Question about Fantom Drives Titanium II (TFD160U2) 160 GB USB 2.0 Hard Drive
D: drive is opening
I was working on my computer and suddenly power went out.when the power comes back and i started my computer then mine d: drive is not opening.when i open this drive it shows an error performing page operation . I have done the following: Click "Start", "Run...", type "cmd" and click [OK] or press [Enter]. From the command line type "chkdsk d: then i got a message this drive,path is not invalid .now how to open d: drive and recover the data
    Scholar:
  • 124 Answers
You sound like you know some techie stuff, so I'll speak more techno-geek ...
Run on your C: drive the "chkdsk c: /r"
Make sure your drivers for the D's connection are still viable; not corrupted from the power outage. Remove and re-detect the USB Hub, if that's what you connect with...
It is not seeing your D at all, so it's not something ON your D that is bad; its in your computer itself.
Posted on Jun 16, 2009
Suddenly loses power no noises coolant light and temperture light comes on
probaly lost fuel pressure, from fuel pump going out, or relay went out. Need more info such as, did engine stop running completly, or did it start back up etc. post back please.
Mar 09, 2014 | 1995 Oldsmobile Achieva
My toshiba satellite pro was set to hibernate, and when i went to turn it back on the power light comes on, and the cd drive light comes on, but that's it. the cd won't even open so i can't use my recovery...
Try this first to get it out of hibernation mode. Unplug the power supply, remove the battery. go hava cup of coffee. Come back, reinstall the battery and power cord. Attempt to restart the computer.
If this fails go to....
Look at the cd drive. Next to the button that normally opens the cd drive is a pinhole. Power up the computer. Using a straightened paper clip, push the paper clip into the pinhole. you should be able to get the cd drive to open.
If you can not get the computer out of sleep mode you should now be able to get the cd drive open and use the recovery disk.
Oct 27, 2009 | Acer Aspire M1201 Athlon X2 320 Gb PC...
Sudden loss of power and won't come back on
More than likely it has a bad power supply board. The only thing is good luck finding one. I am going to try to repair mine.
Oct 02, 2009 | Polaroid FLM-3201 Television
The Acer X1700 desktop suddenly stopped booting.
i would check your power supply. take it to a local computer shop. or call acer for warranty support.
or if you are running on a backup ups, plug the computer directly into the wall and try it again
Sep 23, 2009 | Acer Aspire™ T180 PC Desktop
No Power Steering
Sounds like a belt come off, that drives your alternator & power steering as well.
May 10, 2009 | 2003 Ford ZX2
My power steering suddenly went out on '98 Olds Regency
your power steering and alt. belt come off.. the same belt runs both of this things.. check to see if the belt is there.. good luck keith..
Mar 20, 2009 | 1999 Oldsmobile 88
Maxtor 3200 power indicator lights but computer won't recognize
ooooh, that sucks.
I assume you have tried unplugging it and plugging it back in?
Have you tried to see if it will work on a different computer?
I hop you had it all backed up.
If nobody else's suggestion beat mine...then I give you 2 options.
You have to take it apart (might have to break the shell, since most aren't designed to be user friendly), once you have the actual hard drive out of its housing, open up the side of your computer, and hook it up.
it will have to diferent connection points. One will be power (thats the plug that has (i believe) 4 pins in it...hook that up so your drive has power...the other plug is for data (read/write), its either a sata or ide (depending on how they (maxtor) made it). I assume you dont know what sata or ide is...just google pics it...once you see a picture...you'll know.
anywho, once its hooked up...start you computer back up (FYI, when you do this 'operation', shutdown your pc...and then unplug it)
once you have it all done and loaded back into windows, it should automatically detect it (give it a few minutes).
that scenerio I just laid out for you, is assuming its anything but a hard drive issue.
if it is indeed a hard drive issue....then apart from sending to to some VEEEERY expensive palce that could extract the data for you. theres only one more option. Put the hard drive in the freezer for several hours, then take it back out and hook it up to you computer, if it detects it...move fast, and start transfering all your files off it...cause now its living on borrowed time.
the reason this works **sometimes**, is because of the hard drives heat, its its platter actually expands over time a (very very very tiny bit), enough to mess it up, and when its chillin in your frezzer, the platters contract a little bit...making you able to get your data back...hopefully.
hope all goes well.
Mar 20, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
All of a sudden" going into hibernation"
try to open ur laptop cover .
on the mainboard there is usually a jumper located near the cmos battery. try to change its position for 3 seconds and return it back to its normal position.
this way u will clear the board memory .
start ur computer and load default settings.
hope this will help.
May 14, 2008 | Acer Aspire 3000 Notebook
SimpleTech 320GB Hard Drive- unable to detect the device
I had a similar problem with a SimpleTech 250g Pininfarina USB drive.
I went through the drivers, the power supply, the USB cables, and the various
computers, USB cards and Operating systems.
Finally I opened the case and found the disk drive was mounted too far
forward, causing the IDE connector to barely touch. I loosened the mount screws,
slid the drive back towards the connector, tightened everything down and it works.
Mar 15, 2008 | SimpleTech Pininfarina 80GB External USB...
Screen black
toshiba cosmio f10 laptop screen is not working. Totally black. from start nothing there. just black.
Dec 09, 2007 | Acer Aspire 5100 Notebook
Fantom Drives Titanium II (TFD160U2) 160 GB USB 2.0 Hard Drive Logo
79 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Computer Links
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
