Question about Yamaha RX-V630 Receiver
It has lost partially the mechanical connection between the volume control knob and the volume control pot.
When I turn the volume control down it seems to"slip" ....the knob turns but the volume does now go down. The volume on the remote works fine. I believe I just have to tighten the mechanical connection at the knob.
Thanks
Bernie
  • 1 more comment
  • Anonymous Jan 11, 2008
    I have the same problem. Pushing slightly harder on the volume knob as it is spun seems to help.
  • twicefooled Jan 13, 2008
    I have the same problem on mine,turning the knob left and right but the
    volume is not changing the right way... I think it's the problem with
    the volume knob itself since it is endless rotation...I have tried to
    open it and clean it (i think the potentiometer needs cleaning) but
    everything is well soldered and i don't have the right tools for
    that...so I'm thinking about send it to a service....for now I'm using
    the remote, but I really love to turn that knob...
    Any solution on yours???
  • Anonymous Feb 18, 2009
    i also have this problem
    when turning the volume knob the volume changes erratically and used to work perfectly
    the volume works perfectly with the remote
    the solution posted is not a valid solution as the knob on my receiver is not stripped at all infact it is in almost perfect condition
    there is obviously something more to this problem then just a stripped knob
    any ideas would be fantastic :)
    thanks in advance
  • 979 Answers
The knob could be "stripped". A drop of a slightly resilient glue should do the trick. Do not use rigid adhesives, as this will prevent future service to this area of your receiver....accordianman
Posted on Oct 31, 2007
Mackie 450, signal light off, Sound only comes out when amp. turned up above 75%, when usually used at 40-50%. too loud at 75% and UP, does not Work at ALL below 75%. only 2 years old, with 25 uses... i...
Doesn't sound like a fuse. They don't fix themselves when you reach 75%.
Try shaking the volume knob while in the 30-50% range and/or try (with the power off) rotating the volume knob numerous times from 0% to 100%. If when you plug it back in it responds ANY differently, you might have a bad volume potentiometer. If when you shake the knob you hear static or intermittent sound, you have a bad volume pot.
The only other thing I can think of is that the wiper of the volume pot is not in contact with the windings inside the pot until you reach the 75% mark. When the volume comes on at 75%, does it start off kind of "static" then come in loud and clear? Also try this.... adjust the volume pot to 74% (or when the sound just begins to come on). At this point shake the knob. If you hear static, replace the volume pot.
Unplugging it when still on shouldn't cause any damage... in fact it probably hasn't considering it works at 75% plus.
Mar 14, 2008 | Audio Players & Recorders
Low volume one speaker
It seems likely that the pot (volume control) is dirty. with a slider you can normally get fluid down the side of the knob, your's is a rotary control and you sometimes can do it round the shaft of the pot but more often have to spray it in where the connections go into the pot. You'll need some contact cleaner spray which you can get online or from an electronics store, get it onto the pot track and then take the pot to each end of its travel a few times, this'll probably sort it out until next time. If you're taking it apart it might be worth just getting a new and better pot and soldering that in if you are hand with a soldering iron. The ones in Mackies nowdays are pretty sh1t.
Feb 08, 2014 | Mackie MR5 MR5 Reference Monitor
Onkyo TX-DS575 Receiver Volume knob on the receiver is not working. Sound level can not be adjusted. Volume adjustment with remote controller works fine.
SOLVED!
Behind the volume Knob you have an unconventional and completely closed dust-proof potentiometer which allows for endless 360 degree rotation. After simply pulling the big Vol knob from the panel you must unscrew the nut from the "potentiometer". Easy operation. Now, from the backside you can carefully release it from the panel (in my case it was a bit stuck). It comes out with a small piece of printed circuit board which is tightly fasten through a short cable to the display panel which limits the movements of the released circuit board. With very light hands and finding a way to give the circuit board some mechanical stability you must unsolder the "pot" (2 chassis points + three connections, I advise to do it with the aid of a small vacuum desoldering tool). Even much more carefully you are suggested to disassemble the square format "pot" (4 bent clamps) so you can get into the heart of the beast. If you still have a good eye you will see on one piece a rotor with about 24 (I was not able to exactly count it) copper radiuses and on the other piece 3 + 1 ultra tiny almost invisible brushes aimed to contact with the copper radiuses. Clean both components VERY well and VERY CAREFULLY (I did it with alcohol and a napkin, it seemed to me that some kind of grease of the rotor flowed in) and reassemble the mechanism, weld it on the print board and fasten the "pot+circuit board" to the panel through its nut. Put the Vol knob on the "pot" spindle and it should work as new until receiver's end of life! (hopefully!). I found some similar "potentiometers" in the Internet to buy (perhaps better alternative to clean the mechanism) but no way to get the right specification. If it comes to that point perhaps you must try to find a "pot" with same size, number of connections and around 24 pulses per revolution (or something similar).
May 20, 2011 | Audio Players & Recorders
Black cables loose
Does the jack have any wires connected to it? Can you tell where the disconnected wires originate? Typically, the wire from the middle ear of the volume pot should go to the tip of the jack, and the wire from the back of the tone pot goes to the sleeve of the output jack. You will get no output if either of these wires are disconnected. Also, the next question is "why" did they come loose? That's usually because one of the pots is not tightened down, and is allowed to spin when the volume or tone knob is turned, breaking the wire's contact. Pull the knob off the pot, and tighten the nut down so the pot can't turn. This will assure you won't have the same problem again.
May 26, 2010 | Dean Vendetta XM Electric Guitar
The volume control does not go up or down when I turn the knob. I have to play around with it and sometimes it works and other times it dosen't.
On volume control potentiometer carbon layer wears out with time. The easiest way would be to clean it with spirit. Turn off the unit, remove the knob, spray spirit on volume control then turn the knob back and forth around a minute, should work after. Also you can disassemble CD player and resolder pot contacts on the board, when pressure constantly applied from outside, contacts get loosen. And the best way will be to replace the pot.
Oct 30, 2009 | Alpine CDM-7874 CD Player
I am having problems with the volume knob. The
That is a dirty pot switch.. The volume adjusting pot gets dirty.. Two things to try..
1.) With the unit off - spinn the volume min to max many many times at a rapid pace.. This sometimes will displace the debris in the pot..
If that does not work --
2.) Get some "tuner cleaner" in a spray can.. At Radio Shack or a similar store.. Lay the radio on its back so the volume knob is facing up.. Pull the knob off carefully.. Use short controlled bursts of the spray.. A few sprays and spin the knob min to max several times and repeat..
Good luck..
PLease dont forget to rate for your free question..
Aug 20, 2009 | Lasonic TRC-931 Cassette Boombox
Dual head unit help!
You can try contacting the manufacturer to see if it can be repaired.
When you have this type of problem, it's generally due to the rotary encoder failing. It's unlikely anyone else will have parts.
Dec 22, 2007 | Dual 2-Channel Bridgeable MOSFET Amplifier...
D608 - Volume Problems
I just picked up one at the dump. You have to take apart the front end by unscrewing screws and pulling out ribbon edge connections. It is easier than some components. Then pry off two of the small clamp downs on the front of the volume potentiometer; pry apart about 1/32 of an inch and spray control cleaner for a second and clamp down. repeat on other side.
worked for me.
Bill
Aug 18, 2007 | Pioneer VSX-D608 Receiver
Sound
hi, ya, someimes the POT i.e the volume controller variable resistor loses its contacts with the carbon strip. tru using some switch cleaning solution( NoN Acidic) to clean the POT,let me know
Dec 07, 2006 | Yamaha GX-70 CD Shelf System
Yamaha RX-V630 Receiver Logo
741 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
