Question about Black & Decker String Trimmer Cordless 12" 18V
Battery os fully charged, all connections are good,but there is no power to the motor?
What powers the slide out ?
If you are referring to a camper, the 12 volt auto battery powers them. Fully charge the battery first. there is a switch inside the camper to power the motors be sure its turned on. A lot of campers seem to have a problem with poor wire connections and broken wires. clean all connections check for broken wires and check fuses. good luck.
Apr 06, 2016 | Cars & Trucks
When i connect the battery it will not move and the battery is fully charged
Check to see if power is reaching the motor. Bet you it isn't.
And are you sure that the battery is good? Use a voltage meter and/or hygrometer? Power switch good? Variable speed control any good?
Dec 06, 2015 | Health & Beauty
Rv won't start. starter just clicked rapidly after replacement, battery tested good. Dash lights (high beam and Turn indicators ) light when ignition switch is un start position
Poor connection either at the starter, battery, alternator, or loose engine ground strap. Fully charge the battery also.
May 10, 2015 | Cars & Trucks
2006 Honda TRX 500 ATV, battery fully charge at 12.1 and when I turn the key on I get nothing on the meter screen, when I hook up the battery charger I still get 12.1 but then the meter screen comes on,...
The battery may show full charge and still be bad. If one of the cells are bad it will not have enough power to start the motor. Need to get battery checked and check to see if the stator is putting out full power to charge the battery.
Oct 25, 2013 | Honda Motorcycles
Pedego hub motor jumped and then no power. Fully charged battery and have lights showing fully charged battery.
Please give us a call so we can fix the issue! (800) 646-8604
Thank you,
Pedego Team
Oct 01, 2012 | Motorcycles
It just clicks when i try to start it, wont turn over
ureCheck battery charge it should have 12 to 13 volts if it is fully charged.Check all electrical connections from battery to starter and ground wires. Check the solinoid ,it must make a good electrical connection internally to make the starter motor run.If you are getting at least 12 volts to the starter motor and it still wont turn the starter may be bad. Also be sure that the engine can be rotated normally.
Jun 10, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
2001 Avalon was dead (battery). Won't start or jump
If the battery is fully charged there is but one thing tjst gives you those symtoms. You simply have a bad connection at the negativbattery cable. It won't hurt to ck the positive cable also. This os a common thing when a battery is connected and idle..Always disconnect the bat neg if the the vwhicle won't be used for more than two days. If possible, don't charge your dead battery with the alternator of the vehicle. It could very possibly cause charging problems. The clickinf is from insufficient voltage and jump stating with te dead battery still in place doesnt work because the goog and bad batteries are try to balance again, causing low voltage/amps to the starter. Good Luck. Sorry about the lesson, habit.
Sep 22, 2009 | 2001 Toyota Avalon
I have a toyota corolla and battery is fully charged no power
Sounds like a bad connection with one of the battery cables check the connection to both cables at both ends and I personally would make sure that i cleaned the main engine ground (where the negative wire from battery connects to engine). Good luck!
Aug 13, 2009 | Toyota Corolla Cars & Trucks
Indicator light fully charged...but barely enough power to move
i have the same exact problem on 1 of my sons MX5s..i checked all 3 batteries and all that! you left out the controller clicks when the back wheels sapose to be moving ,it's not....so worse case scenerio batt,controller,motor,(650 This time)& throttle....So theres our blue print...lets hope it's just the batteries....!
Mar 30, 2009 | Razor MX350 DIRT ROCKET - BLUE
Black & Decker String Trimmer Cordless 12" 18V Logo
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
