Question about Dell Dimension 2400 PC Desktop
How do I configure the Dell Dimension 2400 to start from the cd/dvd drive?
  • 81 Answers
Hi, When you first switch on your pc, press F2 on the spalsh screen, this will last only a few seconds so be quick. Once your in the bios, looks for Boot Sequence, once you have found this change it so that CD/DVD is set to 1.
Posted on Jun 16, 2009
My dell dimension 2400 isnt acknowledging cds in the e drive yet it says that the drive is ok. Can I get it to read them again?
Is it a CD drive, a CD burner, a DVD drive, a DVD burner or a Blu-Ray drive? Have you tested all types of cds for the drive? Do certain ones read and noth others? What version of Windows are you running? Did it stop working after a program install or a system crash?
Nov 08, 2011 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 won't recognize DVD-ROM drive as Boot Device.
Enter the Bios and under System Components find the Boot priority in the Bios and move the drive to the top of the list, also you can press F12 at Start up to select it as well. :)
Apr 14, 2010 | Dell Dimension 2400 PC Desktop
I cannot play a DVD on my Dimension 2400. I can
Oops... Man sad but True, it isn't a DVD ROM, if it says CD-RW.
Regards,
Waqar.
Aug 17, 2009 | Dell Dimension 2400 PC Desktop
CD Rom Drive opens and closes over and over won't quit
it happens often because of some materials or cd broken pcs try to clean it carefully
Apr 11, 2009 | Dell (0F027) CD-RW/DVD-ROM (Combo) Burner
Does the dell dimension 2400 burn dvds?
Hi budliteman36
Dell Dimension 2400 series will not bur DVD, see the link blow for specifications.
http://reviews.cnet.com/desktops/dell-dimension-2400-pentium/4507-3118_7-30824846.html?tag=mncol;rnav
You can replace the CD-RW drive with a DVD writer. Here is a list od DVD-R-RW writers.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=89&name=DVD-Burners&
Cheers!
Mike
Mar 31, 2009 | Dell Dimension 2400 PC Desktop
Dell dimension 2400 does not recognize cd/dvd drive
Dear Minita,
please follow these steps.
1. Click on START button, the click on RUN
2. Enter REGEDIT and press enter
3. When REGEDIT starts, open up the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325 -11CE-BFC1-08002BE10318}
4. After clicking on {4D36E965-E325 -11CE-BFC1-08002BE10318} you should see two settings on the right-hand side:
"Upperfilters"
"Lowerfilters"
Click on each of them, press DELETE and click YES.
Then close REGEDIT, shutdown & restart your PC
if you still having problem or any other questions, please do not hesitate to contact me.
Many Thanks.
Regards,
AJoshi
Mar 18, 2009 | Dell Dimension 2400 PC Desktop
Hard drive
Yes, it is possible to do so. Adding a DVD is pretty much the same for most PCs. I suggest getting an 80-wire cable. The simplest solution is to replace the existing CD drive and cable with a new 80-wire cable and a DVD drive. You'll have to get drivers for it as well as software to use it (if the drive doesn't come with any). If you want to add it and use the existing CD, then you'll need to open the case, add the 80-wire cable (in addition to the existing cable) into the second IDE cable connector on the motherboard. Check these instructions from Dell. (Note they suggest connecting it to the existing cable, but that may or may not be possible.) Go to:
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/drives.htm
Jan 17, 2009 | Dell Dimension 2400 PC Desktop
DEll 2400 - cd-dvd drive stopped working
try to clean the lens using lens cleaner...
Dec 02, 2008 | Dell Dimension 2400 PC Desktop
DVD drive bay
yes you should be able to play CD on the DVD reader.
Dimension 2400 have drive slide mounted on the side of the hard drive, cd drive and floppy. they are different for each device. you need the 2 side mount for the dvd. in order to mount them in the Dell.
the drive is inserted from the inside of the box toward the front. The front panel will prevent the device from pop out.
yes, 3 party DVD, CD drive will be shorter and fater that what Dell porvide, but it will work, al long as the opening is accessable.
get the HP DVD driver.
Nov 04, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
149 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
