Question about NEC DTU 8D-2 Corded Phone
Mic button How do I get the MIC button to not be lit
  • 149 Answers
Press function button than 1 or feature button than 1
Posted on Jul 08, 2009
The speaker phone will not work
If you have the speakerphone option enabled in system programming, you may just have the mic turned off. Try pressing Feature then 1 while the phone is idle. The mic light should light up if it wasn't already lit.
Apr 13, 2011 | NEC DTH-8D-1 Corded Phone
If you want to "make an announcement" using speaker phone using intercom, how do you do it
When you intercom the extension, insert a STAR ("*") before the extension number.
EX:
Dial intercom 12, will ring 12.
Dial intercom*12, will page the phone and go straight to speakerphone.
IF the far end user has their "MIC/HFAI" button lit, they will need to do nothing, they can just talk.
IF not, they will need to lift the handset, OR, press the "MIC/HFAI" button, to be head.
Oct 05, 2010 | Lucent PARTNER18 Corded Phone
Dell latitude d600, mic works sometimes
The Mic is on the same board that the power button is on.. there is a problem with this board,, the problem is were the power button board plugs into the main board....... when you push down on the power button your affecting the mic''s conection to the main board,, {Its a bad plug}
The Mic is found next to the power button.. to the left look for a small pinhole,, ....try pushing down to the right side of that.. test Mic when you do this,,,
You need a new main [mother] board to fix
Sep 25, 2009 | Dell Latitude D600 Notebook
Mic muted
Just check the button on the mic or the properties of the mic... from there only you can select the option to not mute.
Jun 13, 2009 | Logitech (980361-0403) Headphones
I can not figure out how to put in discovery mode when turning on
close the mic and hold down the button until it becomes purple. Open the mic and it should stay steady lit purple. Then you can pair it with your phone. I found the manual online because I had lost mine as well. Also, make sure any old phone you were using it with is off so it does not connect with that one. Good luck!
Feb 09, 2009 | Motorola Mobility H700 Wireless Headset
Why is the mic "lit" on my NEC Elite 8-Button Display Telephone DTU-8D
when the light is lit it allows hansdfree use of your phone.
Jan 31, 2009 | NEC DTU 8D-2 Corded Phone
Xbox 360 lips mic will not work
Turn your controller on. Turn the first mic on by pressing the button on the bottom until it flashes. Then press the small round button on the X box then hold in the button on the bottom of the mic. It should flash a lot telling you it is on. Repeat with the second mic. When you get into the game the second mic will not light up again until it tells you to shake the mic to sing a song. Also, make sure you do not have any other controller connected. (Like a guitar or drums) Hope this helps. I was very frustrated Christmas morning trying to figure it out, but now they work everytime.
Jan 18, 2009 | Microsoft Xbox 360 Console
MIC light
Button FNC, then button 1.
Oct 30, 2008 | NEC Electra Professional ETW-16DC-2
Microphone
If the radio receives OK and the TX red LED will not lit up when keying the mic, then it is a mic or mic cord or mic connector problem (or pin configuration). Internally to the mic, there is a switch for keying the PTT. This should be check down to the coiled cord to the connector.
If all of the above checks OK, then you would need to check the TX/RX regulator/switching circuitry.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 08, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Mic
If the MIC lite is not lit you must press "FNC 1" to activate the microphone. If the MIC lite is lit but the problem persists, the extension is not programmed to be handsfree or you may possibly have a bad phone. If the extension needs to be programmed handsfree, it will need to be done by a qualified tech.
Apr 28, 2007 | NEC ETJ 16DD-2 Corded Phone
NEC DTU 8D-2 Corded Phone Logo
405 people viewed this question
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Oloyede Monsuru
ray gallant
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
