Question about LG 52SX4D 52" HDTV
Tv has a green tint
My tv has a green tint to it...I removed the back cover hoping I could see if maybe a different colored bulb was out which would cause this, but it only looks like there's one 'white' blub. Any ideas what could be causing this or how it could be fixed?
  • 2,071 Answers
Its cause this the life span of the lamp is come to an end. To see the life hours of your lamp. Just go to the service mode.If you inclined to get into service mode on LG DLP TVs, simply turn your system off, then use the remote and press the following buttons with about .5 to .75 seconds delay between presses: MUTE-1-8-2-POWER. Once in the service menu, select the bottom item, Options, and from there you can reset the lamp .
Good luck:
Regards:
Posted on Jun 29, 2009
Replaced color wheel now picture has green tint tint conttrol is locked out
There is a jumper on the DMD board. It is there due to 2 different versions of color wheels out in the market. It is usually on the right side of the DMD (looking into TV from the back). You don't have to remove the light engine, just the rear cover. Use needle nose pliers to pull out the jumper. It should look something like this: I hope this was helpful.75bf945.jpg
Mar 28, 2010 | Samsung HLP6163W 61" Rear Projection...
I just replaced the bulb in my Sony 55'' Grand Wega. the picture looked fantastic the first day. turned on the TV the next day and everything that should have a ''white color'' looked pink. the blues...
Please adjust TINT control of Video Settings in Menu that will adjust color tone of TV. I do not think this problem is related with Lamp because TV screen does not have any color blobs or spots.
Above solution is for Sony KDF-55WF655 model TV, if your model number is different, let me know.
Thanks.
Nov 29, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Color has strong green tint - can't adjust with set-up program
One color plug in the back was unplugged - Since the TV had not moved we didn't think to look for that. The cable bundle must have been bumped causing the problem - I feel a bit silly that I hadn't looked for that. Thanks for your follow-up.
Jun 12, 2009 | Panasonic TH-42PX60U Television
Dell 2300mp projector, colors bad
try reseating the vga cable. Try removing the cable, the green tint should disappear meaning that the color or lack of one of the primary colors blue/red/green were missing due to bad connection. or maybe you have a bad vga cable.
Feb 26, 2009 | Dell 2300MP Multimedia Projector
Samsung txh1970 tv screen has green tint
I encountered the same problem with a color computer monitor several years ago. Everything went green. The repair techies told me that's a sign that the power supply is going bad. You will not be able to adjust the color. You will have to either fix it or replace it. Hope this isn't a common problem with this model Samsung TV.
Dec 01, 2008 | Samsung TXH1970 TV
Samsung HCN4226W Green Tint Around Corners
sounds like the alignment of the convergence in that area needs to be preformed or you have a speaker or something in that corner
Mar 10, 2008 | Samsung HCN4226W 42" Rear Projection...
Green hue instead of actual colors
Short on the crt board, look in the green area. Probably an small 3 leg transistor.
Sep 04, 2007 | Sharp 27L-S300 27" TV
Open Questions:
See all LG 52SX4D 52" HDTV Questions
LG 52SX4D 52" HDTV Logo
885 people viewed this question
