Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
Ethernet and internet lights keep flashing - system is slow
    Scholar:
  • 124 Answers
Check you system for Malware.
Got to the site, download the free version of MalWare Bytes and make sure to run the update!! Then have it check your system to see if you have "caught a cold!" :) Sounds like you might have a virus.
http://www.malwarebytes.org
Posted on Jun 16, 2009
  • 81 Answers
This is quite normal. Are you able to access the internet properly?
When attempting the surf the internet or to stream video, my ethernet light will simply stop blinking. When streaming video I often get a message that says my internet speed as slowed. The problem is not...
many of the antivirus software many programs using internet . some timesw your antivirus softwares may have blocked them
you can add the blocked programs into trusted list hence surf the net dont forget to comment and vote thanx
Mar 25, 2011 | 2wire (1000-000057-000) Modem
My modems LAN light is blinking and I can't get Internet, I've tried unplugging it, but the problem still exists, please help
There will be 4 lights...
Power
Dsl
Internet
Ethernet
Power light indicates power supply is good...
Ethernet light indicates connection between modem and computer is good...
DSL light indicates connection between modem and telphone line is good... Also DSL light should be steady and it should not flash...
If it flashes then it says there is a lot of noise in telephone line...
Internet light says whether the internet status is connected or not...Internet light can flash depending upon the internet activity...
Feb 03, 2011 | Paradyne 6381 ADSL2+/ReachDSL Router...
Internet light flashes
Internet light its normally blink, you have to make that the UPnP on your XBox is enabled.
Feb 28, 2009 | NetGear WGR614 Wireless Router
Speedstream 4200
The ethernet light should not blink at all. The first thing to try is a new ethernet cable. If the problem still persists, then you need to check with your internet provider.
Storm608
Feb 04, 2009 | Siemens SpeedStream 4200 (13A4200001)...
My internet light "connection keeps going on and off
if your internet light on the modem is blinking or flashing, then you do not need to worry. the Ethernet light and the internnet light on the modem will always blink, but the dsl and the power lights shud not blink...
for more tips and information click here
Dec 01, 2008 | Westell Wirespeed LiteLine 6100...
Ethernet light blinking
ok this sounds easy
heres your problem you
DsL is a glorified phone connection its not smooth and is always in a state of flaux along with your neighbors there neighbors so on and so forth
technecoly i would run cable connection that does not flaux with neighbors always have a strong signal and wont interfere with your videos
DsL is slow as 58 bit data fax modem i found it a waist of money and time waiting for system to play catch up
now if you want to play videos with out interupt turn off cable dsl modem this will bring function back to normal in video mode
your comps fine its just your service provider
May 09, 2008 | Westell Wirespeed LiteLine 6100...
Enthernet connection
Ethernet connection is a LAN or a CAT cable
One end of that cable will connect at the back of ur router box that u will have with u or u will get it from ur ISP .
and the other end of that cable goes to the back of ur pc in the jack which says LAN or try to plug it in any socket which fits properly.
u will a light that will start flashing at the back of ur back when u plug that cable in
to check whether u system supports ethernet connection or not
1. right click on my computer
2. goto properties
3. goto hardware
4. goto device manager
5. u will find network adapters there
click on the plus sign on the left side of network adapters
plus sign will change to minus
under network adapters look for an ethernet adapter or network controller
or 10/100 or 10/1000 fast ethernet NIC ( network interface card )
if u have one , then ur pc supports ethernet connection
U just have to connect the ethernet cabel to ur router box and at the back of ur pc and u just have to open internet explorer and ur internet would start working...
if u dont have ethernet cable with u or ur system does not have an ether net socket in ur system , u can goto any computer shop and get an ethernet cable and a socket for ur system
If u dont want to do that , u can go for a USB cable connection with ur pc or a wireless connection....
reply back if u face any further problems
Feb 19, 2008 | Computers & Internet
Terrible slow internet connection after installing SP2
If you are sure it is a motherboard problem relating to the on board ethernet connection, purchase a PCI slot ethernet card and see if using the card manufacturers drivers are better than the motherboard ethernet drivers. Although i'm not sure how a slow connection is the motherboard problem, it maybe that it's SP2 thats the problem. Have you checked the driver that is used for the onboard ethernet connection, it maybe you need to re-install original motherboard ethernet driver you got with it.
Dec 07, 2006 | Albatron KX600S Pro Motherboard
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
113 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Carlos Soto
Carlos Soto
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
