To set the timing for the distributor on a 1983 Toyota forklift, follow these steps:
Locate the distributor on the engine. It is usually mounted on the side of the engine and is connected to the spark plugs via spark plug wires.
Remove the distributor cap by unscrewing the screws or clips that hold it in place.
Locate the timing marks on the engine. These marks may be located on the crankshaft pulley or on a timing cover on the front of the engine.
Turn the engine over by hand using a socket and ratchet on the crankshaft pulley bolt until the timing marks are lined up.
Loosen the distributor hold-down bolt so that the distributor can be rotated.
Connect a timing light to the battery and to the number one spark plug wire.
Start the engine and aim the timing light at the timing marks.
Rotate the distributor until the timing marks line up with the proper degree of advance specified in the engine manual or on the emission control label.
Tighten the distributor hold-down bolt and recheck the timing.
Replace the distributor cap and reconnect the spark plug wires.
Test drive the forklift to ensure that the timing is set correctly and that the engine runs smoothly.
It is important to consult the engine manual or a qualified mechanic to ensure that the timing is set correctly for your specific engine and application.
start by checking to see if you have power and ground at the coil connection look for chewed wire rodents are known to chew on toyota wire harness due to what they are made of
