Question about Brother DCP-7020 All-In-One Laser Printer
Black vertical line on prints and copies. 20 blank copies will eliminate line, but as soon as I print something that draws on the toner the line is back again. Have replaced drum and toner without any change in print quality. Have cleaned the machine over and over. Have looked in the back of the printer where I can remove jams and one of the rollers has a black line running around it. Have tried to clean off but nothing comes off. Please help.
    President:
  • 3,085 Answers
It appears that the Teflon is worn off of the roller. You will have to have the FUSER replaced.
Posted on Jun 16, 2009
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Our copies are streaky like the drum is not clean.... help! There is black streaks on the top of all of our copies on our canon imagerunner 3300.
A) Black Streaks, Shadows, And Ghosting
Adjust the printer's lightness/darkness setting to 2-3 different variables and see if problem disappears. Look at the fusing assembly - is the roller torn or does it have any black buildup? Use caution!!! It gets HOT!
Try another toner also.
Feb 17, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
HP 2600N PRINTS A BLACK LINE VERTICALLY ACROSS THE PAGE (FROM TOP TO BOTTOM) RIGHT IN THE MIDDLE EVERYTIME YOU PRINT SOMETHING . WHAT COULD THIS BE? I HAVE CLEANED EVERY DRUM, THE FILM ETC AND IT KEEPS...
You either have a defective black toner, a bad fuser or transfer belt. From my experence it is usually a bad toner cartridge. After you print a couple of pages, pull the black toner and see if there is anything on the drum. If there is try shaking the toner, sometimes toner does like dirt and clogs up. If you still have problem you will have to try another toner. I know that is not cheep, but I don't know any other way.
Mar 02, 2009 | HP Color LaserJet 2600n Printer
Lanier 5622 Prints vertical lines
You could remove the color and black&white drum units and check from below the units to visually observe lines on all the 4 drums. If so, you have to change the drum unit/units. Drums occassionally get damaged before life this way due to solid toner particles inside the toner bottle.Always "shake the toners very well" before replacement, and if you print rarely, then remove the toners and do the shaking to prevent clogging due to inactivity.
Aug 28, 2008 | Ricoh CL4000DN Laser Printer
Printer prints white thick blank lines
1- black lines are from the drum: it has burnt out on that particular spot and rotates
2- the white horizontal gap space if it is not you skipping space is also from the drum
3-the white Vertical is most likely from the developper (unit that has the toner and is against the drum, look at the roller it should be solid black, maybe there is something on it : hair paper etc....
Aug 25, 2008 | HP LaserJet 1020 Printer
HP 3050 Black Line
I was getting a verticle black line and I had to clean the glass, the long white bar above the glass, and the white and black rollers before my problem was solved.
Mar 12, 2008 | HP LaserJet 3050 All-In-One Printer
Blank vertical line on pages
open side door, should be a black assembly there with two wires, is it clean? is there any toner or hair on the wires?
Nov 14, 2007 | Brother DCP-7020 All-In-One Laser Printer
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
Brother DCP-7020 All-In-One Laser Printer Logo
484 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
