Question about Maytag MBF2556HEW / MBF2556HEB / MBF2556HEQ Bottom Freezer Refrigerator
Refrigerator is warm, but freezer works. Coils are frozen.
Our refrigerator is getting too warm. The freezer is still working, but when you look at the back panel you can see the frost/ice on the coils. We have to use a hairdryer to melt the ice and it's good for a week or so. Then the same problems happens again.
  • 82 Answers
You are having a defrost problem, probably needs if it is a maytag, it probably needs a control.
Posted on Jun 16, 2009
Help please - my Kenmore Elite Bottom Freezer not cold - top refrigerator getting warm.
Have pressure taps installed, & check the refrigerant... these refrigerators have a critical charge (meaning not a lot of refrigerant to make them work) So whoever puts gauges on it, make sure they purge their hose while screwing the hose on to the new pressure tap so there is no loss of refrigerant & no air gets into the system. It sounds to me like it is low on refrigerant.
Dec 10, 2013 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Samsung sidexside refrigerator model RS263TDBP refrigerator warm freezer fine. Replaced fan on refrigerator evap coils, still not working. Help
Check the diverted box in fresh food side. Some of them have an electric flapper that opens to let cold air in to maintain temp in fresh food side. If coils are not frozen up then that is the next thing I would look at. The flap might not be opening up,
May 17, 2012 | Samsung RS263TDBP Side by Side...
The freezer stopped working, checked coils not frozen and not cold. Compressor seems not to be running, but making clicking sounds. Does compressor need to be replaced or, is some other electrical...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 29, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Frozen solid freezer, warm refrigerator. (model Amana bottom freezer abb1922few) Can see frost on freezer foods and back vents (almost occluded). Just vacuumed wads of dog hair/dust off of front half of...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 27, 2010 | Refrigerators
Refrigerator too warm. freezer works, 4 years old, electricity works. relatively clean around vents
Is the fan running? Could also be that the freezer coils are frozen up and not auto defrosting. There is a timer in the frig that controls that. Could also be the thermostat.
Mar 06, 2010 | Amana ABB222ZDE Bottom Freezer...
Freezer and fridge is warm, cold air blowing but freezer is still
Try this, I went to the freezer side pulled the inside back panel (had to defrost it to get it out) and it was completely frozen over. It was not not operating properly because the cooling coils would not allow the fan to pull air through them to cool the refrigerator side. I completely defrosted the coils and turned the refrigerator back on, it worked fine. I then ordered a new adaptive defrost assembly (this is the thing that prevents the ice buildup) since ours was apparently not working properly. I used a fan too speed up the defrost process, because i had to take all the frozen food out and put it in a cooler to get to the back panel. After you take out the racks and food you only need to remove two screws that have a 1/4' head. good luck.
Mar 29, 2009 | Maytag MSD2756G Side by Side Refrigerator
Refrigerator on the fritz
The defroster is not working. Ice build up prevents cold air from the freezer chest from blowing into the lower part.
The way the defroster works is this: There is a defrost timer, probably found under the refrigerator at the front, that turns on the defroster three times per day or so. That turns on a heater nested among the freezer coils. It keeps heating until the defrost thermostat gets warm; then it quits defrosting.
I think your defrost timer doesn't turn. You can turn it with a screw driver till you hear a click. Now your ice compartment should be defrosting. With ice buildup it may need lots and lots of defrosting. You might not get cooling back into the lower part for awhile, till the ice buildup melts.
By the preceding, you should know if the defrost timer needs replacing.
If you should need to manually defrost the freezer coils, they are, I think, under the floor of the freezer. To defrost them, I'm told, a hair drier works better than boiling water. The defrost thermostat is in there too, a one inch unit with two wires. It should have no continuity warm, closed circuit frozen. If it has open circuit frozen, that would be your problem.
Jun 14, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerator won't get cold
You likely have a defrost cycle failure. The freezer's cooling coils need to be frosty and cold so the air that the fan pulls over them can cool the fridge section. If the defrost cycle fails, the coils freeze up to a block of ice and air flow suffers (fridge is about 55 degrees F). The freezer stays cold only because there's a block of ice in there now... sometimes that cold "sinks" to the bottom and only the food at the bottom stays frozen (and can even freeze food at the bottom of the fridge compartment while the rest is warm). To be sure, you'll need to take the rear interior panel off the freezer back wall and check the coils to see if they are frozen solid. If they are then there's a defrost cycle failure. If they are showing a nice white frosty pattern evenly all over the coils then that's normal and maybe the evap fan (right above the coils) is not blowing air up properly or is not working at all. That fan should run if the compressor is running, etc. the only time it doesn't run is during an actual defrost cycle. Once you find out what condition the coils are in it should be simple to direct you further on the problem.
Jan 05, 2007 | Maytag 22.6 cu. ft. Side-By-Side...
Maytag MBF2556HEW / MBF2556HEB / MBF2556HEQ Bottom Freezer Refrigerator Logo
596 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
