Question about Nikon D60 Digital Camera with 18-55mm + 55-200mm lens
When I take pictures with my D60 on Manual the optimal exposure seems to be lying to me. In both situations dark and light everything is much much darker than it should be at optimal exposure. I want to take pictures on Manual but am discouraged...
    Scholar:
  • 109 Answers
Check the white balance. Set it to the corresponding lighting conditions and try the white card setting. It should be the last option on the white balance menu. To use it, snap a picture of a white piece of paper and save it. Just experiment with different settings till you get good results. Best of luck!
Posted on Jun 20, 2009
Nikon d60 camera keeps taking dark pictures... what can i do to reset this?
Check your "exposure compensation" setting. It should be at "0". You can set it higher for brighter pictures.
Oct 10, 2010 | Nikon D60 Digital Camera
My nikon D60 is taking dark photos.
The only reason the camera will be taking dark photos is when it is under exposing the image taken. This can be due to the exposure compensation set to under expose the metered exposure. Make sure the expsosure compensation is set to '0' or increase it to compensate for the dark photos.
Also inaccurately metering a scene (such as a high contrast scene) can easily fool the meter into under exposing, especially outdoors.
Jan 03, 2010 | Nikon D60 Digital Camera with 18-55mm +...
Light facial detail in my Nikon D60
Are you using the flash? If so, dial in some negative flash exposure compensation. Otherwise simply dial in some negative exposure compensation.
However, you will have to leave behind the Auto and the other point&shoot modes.
Dec 28, 2009 | Nikon D60 Digital Camera
Photos are dark despite settings saying they're ok
Hi
It is possible that the EV control has been switched on. This will look like this +/- and is usally set to 0. Try that perhaps.
I am uncertain what you mean by MANUAL since if it is true manual control of exposure the whole point is that you can select the level of brightness you want.
Best of luck
marti
Sep 19, 2009 | Nikon D60 Digital Camera
Nikon D60 is taking very dark pictures!!
elis - did you ever solve this problem? the same thing is happening with my d60 and i don't know what to do!
Aug 14, 2009 | Nikon D60 Digital Camera with 18-55mm +...
Nikon D60 is suddenly taking very dark pictures
I have had "dark pictures" from each of my Nikon DSLR (D70, D80, D200, D300) cameras usually when taking pictures from a tripod and/or the self timer. Situations where you take your eye away from the viewfinder which allows stray light to enter thru the viewfinder and throw the auto exposure way off. Not sure if this is what is happening to you.
Jun 22, 2009 | Nikon D60 Digital Camera with 18-55mm +...
Nikon D60 (Auto Mode)
Read up on exposure and take the camera out of Auto mode.
Mar 22, 2009 | Nikon D60 Digital Camera
Pictures too dark
The settings in Auto Mode are factory set. If you want to adjust exposure and shutter speeds then you will have to shoot in Manual Mode (TV=Shutter Priority, AV=Aperture Priority, M=Full Manual)
May 24, 2008 | Canon Rebel XT / EOS 350D Digital Camera
White lines when you take photos in light, but perfect in the dark
The problem lies in you camera's CCD unit which is located on the back of the lens held on be 3 small screws it could also be a setting in the camera's menu try going into the menu and reseting the camera to default it works some times if that does not work than you need the ccd replaced pretty easy fix I fixed 1 with the same problem about two weeks ago for someone it happens I hope this helps you out.
Jan 30, 2008 | Casio EXILIM EX-Z1000 Digital Camera
One of the pictures has a great blue sky but the green tree is very dark and the other one has the green tree and very bright sky?
The two pictures were shot at dramatically different exposures - the "dark" one at 1/1600 shutter speed, f7.3, the "light" one at 1/320 shutter speed, f4.0. This accounts for the great difference, as the exposure conditions for the "light" one allowed much more light into the image during the exposure period. You didn't tell the whole story of how you set this up, I think you were shooting in a "spot" metering mode, where the particular exposure conditions the camera uses would vary considerably whether you were aiming at a dark area (making the picture light) or a light area (making the picture dark). I would make two recommendations: Switch your metering mode to "center weighted" (the mode labeled "[(•)]"), and also change your ISO setting to AUTO, as there would be no reason for shooting these photos at ISO 200 that I can think of.
Sep 04, 2005 | Panasonic Lumix DMC-FZ20 Digital Camera
Nikon D60 Digital Camera with 18-55mm + 55-200mm lens Logo
132 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
