Question about Samsung 710N V2 17" LCD Monitor
Not optimum resolution message
I had no power problem.the processor is too hot at the data card and it says not optimum resolution
  • Anonymous Jan 26, 2008
    I have the same problem. The monitor display this pop-up on a blck screen and I can't get out if it...!!
    Please help me.
    Thanks.
Buy another monitor
Posted on May 26, 2008
Hello, My winXP cannot recognize monitor Asus VH232T - windows suggests 4:3 resolutions only. Can you please advise where can I download the monitor driver? Video card is ATI RADEON XPRESS 200 Thank...
Hi
Monitors do not generally require drivers. The .inf drivers to run almost all monitors are already in Windows.
The problem here is in the settings of the graphics card.
Many users aim for Maximum resolution, when what they should aim for is Optimum resolution, balancing the RAM, CPU, GPU, GRAM and Monitor''s resources in the most efficient and effective way.
Keeping the relevant software updated also has an impact on graphics performance (grpahics Card Drivers, Java, Flash, DirectX, Video Codecs, etc.)
If the video resolution is set too high (or too low), beyond the graphics capabilities of the monitor, on reboot, the monitor will be unable to resolve the image.
The simplest solution would be to use a different monitor to adjust the video resolution, shut down then test the preferred monitor again.
Right Click on desktop>Properties>Settings then use the slider scale to adjust resolution, then Apply, Yes on the optimum setting, them OK.
Find the optimum setting in XP with your graphics card for this monitor and you should be fine.
Hope this helps.
Aug 02, 2011 | ASUS VH232H 23" Monitor
"Not Optimum Mode","Recommanded Mode 1280
FIXED : Before you start your legacy game, software where the "Recommanded Mode 1280 x 1024 60Hz" keeps showing, change your display FROM VIDEO CARD DISPLAY control application to 1024x768 or your choice.
My Syncmaster 2233 had same problem of "Not optimum mode" box coming on whenever I started any old game like Age of Empires etc. It got fixed by selecting FROM DISPLAY CARD DRIVER CONTROL UTILITY's (mine from Catalyst Control Center) >Set desktop area to > 1024 x 768 in my case BEFORE STARTING old application/game. Switch back to your normal resolution after you are done with this application.
Hope this helps.
Regards
Saurabh
Jun 29, 2011 | Computers & Internet
My monitor keeps going blank with a window that pops up saying "Not optimum mode. Recommended mode 1280 x 1024 60Hz" then there is a question mark box. I can't get the display back, no matter...
check you video graphic card option and select or fight the right resolution,otherwise update your video card and you can use this :
CLICK ME
here's the serial : JCCQ-MAKC-KACK-6TSE-BN35
Jun 05, 2011 | Samsung SyncMaster 912N 19" Flat Panel LCD...
When i turn on my computer i get the message"NOT OPTIMUM MODE, RECOMMENDED MODE 1280x1024 60Hz" What is the meaning if this?
This is just your computer trying to give you the best resolution your monitor can handle. With the extent of modern technology being what it is, most devices will communicate information between themselves without a human being needed for most of it. This case is a perfect example. Many new monitors will "tell" the computer what their maximum resolution and refresh rate are, and the computer will automatically set your video card to use those settings. Resolution is the "1280x1024" part of the message, which refers to the number of pixels and size of area to be used on the monitor. Refresh rate is the "60Hz" part of the message, and isn't really important unless you see a flicker on your monitor or are getting into the advanced usage of a large, powerful monitor system.
The message you received was because of a miscommunication between the monitor and the computer. The monitor had no factory set value for its "Optimum Mode", so your computer was forced to ask you for input. The recommended mode should work just fine for you, so feel free to ignore that message unless it starts causing you problems, like an odd flicker in your screen or the screen not displaying your desktop properly.
Mar 06, 2011 | Samsung SyncMaster 710N 17" LCD Monitor
After 5 years with no problems, my Samsung SyncMaster 915N monitor is blank with the exception of an error message that says something about needing optimum resolution. At first we thought it might be the...
The optimum resolution for this monitor is 1280x1,024 @60Hz.
The resolution setting is done at the PC not at the monitor.
After 5 years, more likely components failure will be the filter caps in the power supply section, that will be the first thing to look for inside. You can see failed SAMSUNG monitors here:
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Apr 27, 2010 | Samsung SyncMaster 915N 19" Flat Panel LCD...
I have a Samsung SyncMaster 901B, it's not new, a friend gave it too me, i connected it to my computer,i start the computer, it works fine until windows finishes loading, then the screen goes black and i...
What happen when you hook this monitor up to other PC that has the video setting 1280 X 1024 60 Hz? Just ant to narrow down the problem before opening up the monitor. You may have logic problem in the logic board. If it does the same with other PC, then open it up and inpsect the inside for such thing as failed caps on the logic board or on the main power supply board, I think more likely to be ROM chip on the logic board is scrambled.
See typical failed monitors: http://s807.photobucket.com/home/budm/allalbums
Mar 30, 2010 | Computers & Internet
Samsung syncmaster713bm not optimum mode
try to adjust resolution you monitor may not support higher resolution change it in the display properties
Mar 13, 2010 | Computers & Internet
Nvidia geforce 9400gt 1gb card problem
The maximum performance of your video card is limited by the hardware you attach it to. In the display properties of Windows, your highest resolution is 1280x1024 because your monitor is not able to go any higher than this. This resolution is a typical maximum for a 17" monitor. Some 15" can do this, and some 19" can do this. In order to get a higher resolution, you'll need to get a bigger monitor with a higher native resolution. For example, a nice 24" monitor can only do 1920x1200. The video card can go higher, but it's limited by the monitor. 32bit color is your highest setting - that's 16 million colors. Your video card's 1GB of RAM only determines how much rendered data (usually 3D) it can store and move at any given moment, which is related to but not determined by your screen resolution. That's a very nice card - you should be able to get very good frame rates, color, and performance out of 32bit color and 1280x1024. If you want a higher resolution, you'll need to get a bigger monitor.
May 13, 2009 | Computers & Internet
I have an error message on my screen which ios moving around. It says - 'not optimum mode. Recommended mode : 1280 x1024 60Hz'.
Sounds like you have an LCD monitor. LCD monitors look best in their native resolution. Yours must be 1280x1024. You need to (assuming this is a Windows PC) right click on the desktop and choose Personalize, Display Settings (Vista) or Properties, Settings (XP or older). Set the slider to 1280x1024. It'll confirm the change and then the message should never reappear.
Aug 28, 2008 | Computers & Internet
Screen blacks out
OK you need to try this monitor on another pc so as to write off a faulty graphics card. If your settings on monitor match the pc and youve tried the auto settings button, there is a faulty lcd for replacement.
Nov 10, 2006 | Samsung SyncMaster 510N 15" LCD Monitor
Samsung 710N V2 17" LCD Monitor Logo
261 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
