Question about Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac
Craftmans 24cc model #358795050 will not start Help If it is bad gas what can I do to correct the prolem
Not sure if this will help, but I read on another web site, where a guy unplugged all the portals where the exhaust came out. He claimed this was a common problem for most weed eaters. If the exhaust pressure cannot escape, the thing will not be able to run.
Posted on Jun 28, 2009
  • 1,041 Answers
Does it have fire, (spark)?
Jim
Posted on Jun 19, 2009
  • Jim Parker
    Jim Parker Jun 22, 2009
    Did this solution solve the problem?
    Jim
I can't get it started
Check 1. Compression 2. Gas/oil mix 3. Air filter 4. Spark at spark plug. This is just the beginning of troubleshooting a 2 stroke. They develop fuel line problems and carburetor problems and magneto air-gap problems. Critical though is the oil/gas fuel mix that is used. It needs to be fresh and mixed at the correct ratio. Check all these things that you can and post back.
Dec 14, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Sears Craftman Garage door opener model # 41a3493-1. Does it have auto reverse?
That isn't the model number you give it is the part number for the logic board. The model number is on the opposite end of the motor unit and starts with 139. If you are asking if the opener should reverse when it hits an obstacle the answer is yes. If it doesn't it is not adjusted correctly or is faulty.
Dec 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Poulan pro weedeater will start fine run untill you pick it up then dies
poulan has a bad habit of the fuel breaking inside the tank if it breaks before the fuel filter that makes the fuel line shorter
Nov 05, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Craftman Chainsaw do not run
Extreme Flooding by Dolfoff
Please follow this link, http://www.fixya.com/support/t3226410-no_spark_new_plug_but_continues_flood cursor down to “Best Solution”, while there click the “Was this helpful? [Yes]” button HTH
Lou
Oct 20, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a craftman snow thrower, model#536.886122, serial#632722946 and I'm in need of a manuel.
Manuals of Sears products are available through their 'Parts Direct' system and have been resonable in price. The last one for a riding mower cost ~$7.00
Sep 21, 2009 | Tools & Hardware - Others
Won't start - gas is leaking out
If the gas is leaking out of the carb, then it is most likely flooding and the needle valve possibly is being held open by some stray debris. Carb needs to be removed and checked....possibly even rebuilt as older models require this periodically.
Jul 02, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Fuel lines dry and brittle how to replace on craftman 24cc gas powered blower vac
take one of the lines to a hardware store and see if they have the proper size. You should be able to change them easily. Just remember to clamp the ends to prevent gas from leaking out.
Jun 15, 2009 | Toro Blowers Rake and Vac - Electric...
I have a craftman yard vac with a tecmseh 4.5. She has failed to
Hi gr2954;
Lots of the starting problems with 2 cycle engines (weed eaters, blowers, chain saws, etc) are caused by leaving them stored for long periods of time with the oil/gas mixture left in them. what happens is that a residue forms on parts in the carb.
Try the following: empty the fresh gas out of the blower. add a gas stabilizer to the existing gas you plan to put in the blower. You can get this stabilizer at any auto parts store. While you are there get a can of spray start fluid. Put the fresh, modified gas in the blower. Take the spark out and spray some starter fluid in the plug hole.Replace the spark plug and try to start the engine.It will probably take a few cycles of doing this to get the blower to stay running.
when you put the blower up for a long period, empty the remaining gas out then start the engine and run it till it stops. this gets the remaining gas out of the carb.
Nov 30, 2008 | Garden
Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac Logo
189 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
