Question about Maytag Atlantis MAV6451 Top Load Washer
Fresh water fill does not shut off. - Maytag Atlantis MAV6451 Top Load Washer
  • 6,784 Answers
Hi. this is a failed inlet water valve assembly. replace asap if possible. it has failed.
Posted on Jun 16, 2009
Keystone Raptor 3110TT 2007 and fresh water holding tank. What size PEX cap do I need to prevent water from running out of my drain. Can't fill up water holding tank.
The water tank drain should have a shut off valve to prevent water leak. I wouldn't cap it, you should want to drain water tank on occasion.
Mar 21, 2017 | RVs
When connecting the water to the city water connection it filled my fresh water tank. Is that normal?
Probable cause would be a leaking check valve in the pump.
On the RV the city water and discharge from the fresh water pump are tied together. When on city water the discharge of the pump will have city water pressure on it. If the internal check valve on the pump is leaking, water will flow through the pump backwards and into your fresh water tank.
Mar 15, 2015 | Heartland 2014 Gateway 3200RS
Where is the shut off valve to drain the fresh water tank
follow the water line coming out of the fresh water tank going to the pump. the valve should be there, usually near the tank.
Jul 13, 2014 | Holiday Rambler 2014 Aluma-Lite 278BHS
Trying to fill fresh water tank. Overflows in a minute
there is probably a stoppage in the relief opening. should be next to the potable water fill. are you trying to fill from the pressure inlet or potable fill inlet? if from the pressure inlet, there is a bypass valve by the fresh water tank to divert watr into it.
Jun 19, 2014 | Thor Motor Coach RVs
Thor ace 29.2 fresh water won't fill
check for blockage in relief valve next to potable water fill. it has a little screen that allows air to flow out as water is going in..also if you are using pressurized side check the bypass valve by water tank.
Jun 19, 2014 | Thor Motor Coach 2014 A.C.E. 29.2
How do you get mold out of fresh tanks?
There should be a fresh water fill on the outside of the coach. If not then there is a valve that would need to be turned that will allow water to be put into the fresh water tank. If that is the case then it will be a bit more difficult to put bleach into the fresh water tank but not impossible. There will be a pump that draws fresh water out of the tank. You can disconnect the input and output lines. Connect the input line which comes from the fresh water tank to the output side of the pump. Then using a flexible line with a 1/2" pipe thread fitting, connect that to the input side of the pump. Put the loose end of the flexible line into a gallon of bleach and turn the pump on. It will draw the bleach out of the container and pump it into the fresh water holding tank. Now return the plumbing of the pump back to the original configuration. Using the valve system complete filling the fresh water tank with fresh water and allow to sit for a couple of days. Then open the low point drain on the fresh water tank and completely drain. When the coach is not in use make sure the tank is completely drained. There is also a fresh water treatment that you can purchase at your local rv parts department.
Jun 13, 2014 | KZ Coyote Rock Climber CRC220 RVs
Why does water not shut off after making ice
Is the bin drain line and dump drain line tied together. If so then it is melting ice from the bin. now when ice machine starts up it will dump the old water in sump tray so it will be fresh water during new freeze cycle.
Jun 25, 2013 | Scotsman CSW45 15" Ice Maker with 26 lb....
Maytag ice maker floods the kitchen when water does not shut off when filling the ice tray. What's the reason and fix?
What is the refrigerator model number? In most cases the dual water control valve with have a mechanical defect and cause the water to flow by the valve even when off. W10408179 Water Inlet Valve
If you can find your model number around the fresh food section door frame please post so I can insure I give you the correct part numbers, Thanks Sea Breeze
Dec 04, 2012 | GALAXY Microsystems 25.4 cu. ft....
Maytag Atlantis MAV6451 Top Load Washer Logo
52 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
