Question about John Deere Garden
Discharge indicator light stays on.
I have a 1993, 318 John Deere lawn tractor. I have a problem with the battery discharge indicator light staying on. Where do I start, one thing is that it seems that I can trickle charge battery and things seem to be find for a little while. My trouble shooting book says it might be a defective stator. Is the stator easy to replace and where do I start.CECIL
  • 3 Answers
I would start with a new voltage regulator which is located under the battery tray.
Posted on Jun 29, 2009
I have a sst16 and the battery will not stay charged any suggestions as to what the problem could be. I can not find the fuses is there a diagram
battery will not stay charged Deloris, Have battery tested could be bad (lucky to get 2 seasons out of one). You have to see if charging when running with a digital volt meter. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to test small engine charging system battery alternator
Repairing the Charging System on John Deere 175 Lawn Tractor
Electrical System Troubleshooting for Lawn Tractors Mowers
Apr 03, 2016 | John Deere Garden
My John Deere 1023e had a dead battery now it won't start
Sounds like the battery is discharging somehow. I would check to see if the key that starts it and controls the headlights is left on and allowing the batter to discharge.
Mar 01, 2015 | John Deere Garden
180 john deere riding lawn mower
Your deck belt slipping. It need adjusted or replaced
Aug 11, 2014 | John Deere Garden
John Deere LX188 17hp Kawasaki eng. Battery light constantly on; PTO for mower intermittent; will shut down after running for about an hour(battery discharge?). Suspect voltage regulator. Can't...
I have same problem with my lx188 battery light stays on and will run fine at idle, then I can mow for about 15mins then it powers down and run rough, and battery light dims down.
???? Is it the voltage regulator ?
May 06, 2011 | Garden
John Deere LX188 lawn tractor battery discharge light remaining o
Check the brown wire feeding your voltage regulator,its between batt and steering wheel behind left side of frame.LX100 series machines had a problem with brown wire not fully contacting terminal in regulator.You will know you had bad contact if plastic is discolored.
Sep 23, 2009 | Garden
John Deere Lawn Tractor LX176. Battery discharge
Locate voltage regulator above battery to the left as you sit on machine,its behind frame that supports steering wheel.Once you have found it use a light to shine on harness and follow the brown wire that leads into regulator.The plastic around that wire should not be burnt or showing any other color.The LX series machines had a problem with brown wire coming loose and causing the charging light to stay on.Remove plug from reg and use small screwdriver to clean out wire and work it a little so it makes good contact.
May 08, 2009 | Garden
Garden Logo
1,547 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
