Question about Vtech DECT 6.0 Cordless Phone with Digital Answering System
My v-tech phone will not set to EST. It goes back to Pacific time as soon as the phone rings.
  • Vtech Master
  • 2,460 Answers
The key is "as soon as the phone rings". Who's ringing it? I had one of those on Packet8. I had to go to their website and get the instructions to change the time offset in the Packet8 ATA. Check with your dial tone provider for a solution. Carl
Posted on Jun 16, 2009
When I change time on phone, it goes back to the incorrect time
Most phones are programmed to select the EST & PST, & when we change to the standard. Do you have a set button somewhere. Again, techie I am not, & it should stay that way. Get a fourth grader, they can do it for you. Seriously.
Nov 06, 2017 | Cell Phones
Synergy global supply model 9105 how to set
http://www.synergythesource.com/doc/alarm-clock-setup-910500.pdf
Quick Setup
Model 9105
Alarm Clock Radio
1) Plug clock in before making any adjustments.
2) If using on East Coast- Do nothing! Time and date are set to EST- Daylight Savings time is 'On". Clock is ready to use.
3) If using in time zones other than EST. Hold the clock with LCD facing you. Lean clock back and find small button on bottom right marked P-M-C-E. Hold for 2+ sec. LCD will blink the time zone. Press button again until LCD blinks the correct time zone, CST, MNT, PACIFIC.
4) Daylight Savings time- Default is always on. If you are in a zone that does not recognize daylight savings time. Hold the clock facing you, lean clock back and on bottom left is a small button marked D. Hold 2+ seconds and the LCD will blink ON. Press again and LCD will blink OFF. Daylight savings time is now OFF.
5) If power goes out, clock will retain time and alarm will sound if in the ON position.
6) Replace batteries once every year...!
7) If clock looses time or date:
a. Hold Volume +, and Tuner + at same time for 3 seconds
b. Clock face will blink year
c. Turn outer ring of alarm to set Year
d. Press Tuner + once, turn outer ring to set Month
e. Press Tuner + once, set Day
f. Press Tuner +, set Hour
g. Press Tuner +, set Min.
h. Press Tuner + to save all settings.
You must go through all set points to have them remain in memory. (have to run thru all a - h, can't set just Day or Hour/Min, etc. without starting with Year)
Any questions please call:
Synergy Global Supply
804 435-7520
8:00am-4:00pm EST
Oct 23, 2012 | Audio Players & Recorders
I just wanted to ask how to shorten the number of rings before it goes to voicemail on a t7316 and t7208 phone. Thanks
You may need a tech if unsure of programming, passwords and navigation.
In Config or Admin under Sets/Capabilities you will see Forward No Answer, that needs to be pointed to the voice mail ext # (F985 to see what that is), then after that setting is the ring count....4 is recommended for average office staff.
Aug 06, 2012 | Nortel T7316E 2-Line Corded Phone
My accuwave ds model 625-236 is stuck on the pacific time zone and will not let me reset it to EST which is where I live. How do I fix this problem. Thank you, Bhavna
Time Zone Setting
1. Press the MODE button to enter the Alarm Time Mode.
2. Press the SET button to change the time zone.
3. Press the MODE button to exit.
Apr 01, 2011 | Howard Miller Techtime II 625236 Clock...
Jakks spytech watch only will work when connected to USB port of computer. If disconnected it goes blank and will not operate. When connected toi USB port the following message is the only thing...
Same problem. But I am able to set the location, time and date while usb connected. As soon as I pull it out, total failure. Even tried the RESET button on back, but nothing works.
Anybody... anybody?
Dec 27, 2010 | Jakks Pacific Spy Kit
How do i adjust length of time phone rings lg kf310
Call in to Customer Service, listen to prompts for tech support standard customer Service will just Fwd you there, ask the tech that you would like to extend the amount of rings before it goes to your voicemail some providers do it by rings, and i know at&t does it by seconds and if it is by secs good rule of thumb is 5 secs = 1 ring!
Jun 28, 2009 | LG KF310 Cellular Phone
Voicemail won't allow recording transfers back to receptionist!
Are the mailboxes set up?? What happens is a call goes to an extension, there is one program set to tell the system that if a call rings 4 times, go here(voicemail). Once it goes there, the voicemail system sees that there is or is not a mailbox matching that extension. If there is, the call goes to voicemail, if not, it transfers to the operator.
OR.....Does your system display the correct time? Its possible that the phone system lost its programming, and doesnt know where the voicemail is.
Both might need a professional tech on site...a bit too hard to help over a forum.
Mar 20, 2009 | Lucent PARTNER18 Corded Phone
Phone does not ring
You have to go in to installer programming to make the phone ring . Press feature ** 266344 the system will then ask you for a password just re-enter 266344 . Next if you have the old software you need to go in to config,show stations , line access ,ring and change to y for yes , if it is the newer software you start at terminals and sets . If you have any ? you can call me 626 712 5753 pacific time .
Jan 27, 2009 | NorStar M7324 Telephone
How do i inrease the number of rings
Don't know if this will work, but try the 983 feature, pw 1020000 (or 120000, or 10020000, depending on your extension numbering). Access the Mailbox menu. "Show" thru the menu until you get to "forward to" ###, then next. This should ask for delay. (to est time in seconds, multiply the number of rings by 6)
Dec 11, 2008 | NorStar T7316E Corded Phone
Vtech DECT 6.0 Cordless Phone with Digital Answering System Logo
261 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
