SOURCE: Reg. zebra S600 lable
I had this happen when I changed from one label to a different size label. It needs to be calibrated. There are several types of calibration to do to the S600. Here is the solution that worked for me.
For CARD labels, the media sensor needs to be set at the edge of the card so it can “see through” the notch that is cut on the edge where the perforation is.
Set to Factory Defaults. This is so that all of the following steps will work. I do not need to change the steps based on the type of mode that printer is set up in because it will erase all that by setting it to the factory default. (See figure 14 for buttons)
Test to see if the calibration is set correctly for the label. If not, proceed to the following steps.
Turn off the printer.
Put the printer into Auto-Calibration Mode.
SOURCE: My printer appears to be printing the lables but
Make sure you are using thermal paper roll and not regular label roll.
