Question about Jandy LAARS LX250 - NATURAL GAS, DIGITAL READ-OUT, LOW NOX
Jandy lx250 heater is giving me service code ags
    Problem Solver:
  • 9 Answers
AGS automatic gas shut down
which means you have ignition failure, which can be from low gas pressure, or volume. if the heater fires then goes out the signal is not going back to the control module check all wiring.
Posted on Jun 18, 2009
  • Scott Corey-reid Feb 13, 2014
    also caused by flame sensor failure. clean the flame sensor. a dirty flame sensor will cause heater to short cycle. flame sensor should be your first area to check
Jandy LT250 pool heater ignites, then shuts down right after the fan comes on and gives service code "AGS". What's happening?
AGS means didn't fire correctly check gas if ok check flame sensor see if burn tubes blocked if ok bad flame sensor
Jun 06, 2018 | Jandy Pool & Spa
Tip
Laars LX250 Manual Download
Laars LX250 Installation & Operation Manual
Models: LX250NL / LX250PL / LX400NL / LX400PL
Models: LT250NL / LT250P / LT400NL / LT400P
Have you lost your Users Manual / Owner's Guide for your Laars LX250 Pool Heater?
Would you like a digital copy of the Installation / Operation Manual for easy searching of terms and quick reference?
Click here to download your pdf version of the Laars LX250 Pool Heater guide.
I hope that helps.
on Apr 19, 2010 | Jandy Laars Lt 250,000 Btu Heater
Jandy LX250 pool heater won't light - trips out after 3 attempts on "AGS Fault" - gas valve is getting 28V when needed and you can feel it click, and igniter is glowing fine - not getting the brief whiff...
Yes, it is either the gas valve or the gas supply that is the problem. Can you check the gas pressure with a manometer? How old is the heater? Gas valves go about 10-15 years on average.
Aug 13, 2013 | Honeywell Vr8305m4231 Pool Heater Gas...
Sevice MANUAL FOR JANDY LX250
go to jandy site they have PDFs of all
Jun 27, 2012 | Jandy LAARS LX250 - PROPANE, DIGITAL...
On the jandy 400 lt its displaying the AGS code... what does that mean?
Per your owner's manual:
AGS
(automatic gas shut-down)
1. Oscillating pump pressure.
1. Clean filter or identify and repair cause of pump oscillation.
2. Low gas supply pressure.
2. Identify and repair incorrect supply pipe size or pipe line blockage.
Refer to qualified service personnel.
3. No flame at burners.
3. No flame at burners. 3. Identify and correct loose wiring connections, or problems with igniter, flame sensor, gas valve, or ignition control.
For more info the manual is here:
http://www.jandy-downloads.com/pdfs/LXandLT_H02140B.pdf
John
May 03, 2011 | Jandy Laars Lt 400,000 Btu Heater
Service light and ags light comes on after a minute or two
I had this problem. Jandy ended up replacing the burner from day 1 with the heater (LT400 propane). It was a manufacturing defect. Of course it took 5 trips from the "warranty" company to not fix it before they finally punted to Jandy. Then, there's only one Jandy service rep from VA to ME (I'm in PA).
Jan 27, 2010 | Jandy Laars Lt 400,000 Btu Heater
Jandy LX250 LT Pool Heater High Limit Switch
Jump the High limit switch. If it fires the switch is bad
Jul 16, 2009 | Jandy LAARS LX250 - NATURAL GAS, DIGITAL...
Laars lx 250 fault code "AGS"
make sure safety circuit is ok that cuts off fan and check pressure switch and hi limits
May 22, 2009 | Jandy LAARS LX250 - PROPANE, DIGITAL...
My "AGS" code is lit.
check gas pressure if too little it will error out
Jan 08, 2009 | Jandy LAARS LX250 - PROPANE, DIGITAL...
Jandy LAARS LX250 - NATURAL GAS, DIGITAL READ-OUT, LOW NOX Logo
1,234 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
jhalston
Level 1 Expert
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
