Question about Cycling
I have a master cycle but I need 2 rear wheels with tires. Where do I look to get them or where can I get them?
    President:
  • 1,138 Answers
A good bicycle shop should be able to help you. They are 20X1.75" spoked wheels. Tell them what you want the wheels for and they can help you with any other parts you may need to mount them.
Posted on Jun 25, 2009
How do I change the inner tube on my rear tire
This is no easy task!
You will need to remove the rear wheel to access the wheel, tire, and inner tube
Unless you have a single speed rear axle, you will be needing to disconnect the multi-speed gearing, which you may not really enjoy.
God bless your efforts.
Apr 19, 2016 | Schwinn 24in Riverside Girls Cruiser Bike...
Why is just the LEFT side front and rear tire locking up
problems in the master cylinder
It should be left front and right rear wheels as these are the wheels affected by half the master cylinder
The other two are affected by the other half
Suggest you visit an accredited brake specialist shop and I suspect that they will recommend a new master cylinder.
Mar 23, 2015 | Cars & Trucks
Bleeding sequence for 91 nisson 240sx
always start with the farthest cylinder from the master cylinder and work your way to the nearest, finishing with the master cylinder itself.
Mar 07, 2013 | 1993 Nissan 240SX
There is a knocking noise coming from the rear of my 94 chevy 1500 series truck it is knocking at the speed of the tires turning and is loudest at slow speeds,what is it?
Car wheels spin at different speeds, especially when turning. When making a turn the outside tire turns faster than the inside tire since to outside tire has a longer distance to travel in the same amount of time through the turn.
FGTech Galletto 2-Master EOBD2 V51 BDM-TriCore-OBD
Dec 18, 2012 | Cars & Trucks
Vibrations at 60-65 mph. Have quality tires, balanced with Hunter road force, checked rims, all of it. Still won't go away?
Before going into more mechanicals, try using the spare tire on the front wheels and test drive to see if it helps. Then try the same with the rear wheels. It will take time and effort but as you do it you can check tierod ends better with the tire off. And it will not cost you anything to try it.
In the rear, with front wheel drive, there are 2 things that can cause this problem. You can check the rear wheel bearings by turning the wheel and checking for noise and excess play. The second thing would be a rear wheel Alignment which many front wheel drive cars require.
If you have rear drum brakes, look for rust outlines of weights missing from the drums. The other mechanicals could be the A/C clutch cycling which it does in Defrost and A/C mode. Turn controls to OFF and see if vibration disappears.
Would like to know outcome for this problem. Thanks
Oct 04, 2010 | 2006 Ford Five Hundred
How do you replace the front and rear brakes in a 2003 pontiac Grand Prix
Removal & Installation Front To Remove:
  1. Inspect the fluid level in the master cylinder reservoir. Remove fluid from the reservoir until the level is lower then half way between the MAX and MIN levels.
  2. Remove the tire and wheel assembly.
  3. Install 2 wheel nuts to secure the rotor on the hub.
  4. Remove the bottom brake caliper pin bolt.
  5. Pivot the brake caliper body upward and secure out of the way. Do NOT disconnect the hydraulic brake flexible hose from the caliper.
  6. Compress the piston back into the bore using a C-clamp. Figure of brake assembly with caliper raised showing brake pads in mounting bracket gmpc_l4.gif
  7. Remove the inboard and outboard brake pads from the brake caliper bracket.
To Install:
  1. Install the brake pad retainers and both brake pads into the caliper bracket.
  2. Pivot the brake caliper down over the brake pads and into the brake caliper bracket. Insert the lower brake caliper pin bolt and torque bolt to 70 ft-lb. (95 Nm).
  3. Reinstall the tire and wheel assembly.
  4. Lower the vehicle.
  5. Refill the master cylinder. Pump the brake pedal several times to seat the pads against the rotor.
  6. Check the master cylinder level and add fluid as necessary.
Rear To Remove:
  4. Remove the upper caliper mounting bolt.
  5. Pivot the caliper down to access the pads.
  6. Remove the inboard and outboard pads from the caliper bracket.
  7. Remove the brake pad clips from the caliper bracket.
  8. Compress the piston back into the bore using a C-clamp and the old inner pad.
To Install:
  1. Install new brake clips in the caliper bracket.
  2. Install the inboard and outboard pads in the caliper bracket.
  3. Pivot the caliper up over the pads.
  4. Reinstall the upper mounting bolt and tighten to 32 ft. lbs. (44 Nm).
  5. Remove the 2 wheel nuts securing the rotor.
  6. Reinstall the tire and wheel assembly.
  7. Refill the master cylinder. Pump the brake pedal several times to seat the pads against the rotor.
  8. Check the master cylinder level and add fluid as necessary.
Aug 26, 2010 | 2003 Pontiac Grand Prix
My rear wheel shudders and its hard to brake
Rear Wheel problem is most likely bad wheel bearings. When you were tightening these did the Tire Rim Holes have damage?
Wheel Lugs should be tightened to 100 ft-lbs.
Get also a four wheel alignment.
On the Brakes issue: Is there enough brake fluid in the Master Cylinder Reservoir? It sounds like there is air in the system, or incorrect fluid. Did the Brake Fluid level fall below the minimum level at any time in the reservoir? If so there could be air in the Master Cylinder. You can bleed the Master Cyclinder while still on the vehicle. Let me know if you need to do this; I let you know step-by-step.
Is there Brake Fluid leaking anywhere? Check especially on the inside portions of the wheels looking for brake fluid. That leak will have to be fixed first.
Bleed all the brakes. Start at the right rear, then left rear, then right front, then finish with the left front. Use two (2) helpers to do this. One person adding fluid into the Master Cylinder while the other pumps and eventually holds the brake pedal, while you lossen and then tighten down the brake bleeder ports.
Let me know if this helped or if you have additional questions or information. Feel free to contact me at FixYa.com!
Jan 03, 2010 | 1998 Dodge Grand Caravan
No pressure when i press break, slight leak under left rear tire,
1st need to know where the leak is? Is it a rusted line, or? To bleed after repairing leak, do the following: Have a helper start the Jeep, go to the wheel the greatest distance from the master cylinder, have helper pump brake pedal 3 times, pushing down about 1/2 way on pedal each time. 3rd time, he should hold pedal at 1/2 way down point while you open bleeder to let air/fluid out. As flow is about to stop, close bleeder. Repeat til all air removed. Check master cyl and refill often, because if you draw in air, you have to start all over. Go to the next wheel that's now the greatest distance from master cyl, repeat, til you get to wheel closest to master cyl. Done!!
Apr 22, 2009 | 1999 Jeep Cherokee
Fluid leak on rear right side near tire.
if it is sure break fluid. then you have to change break master cylinder, if your car rear wheel drive that might be shaft oil and vibration come from a worn rear wheel bearing.
Jan 17, 2009 | 2003 Ford Crown Victoria
Cycling Logo
69 people viewed this question
Top Cycling Experts
Marvin
Marvin
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
