise that rod and activate the teeth in bucket to crush ice... if not will let ice fall out in whole piece...this solenoid sometimes gets hung or will freeze ...make sure with your finger you can move it freely and then watch it with some assistant pushing the switch for you does it go up when the handle is hit... the ice bucket in door works the same way except the componets are in the door and a little harder to access... repost with any questions if this doen not help you out...good luck to you
Jan 19, 2011 | Whirlpool Refrigerators
Fridge Freezer model KA58NP90 Ice maker problem
What is most likely your problem is the crushed ice solenoid. This solenoid, which is located next to the auger motor behind the ice bucket, is failing to actuate when you request cubed ice. Its "home" setting is crushed, and actuates to allow cubes past the crushing mechanism in the bucket. To be certain its the problem, remove the ice bucket, and tape the door light switch in the closed position. actuate the ice dispenser lever, for both cubed and crushed ice. you will see a square hole next to the rotating fork, when you select cubes, it should open. If it does open, there is something wrong with your ice bucket, perhaps the arm is broken, or the door inside bucket is off its snap in type hinge or broken altogether. If it doesnt open, replace the solenoid
Expert Refrigerator Repair Service in Chicago and Suburbs
Mar 20, 2010 | Freezers
WILL NOT MAKE SWITCH FROM CUBE ICE TO CRUSHED I CE
remove bucket,empty into large bowel. inspect bucket opening,and be sure ther are no chunks of ice hindering movement of blade bypass mech. w/bucket out operate ice disp on crushed and cubed selections,listen for sharp snapping sound before motor turns.if sound is heard,reinstall bucket,and you should be good to go
Mar 10, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE Side by Side only dispenses crushed ice
remove the ice cube tray assy, remove all the ice, save the cubes, wash the assy with warm water dry the assy, be sure the lever in the rear of this ice cube assy is moving and spring loaded, move the lever and it should snap back and return if so you know the unit is ok(the cube assy), now with the assy still out of the freezer close the freezer door and select crushed ice and push the pad where the glass normally hit to activate the ice cubes,if the operates and you here a thump and snap and hum most likely your ok,if not you could have a defective auger motor assy,but if you here all the sounds as decribed oped the freezer door and select cubed ice push actuator on despensor door with the freezer door closed, reopen and install the ice cube assy tray bucket assy,push it in firmley, and try it with some ice in the bucket you should be fine,if not replace auger motor assy..
nbcrca:)
Apr 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice Maker Issues-only crushed ice works, cubed comes out crushed
There is a solinoid in the freezer section by the motor that turns the ice auger. Test it by selecting cubes and with the ice bucket out, open the door, hold the door switch so the lights turn out and push the dispenser button. It should make a loud snap and travel upward. If not then I would say you have a bad solinoid. If it does, then I would look at the bucket. the metal rod that runs along the side of the bucket opens a flap in the bucket that is supposed to let the full cubes drop. look for anything that might cause it to be hanging up.
Jan 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire In Door Ice Dispenser
Most likely nothing broken. Just pull out the ice bucket. You will see a metal rod along the bottom area that protrudes into a hole in the back of the freezer. That gizmo has to move up and down freely to set the crusher / cube arm in the correct position. You should be able to move it up and down with your finger. If not, it may be frozen, or have a back solenoid.
Sep 01, 2008 | Refrigerators
Ice despenser
will it still dispense the whole cube?theres a brass rod under yourice bucket, remove bucket and check that rod, should be spring loaded and have a little bit of action(youll see it move a flap in front of bucket as its twisted, if so make sure the bucket is being reinstlled correctly, try the dispensor w/o the bucket installed at all, open the door trip the switch with one hand and depress the plunger for both crushed and cubed and check for the motor to turn
Feb 22, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Ice maker
there is a door in the bin that switches the cubes empty the bucket and make sure its not jammed also take the bucket out push cubes hold down the door switch not the one that turns the light off unless you unit only has one and push the switch with the door open in the back a leaver in a hole should jump up it not switch it to crushed and try it again if it still don't then the solenoid is bad or frozen
Feb 18, 2008 | GE PSS26SHRSS Side by Side Refrigerator
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
196 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
