Washing machine cl coming up on display
  • bradjess Nov 18, 2008
    Washing maching is coming up with CL will not clear doesn't matter what I press noting does anything won't even turn on or off!!!
  • 240 Answers
Try this:
If a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either "CA" for average current limit trip or "Cl" for instantaneous current limit trip.
Average current trip occurs if there is a 2 second average of current draw greater than 5.55 amps at the motor windings.
Instantaneous current trip occurs if there is a spike of 26 amps instantly at the motor windings.
This may signify problems with the drive motor, thermal protector, or motor controller. Over-loading the unit may cause this problem.
Press STOP/CANCEL to clear the display.
Also could be a leveler, u-joint, or basket drive condition. I hope that this is a Calypso washer.
Posted on Nov 01, 2007
I have a CL blinking in the display. How do I reset?
LG Washer Error Code Cl Fix -
Jan 19, 2011 - CL means that your washing machine's CHILD LOCK is ON. You canfind ... CL popped up on my display had no idea what it was because the manual didn't say. ... I have the touch screen panel and it does not have temp or option buttons ... I've had tried to reset but won't do do I press temp and what else
How does Child Lock work on my washing machine?
Samsung ElectronicsOct 23, 2015 - If the Child-Lock function is activated, the Child-Lock icon will blink. ...If 30 seconds have passed after opening the cover when the Child-Lock ... Step 5: To clear "CL" error on the display, close the door of the washer after ...
[PDF]Washing Machine - Home Depot
The Home DepotJan 3, 2015 - Warnings and Important Safety Instructions in this manual do not ... Donot wash or dry articles that have been previously cleaned in, washed in, soaked ......the Reset water level, "CL" is displayed on the LED display without.
Jan 19, 2016 | Washing Machines
Washing machine Siemens iq300 has error CL in display (status) & can't be used
This means that the door is not being closed. It might be a bad door switch.
Mar 27, 2013 | Washing Machines
CL is coming up on the display panel and machine is not working
(copy of your other one!)
'CL' stands for Child Lock.
To disengage press temp and eco/rapid together- apparently ;-0)
John C
Mar 14, 2011 | LG WD14121 Front Load Washer
The washing machine doesnt start at all. The displayer says: CL.
CL means "means chils lock" to disengage hold temp and echo/rapid together and this should solve the problem
Jun 21, 2009 | LG Washing Machines
hi Hills659.
this is all i could find out.
What does CL mean on LG washing machine?
LG Washer CL Code Definition (What does it mean?) = The CL Code on front loading LG washing machines simply means the CHILD LOCK feature is turned ON.
The CHILD LOCK feature on your LG washer is meant as a safety precaution so children are not able to change wash settings. CL is not an error code. It is indicating that the CL or CHILD LOCK feature has been turned ON and is active.
LG Washer Error Code CL How To Turn CHILD LOCK Off
Dec 17, 2017 | LG Washing Machines
LG-Trom Getting error CL .now not able to operate.after switch on it gives CL in display
IE is a water inlet error...meaning that the correct water level was not achieved within 8 minutes or it did not reach preset water level within 25 minutes...
CL is child lock feature which can be toggled on and off by by holding the Pre wash button in for 3 seconds.. Hope that helps...
Aug 04, 2008 | LG WM-2277HW Front Load Washer
LG WM-1285FHD Error Code 'CL'
The "CL" code is not an error! This means "Child Lock"!
To unlock a washing machine you will press and holding within 3-5 sec two button, marked "child lock".
And happy day will come! :))
Apr 09, 2008 | LG WD-1280FHD Front Load Washer
Machine shows Cl on dispay
cl is over loaded push stop clear to clear then try again with a lighter load
Jan 30, 2008 | Westinghouse WWS833ES Super Capacity Top...
Washing Machines Logo
162 people viewed this question
Top Washing Machines Experts
