Question about Frigidaire GLTR1670A Front Load Washer
Error Message "LOC" Three beeps, won't door lock or start
Won't turn on. Nothing resolves when unplugged and replugged.
  • 82 Answers
You may have to remove the lower front panel to get to the tech manual. If the door latch isn't latching though nothing is going to happen.
Posted on Jun 16, 2009
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
Machine turns on but won't start
this means that the door is not shut check to make sure the door button is still there its behind the door on the frame you should see a little black button sticking out if its not there you need a new door switch if its there try pushing the door button a couple times really fast sometimes this button gets stuck if that doesnt work its probably your door lock
Aug 27, 2012 | Kenmore 44102 Front Load Washer
My Neptune washer MAH6700AWW won't unlock door and won't work. It stopped mid cycle and the door is in locked position. I unplugged and replugged and try to run a cycle but all it does is make...
Hi
It seems that something is clogged in the drain pump assembly and you have to clean it to solve this issue. After cleaning if the issue returns then test the door lock assembly, if bad it should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jul 07, 2011 | Washing Machines
Door locked, won't turn on. won't reset by pressing pause/start/power or unplugging washer.
Remove the bottom panel which would give you access to the pump area if you look up along the side that the door lock is on you will see a cord with a loop on it pull this cord and the door would open. The panel must be removed in order to locate this pull cord. If you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future Thanks Rick
p.s if after you open the door and you were to leave the unit unplugged for 7 minutes if the error did not go away or if the door once again locked up you would have no choice but to replace the door lock assembly on the unit Thanks again Rick
Jul 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Continue to receive DL (Door/Lid cannot lock) error message. Pause/cancel and then start don't work. I have made sure nothing is blocking the door. I have unplugged and plugged back in. Continue...
Hi
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code. It has happened because Door lock mechanism is broken or removed from door. It may also happen due to Door switch/lock unit failure. To resolve the issue follow these steps---
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Hope this helps...Please post back if you need more information.
Daniel
Jan 01, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
F 22 front door locked and door won't open.
hi there,
the F22 stands for the CCU/Touchpad error. in other words, the keypad has lost connection with the control board behind it.
this is what you do:
unplug the washer
take off the console
check the connection between the touch pad and the CCU boad
make sure that nothing looks corroded or burnt
make sure that nothing is pinched or bent
unplug and replug wiring harness and connections form keypad to the CCU board
let me know if it this works.
Sep 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite 790.3670 oven door locked
I held down the clear button for three seconds, it unlocked but still showed the lock button lit. It began beeping over and over. I opened the door and pressed the clear button again for three seconds. It stopped and the oven works just fine now. In fact, I used it right after I got it cleared out.
Feb 07, 2008 | Kitchen Ranges
Kenmore Elite Range door locked error message
Hold down the number three button until the LOC message disappears and then the door will open.
Dec 23, 2007 | Kitchen Ranges
Front load washer won't start
Telescope, Im assuming your model starts with 417.44092, Kenmore made by Frigidaire. You have the best model with the digital display. Try unplugging the machine for 5 minutes to see if you can reset the board. If that doesn't work put it into a test mode by doing the following: Turn the dial to drain spin, press cancel to turn off the led's. Within 5 seconds press and hold the options and pause/cancel together for 5 seconds. All the led's should light. Now by turning the dial 1 click at a time clockwise you are going to test the following. 1rst click- hot water solenoid 2. bleach solenoid 3. Bleach and wash water solenoid 4. door lock solenoid activates 5. door lock solenoid de-activates. 6. the washer will fill and tumbe. 7. washer will fill and spin 8. drain pump and door lock will activate and washer will go in high spin. 9 clicks from the start, the last error code will be displayed. To clear the error, press and hold the options and cancel buttons for 3 seconds. To exit the test, just unplug the washer for 5 seconds. Sometimes these electronic boards just get a glitch and have to be reset. Make sure that the dispensor door is shut all the way. Try these things first...Catriver..post back.
Nov 04, 2006 | Kenmore Energy Star 44092 Front Load...
Frigidaire GLTR1670A Front Load Washer Logo
98 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
