Question about Sharper Image Ionic Breeze 3.0 Air Purifier
Broken internal wire
Is there a place to buy these ?
  • 2 more comments
  • jefftl Jun 16, 2009
    I knew they filed but I was looking for a few generic parts places.
    I just ordered 100 micron corona wire to see if that works. Will post when I get it installed.
  • jefftl Jul 03, 2009
    I also tried to rewire. not an easy job and did not work long term. I am buying a unit off ebay now. too much to go through :-)
  • Samuel Charles Spriggs May 11, 2010
    I repaired four of these units using titanium wire. They worked for about a year. Long-term, I don't think these units are worth the repair -- as most agree, this is a very tough, complicated job. I started getting them off E-Bay -- these didn't work very long either. Now shopping around for a more rugged ozone-generating air "purifier". Charlie
  • 6,784 Answers
There are no replacement parts for these devices. the parent company that distributed these units are no longer servicing the units. Sharper filed for bankruptcy two years ago.
Posted on Jun 16, 2009
  • 1 more comment
  • Michael Masters
    Michael Masters Jun 16, 2009
    I see. i checked on the replacement parts you seek. there are none online that will be useful in this unit. sharpers designs are rare and, all replacement parts vanished when the company was dissolved.
  • Michael Masters
    It is possible to purchase the identical gauge wire form a local electricians shop or radio shack i suppose. this should work. the contacts are another issue.
  • Michael Masters
    Ok.
How are the wires attached?
I am going to try repair with stainless guitar string .005"
Posted on Jan 04, 2010
  • docante Jan 04, 2010
    am planning on repair with .005 " guitar stainless wire I have laying around
    how exactly does the wire attach?
    Problem Solver:
  • 6 Answers
I have the broken wire problem and did the following. First I mic'd the wire to determine its size (0.0050" or 36 Gauge). Then I measured the resistance of a salvaged foot of it which measured close to 27 ohms. These are the kind of specs that define Nickel-Chromium (Nichrome) wire. I went over to eBay and bought a 30 ft coil for a couple of bucks and rewired the unit. (This is not a job for the faint hearted or the ham fisted and you had better have a soldering station available.) I turned the unit on and it worked........for about a week and then the wire snapped again. Thinking the piece of wire I used might have been flawed I redid the wiring (with another piece from the same coil - you need about 4 feet to do the job) and again the unit worked for a bit over a week and failed the same way. Considering that this wire is fed from its center point by a high voltage very low amperage source (similar in style to the high voltage flyback/rectifier found on CRT monitors/TVs) and is unterminated (i.e. its an antenna generating an electrical field) I don't know why nichrome should fail; after all its common use is as a heating element and can turn red hot without breaking. Heat is not an issue here. Could the wire itself be faulty which seems the most likely explanation and if so, how? Would the problem be addressed by using a heavier (smaller gauge) wire? Doing that would significantly lower its resistance per foot and besides this was not what was originally provided. So in the end here is what I believe to be useful information about the wire but no lasting solution. Anybody know where to to get factory spec on the wire (ha ha) or know anybody who might have a spool of it?
Posted on Jul 03, 2009
    Problem Solver:
  • 5 Answers
Greensal,
Good post on the sharper imagae ionic breeze corona wire. Mine also broke, I measured it that same as you did and confirmed the same measurments (0.0050" or 36 Gauge). When I took the resistance measurement, and reconfirmed, I got 2 ohms per foot.
Nickle wire in 36 gauge is 2.4 ohms per foot.
304 stainless in 36 gauge is 17.5 ohms per foot.
Nichrome 80 in 36 gauge is 26 ohms per foot.
Nichrome 60 in 36 gauge is 27 ohms per foot.
Manganin in 36 gauge is 11.6 ohms per foot.
Tungsten in 36 gauge is 1.6 ohms per foot.
This says the wire I have in mine is probably steel.
I would use Tungsten in a .006 or 34 gauge wire due to it's superior properties.
Due to the fact that this wire is basically a high voltage antenna with a corona field around it, the resistance should not be a significant factor. A larger diameter wire such as 32 gauge would offer a greater resistance to breaking and only a slighltly diminished corona field, but should again not be a factor in the overall operation.
Posted on Sep 27, 2009
  • Ken Gillette
    Ken Gillette May 15, 2014
    Were you able to fix your air cleaner? Where did you purchase the white Tungsten 32 gauge wire?
The nichrome wire is a very old type of wire. One unusual problem that it has always had is a tendancy to break over time if you touch it. The salts/oils from your fingers corroded the places where your fingers have touched it. A form of corrosion. WEAR CLEAN COTTON GLOVES OR PLASTIC GLOVES WHEN HANDLEING THIS WIRE. The same problem happens when handling high intensity Halogen light bulbs, the finger print salts and oils will cause the bulb to fail when the high heat of the bulb contact the salts/oil that you left behind. ALWAYS WEAR CLEAN GLOVES.
Posted on Aug 04, 2009
  • Ken Gillette
    were you able to fix your air cleaner?
Ionic pro CA500
Yes, a new portion of wire can be put in place of the broken wire.
Sep 28, 2014 | Ionic Pro CA500 Air Purifier
What happens having one broken wire?
Not trying to be funny, but it depends on the wire, if your air purifier is still running or not, whether you have lost hi/low settings etc. Or is your plug wire and you lost the internal ground wire. Attached link you are able to download user manual. Need to be more detailed, color of wire, location of break. Hope this helps, or provide make model, and other details. PEACE
http://www.oreck.com/userguides/global-user-guide.html
Redirect Notice
Jun 07, 2014 | Oreck XL® Tower Air Purifier
My ionic pro ca500 has the blue light on but also is making a intermittent sizzling sound, I have wiped the blades, the clean light is not on.
What does the blue light mean? I had 4 Ionic breeze air cleaners, ionizer wires are broken. I was thinking about buying the Ionic Pro cleaners, but have no input about how well they work.
Dec 02, 2013 | Ionic Pro CA500 Air Purifier
Honeywell Enviracaire Elite 300 problem. Light is not on. Seems like no power to system. No snapping or noises. No obvious bent fins or broken wires
If it was wired to the return air it will have a flag switch to let it know the blower is on, sometimes the flag comes off and it wont operate, sometimes it is wired directly to the computer board on terminals EAC that stands for electronic air cleaner and the board turns the air cleaner on when the blower is running, if you have a meter you can check voltage in both places to see which one is the problem. let me know. thanks wally
Mar 11, 2011 | Honeywell Enviracaire Elite F300E-1019 Air...
Two of the cleaner wires are broken and lying in the bottom of the unit
I am not exactly sure what you are talking about. Can you please explain in more detail . Thanks!
Oct 28, 2010 | Ionic Pro CA500 Air Purifier
Broken Wire inside unit. Looking to have it repaired or purchase part.
You're probably screwed....
The company went under and doesn't service them anymore. It's possible you could find a local repair place that might be able to do something, but there is no authorized or trained service station, and you can't get parts.
You might be able to pick up spare parts if you scour eBay long enough.
May 21, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
A broken switch on a small portable ozone machine--X-15 or XL
Hi again, epyn,
As I think about this more, I'd say that the switch you have would probably _not_ work. What you have is somewhat like a conventional 3-way switch. With the Alpine/Ecoquest switch, I suspect one terminal is for power to the internal light/LED, one is the load to the switch, and the third would be the ground for both.
If I can be of further assistance, let me know - I'd like to resolve this for you. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Dec 15, 2008 | Alpine Air XL-15 Air Purifier
Ionic breeze quadra
If you are talking about the 2 thin wires inside the unit, it can be fixed if you are good with taking things apart. You have to do an almost complete tear-down of all the internal components (many hidden screws). You can replace the broken wire with a .009 or .008 gauge E string for an electric guitar. This can be found at a local musical instrument store. The string must be cut to almost the exact length. The wire has a spring tension mount on a small circuit board. If the replacement wire is too long, there will be too much slack, too short and you will not be able to put it back together. I did this and it took me hours. I removed about 80 screws to disassemble it.
Nov 03, 2008 | Sharper Image Professional Plus Ionic...
Broken Wire
Go buy a couple of .09 guitar strings from your local music store. This is how I fixed mine. You need to very mindful of the way it is assembled whilst taking it apart so you can duplicate the assembly in reverse:)
Apr 29, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
Sharper Image Ionic Breeze 3.0 Air Purifier Logo
1,570 people viewed this question
Top Sharper Image Air Purifiers Experts
Marvin
Marvin
Daniel Dollive
Daniel Dollive
Jay Finke
Jay Finke
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
