Question about Goldstar GVR-E435 VHS VCR
How to connect flat screen t.v to vcr - Goldstar GVR-E435 VHS VCR
  • 458 Answers
Easiest way is to connect the TV & VCR using a Scart connector. The VCR should automatically switch over when play is selected. To go over to the VCR channel then select AV1 on the TV input select. ( This may be named different depending what make of TV you have eg. AUX 1)
Posted on Jun 20, 2009
Connect rbg cable tv
Contact Arris Support ARRIS for Consumers
Mark
Motorola Support
Apr 23, 2014 | Motorola Audio Players & Recorders
I have a 32" Snyo TV serial #DP32642 and my Emerson VCR that records on tape cassets. I can not get the VCR to display on the TV screen. I do not have a cable that will fit any connections I find.
The Emerson VCR has output connections for left (W?) and right (R?)audio and video (Y?). Your Sanyo TV may have inputs for the same in which case you would make the appropriate connections. Some operation of your Sanyo remote has to be found that will allow your videotapes to be seen on the screen
Jan 17, 2013 | Sanyo Televison & Video
How do I use this on my VCR?
Connect you vcr audio video output to tv audio video input and turn it on. On your tv menu select video input. If you see 'tv\video' on the button switch of the remote control or tv switching panel, press it.
Oct 25, 2010 | Televison & Video
I'm trying to get my dvd recorder and vcr hooked up to my new flat screen tv. How do I connect them and what channel do I put my tv on (flatscreens don't have channel 3 or 4) to recognize the dvd recorder...
DVD players do not connect using regular cable connections Your flat screen TV should have separate Audio and Video connections. These are the connections that you should use to connect your VCR and DVD player. If you have a combo unit, that is a single unit that has both DVD and VHS in one box, you might be able to get your VCR to work on the cable connection. However your DVD will not be able to work as the cable connection doesn't allow enough information to pass through. If you go to your local Audio Video store and tell them what you want to connect they should have the cables you need for less than $10.00. Good luck.
Sep 15, 2009 | Televison & Video
HOW DO I CONNECT MAGNAVOX DVD/ VCR TO VIZIO FLAT SCREEN
Is simply. get the audio/vido cables and look on the back of the TV and connect from the audio video outputs from the combo to the audio video inputs on the tv. remember the colors of the terminals and connect them that matches the red, white (audio) and the yellow (video). Using the remote locate the button "input" or "source", and select video 1 or 2, depending where you connected it.
Nov 18, 2008 | Philips Magnavox DVD/VCR Dual Player
I cannot connect my vcr to my saNYO FLAT SCREN
First of all, it's a disservice to connect an aging vcr to a new flat screen. 2nd if you must, find out if the back of the vcr has the same connections going out to the back of the new tv going in. Post pics of the back of your machines if you can't find a friend to help.
Oct 17, 2008 | Televison & Video
Dvd/vcr combo connection
Click here to download the user's guide and check page # 9 for more info on connecting your DVD/VCR device to the LCD. Use the yellow, red and white cables connected to AV1 or AV2 and select the appropiate input from your LCD.
Sep 13, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Unable to connect philips dvd recorder/vcr recorder to philips flat screen 19pfl4322 tv. HAVE AV 1 AND AV2 ON FLAT SCREEN TV BUT RECORDER WILL NOT GIVE MENU PICTURE. COAXIAL CABLE ATTACHED TO VCR AHD...
make sure that av 1 out on the dvd go into av1 in on the screen and av2out goes to av2in onto the screen.make sure the cable is not loose.press av on the tv remote till you find it. same with the vcr remote
Mar 31, 2008 | Televison & Video
Bought a new 42' flat - "No Program or Weak Signal"
Hi,you have not said weather you are using a scart lead(euro connecter)or an RF lead,if you are using the later don't,please connect the vcr to the tv via the scart to scart euro connecters,use a good quality scart lead(the thicker the better)as the thicker ones generally are 21 pins connected meaning it should be auto switching so as soon as you play a tape it will come straight on.
Feb 02, 2008 | Televison & Video
CONNECTING A VCR RECORDER/PLAYER TO A HD FLAT SCREEN TV
Now one question - Do you want to record the TV program on the VCR or Movies from a DVD plater hooked to your HD TV?
Jan 10, 2008 | Goldstar GVR-E435 VHS VCR
Televison & Video Logo
604 people viewed this question
Top Goldstar Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Goldstar Televison and Video Expert? Answer questions, earn points and help others
