Question about Intertherm P3RA-036K Air Conditioner
I hear the compressor and the fun works but is
I hear the compressor and the fun works but is not cooling
  • 43 Answers
This could be caused by a few things. The #1 would be low on refrigerant.
Posted on Jun 16, 2009
GE refrigerator model #GSS22WGMD wont cool at all but fans run but don't hear compressor
If possible, try by passing the thermostat. If it starts up the t/stat is bad.
Feb 25, 2015 | GE Refrigerators
Maytag refrigerator model msd2651heb not cooling. Hear fan running but not condensor
if you mean the compressor isn't running most likely you have a bad start device part 67005560,pull out machine unplug it and remove the bottom back panel,look at compressor,pop off metal clip and remove cover on the side of compressor,slide off the device and shake it,if the device is cooked you'll hear pieces rattling around inside it,install new part,if it still doesn't start could have a bad compressor.
Jul 14, 2012 | Refrigerators
I have a Turbo Air TGF-49F freezer and it is not cooling. The compressor unit seems to work but when I turn the unit on all I hear is the compressor running continuously but nothing gets cold.
Difficult for you to check this I'm afraid, if the fan on the cooling unit is working unless you have an experienced 'ear' you will not hear the compressor running or worse still occasionally clicking.
Possible faults are
1. Compressor not running (the fan will run even if the compressor does not) electrical fault
2. Compressor seized (consult your service guy) also true for the rest of these
3. Compressor not pumping
4. Refrigerant leak
Not much hope for a cheap repair
Apr 14, 2011 | Turboair 49 cu. ft. Upright Freezer...
How do i turn it on for the first time
hi there'
turning ac on,there are two switch on control panel of ac.find the thermostat control this signifies the room temperature you want,set this first to a maximum setting.another switch is for the motor compressor and fun motor.rotate the switch to fun first after a couple 15 second rotate again the switch to lo cool setting w8 for 10 to 15 sec. then rotae it again to hi cool there will be a sudden heavy change of blwing air and cooling effect then rotate set the thermosat switch to temperature comfortable to your feeling,observe the cycling process,because the compressor motor stop if the room temperature reached the set up temperature.stopping or switching off just rotate the switch of the compressor motor on off position.have a nice day fix my rate thank s a lot.
May 14, 2010 | Amana PBE12 Wall/Window Air Conditioner
Freezer works fridge cool but not cold
Most side by side units have 2 compressor units. If you listen for it, you should be able to hear 2 compressors with slightly different pitches, operating at different times, or sometimes at the same time. If you never hear the fridge side compressor turn on, a sensor or the compressor is probably bad, if you never hear the fridge side turn off, the temp sensor is bad. If it has ever, or is leaking in the back, then there is a puncture in the cooling system, and the fridge will not be able to be cooled. If you can pull the fridge out and examine the tubes or unplug it for about 10 minutes and plug it back in to observe compressor activity and any small leaks, it would give a more definite answer to the problem. A mechanic will most likely be necessary.
Dec 04, 2009 | Amana SXD524VW Side by Side Refrigerator
Mod# GS6SHEXNLOO Ser# GF827090B Strip between side by side doors is hot to touch, not luke warm. Fan in back is working but not cooling.
The fan which cools the compressor ? You cannot hear the fan that cools the compressor . Have to visually look , If you hear a fan , it has to be the freezer fan you are hearing .Remove the rear panel behind refrig to see compressor fan .
Aug 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Won't cool any more
What do you mean turns on. The light inside is on. Do you hear the compressor coming on. If you hear the compressor turning on and the fridge doesn't get cold, compressor might need freon. If compressor doesn't turn on, your timer is not working
Jul 23, 2009 | Kenmore 52632 / 52634 / 52639 Side by Side...
Refridgerator/Freezer stopped cooling
if the compressor was very hot to the touch, suspect you have a compressor fault
Oct 02, 2008 | Refrigerators
Intertherm P3RA-036K Air Conditioner Logo
101 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Bill Long
john h
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
