Question about Apple iPod nano
The iPod is frozen, reset to factory settings.
Hi I am having problems with my iPod (4GB) Nano. It just froze. I tried to reset it and it gave me an ok signal but now it won't turn on. Right now it is just opening thru itunes. iTunes was initially telling me it needed to prepare my iPod for recovery now it is saying it has detected my ipod but it couldn't be identified properly.
Earlier on it went on, showed me the (apple) showed me it was charging, asked me to reset to factory settings which i did now it just wont switch on. I have held menu and the round button many times
What should I do? Can someone tell me what to do next! Thanx
Mine just had the same problem, it was frozen solid. So, I connected it to my pc, and it said that it needed to be re-formatted, so i went through the steps, and just as it was finishing, it said it could not be ocmpleted. So, I slid the lock switch on the ipod back and forth about 10 times, then at the same time pressed the center button, and the menu button, and it restarted like normal ! I hope this helps you !
Posted on Jun 25, 2009
  • 3 Answers
Try switching LOCK switch on top back and forth a few times and then try to press senter roudn button to turn on. this may help
Posted on Jun 17, 2009
I was playing a song on my ipod nano 4gb and i changed a song and it froze on my and i try to press buttons and its not doing anything. im just wondering what i can do to get ti back working
I would recommend that you attempt to reset your Ipod by pressing and holding both the menu and center buttons for at least ten seconds or until an apple appears. Usually this is the only step needed to resolve a frozen iPod issue, but please do let me know if your issue is not resolved by this step :-)
Jan 17, 2010 | Apple iPod nano
Frozen
Start by reseting it, hold down the "Menu" button and middle button for about 7-8 seconds. This will most likely work, if it doesn't, try restoring it. Do this by first plugging your iPod into your computer and starting iTunes. Then select your iPod in the list to the left, now click the "Restore" button located under the large picture of your iPod model. Restoring will probably take a little while, maybe 10-15 minutes.
Hope this helps!
Sep 15, 2009 | Apple iPod nano
My ipod 4gb wont turn of its frozen?
Hi
Please press the center and stop/pause button until your ipod resets itself or until apple logo appears. Also try to connect your ipod with your computer and restore the ipod settings with itunes.
Please accept the solution and revert for further assistance.
Thanks
Rylee
Jul 07, 2009 | Apple iPod nano
Ipod 2gb is on but completely frozen!
you can try to toggle the hold switch to on (red) then off then press and hold the middle button and the manuel button at the same time untill the apple logo reappears
Mar 25, 2009 | Apple iPod nano
Ipod Nano 4gb - click wheel inop
HI,
Since you hav tried resting the ipod...Also try restoring the ipod and update the software using Itunes and check it...
Feb 02, 2009 | Apple iPod nano
Locked my apple nano ipod and don't know pin number.
Hi All,
First you can try to connect the ipod to your computer and try to update the software using the Itunes and then try to use your ipod... even after updating the software if you r not able to use, the you should restore the ipod to factory settings
Jan 31, 2009 | Apple iPod nano
I forgot my numbers to unlock my ipod 4gb-grey,and need to know
You will have to plug your Ipod into Itunes and restore it to factory settings in order to reset it. Then reload your songs.
Jan 11, 2009 | Apple iPod nano
Ipod nano 4gb is frozen
To user VIVS919, even though you lost the reciept you can call apple at 1-800-APL-CARE (1-800-275-2273) They should replace your iPod under warranty. {Just don't admit to any "accidental" damage}
Oct 16, 2008 | Apple iPod nano
Ipod frozen
Try holding down the play button for about 30 seconds
Hope that helps
Jul 28, 2008 | Apple iPod nano 3rd Generation
My 4gb nano froze up on me can you help me get it unlocked?
ResetTo reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
    Tip:
    • If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
    • If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Apr 01, 2008 | Apple iPod nano
Apple iPod nano Logo
248 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
