Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
Gas pool heater pilot will not stay lit - Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
  • John Prohaska
    John Prohaska May 11, 2010
    When it lights, can you see the flame? What color is the flame if you can see it? Can you get a millivolt reading off the generator to see if the power output is high enough?
  • 366 Answers
Depending on the make and model of your heater, the first thing I would check for is gas pressure. If it is sufficient, check the pilot assembly for corrosion and/or a damaged pilot tube. Sometimes replacing the entire pilot assembly is a sure fix and also replaces the pilot generator that degrades over time. A new pilot assembly takes care of a couple of problems by improving gas flow and millivolts generated. Also, the orifice inside the pilot assembly could be corroded or clogged.
Posted on Sep 15, 2009
Teledyne laars xe pool and spa heater
look inside on panel directions if not turn to pilot setting hold down button light under where small silver line goes under while holding down button when lit keep holding for about a minute then turn to on should stay lit if wont stay lit need new pilot generator
Jun 09, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
My larrs pool heater will ignite,but not stay lit
If your Laars will not stay lit then the pilot generator is faulty. That is the small brass and copper piped connection near the pilot flame. It must produce 250minivolts in order to open the main gas valve and keep the gas running into the pilot burner..
please visit http://www.laarsman.co.uk for more help
Miles X
Jun 03, 2010 | Teledyne Laars Laars Lite2 Heater 400000...
Pool heater stays lit for approx. 30 seconds then shuts off. pilot stays lit whole time but burners wont stay lit. water flow is good
Problem with the thermocoupler its not producing a minivolt of 250 plus that is needed to open the main gas valve
Miles
Jun 02, 2010 | Teledyne Laars Laars Lx Pool Heater /...
I have a natural gas pool heater. When I release
Replace the pilot generator. For a quote on the part, send us your heater make and model using the contact form at www.arrowpools.net
Jul 16, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Hi I have an Hayward H Series pool heater and the pilot doesn't stay lit when I depress the control to turn it on. Any quick solution for that ?
Check the thermocouple that the pilot light heats up. If it is not working then the gas to the pilot will not stay on.
Jul 01, 2009 | Hayward H Series Pool & Spa Heater 400k...
Pilot did not stay lit,replace gas valve , pilot stays lit,but now it won't fire up. Jumped the TH terminals and it shut off the pilot light.thermostat is set highier than the water temp.Jump all ths...
Your problem is the pilot generator where the flame is by the burners. This needs to be repalced. That is what is causing the pilot to go out and not start. It is a flame sensor and also tells the gas valve when to release more or less gas.
May 28, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
288 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
