Freeze up My AC freezes up & leaks water into my hallway. What causes this?
  • 43 Answers
Icing is usually caused by poor airflow through the evap. coil or low on refrigerant.
Posted on Jun 16, 2009
Stagnant water smell on 2nd floor, not related to bathroom issues.
A leak in the roof perhaps? Dependent on country, but you might have a water tank up there as in the UK?
May 08, 2018 | Refrigerators
Where is the freeze plug located on a 1991 Acura Legend
more info on freeze plug failure? - The Acura Legend & Acura RL Forum
www.acura-legend.com/vbulletin/.../more-info-freeze-plug-failure-1436...
May 29, 2010 - 5 posts - ‎2 authors
my mechanic told me that my freeze plugs could have failed, i have already searched ... Car 1: 1991 Acura Legend ... Car 1: 94 acura legend ls. anti freeze leak
May 11, 2010
Easiest way to
Jul 17, 2007
Manual transmission fluid change help
Apr 7, 2007
engine block heater?
Dec 21, 2003
More results from www.acura-legend.com
Where is the freeze plug located on a 1991 Acura Legend ...
www.fixya.com/cars/t26009696-freeze_plug_located_1991_acura_legend
1 hour ago - where is the freeze plug located on a 1991 Acura Legend - Acura Cars & Trucks question.
Acura Legend leaking freeze plug Questions & Answers ...
Dec 16, 2015 | Acura Cars & Trucks
Could freeze plugs cause my Lincoln navigator 5.4l engaging leak water from back of engine and oil from the side of engine
Yes, that is a possibility. I have a 4-liter V-6 in my 1993 Ford and it had two freeze plugs that had rusted and were leaking. It was easy enough to replace them because they were on the side of the block but I learned there are two freeze plugs hidden under the transmission bell housing. It they are leaking, antifreeze would be dripping off the back of the engine.
Freeze plugs should not cause oil leaks as they are a safety device for the water jacket.
Mar 09, 2015 | Lincoln Cars & Trucks
Why does my Buick Rendevous, 2005, leak water into both front floorboards?
Is it leaking water or Anti Freeze?
If it's Anti Freeze you can pull down the rug or floor mat to check, you should also smell the Anti Freeze. This means your heater core is leaking & has to be replaced, if it's not leaking bad you can try a sealer called Aluma seal (my spelling could be wrong),looks about the size of a roll of dimes, most auto stores have it.
If it's water, my guess is the AC condensation hose is blocked. Does it leak only when the AC is on? this hose runs outside, usually on the
passenger side behind the front wheel, when the AC is on & condensation builds up, you will see water coming out on the ground, this is normal, but if that hose is pinched or blocked the water could end up running onto your floor. Hope this helps.
Sep 08, 2014 | Cars & Trucks
Interior leak
Could be connected - - the drain for the ac could be plugged up and the water is dripping into the passenger compartment. The system may be low on freon or have a restriction in the line which could cause it to freeze up. Could be an air flow problem with the cooling fan too.
Aug 28, 2012 | Cars & Trucks
My 1997 subaru impreza squeals badly and then engine smokes
Hi this sounds weird does the smoke come out from the front engine covers? the squealing could be the cambelt trying to turn a semi or completly ceased waterpump which would cause the smoke after a while, also without the waterpump working properly the engine will leak water and anti freeze out the overflow and overheat really quickly
Apr 22, 2012 | 1997 Subaru Impreza
I have a 2000 Saturn LS1 that is leaking fluid inside my floor board was told it wa smy heater core so had this bypassed, in which the fluid was still leaking & also causing my AC to blow hot air with...
Katrina, you are getting runaround from your "mechanic". You definately need to shop around to reputable mechanic shops.
The clear fluid is condensed (pure) water. To clean out the condensation drain for your AC, use a pipe cleaner available from any tobacco shop, cheap. You need to look at the firewall infront of the passengers feet area for a crinkely short rubber tube, and clean it out with th pipe cleaner. May have to do this from underneath the car. Once you do this the inside will dry out quickly (in your heat with ac to help).
Running the engine without a thermostat will do more damage. The problem is localized overheating in the engine. The coolant moving too fast will cause hot and cold spots in close proximity, which can cause warping and subsequent head gasket leaks. As per DTTECH above. So have brother inlaw install the thermostat, BUT FIRST, perform a radiator flush. Actually flush the whole system. With a hose run water through in both directions through engine and radiator. Possible debris in system from first 2 times opening the thermostat area.
When filling up system, with ready to use antifreeze, look for bubbles in the radiator. Yes there will be bubbles for a while, till the system is really full, but when you cannot get anymore fluid in system, you should not see bubbles. GENTLY rev engine and watch for bubbles that seem to pop with smoke in them. That will indicate a leaking head gasket. Good luck
Jul 09, 2011 | 2000 Saturn L-Series
My AC unit leaks an inordinate amount of water into the apartment. Most of the times it happens when the humidity is high. I have to put rags inder the unit to absorb the water & change the rag after...
Check your air filter, the unit may be freezing up because of not getting enough air...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 06, 2010 | Emerson Quiet Kool 10NW16K Air Conditioner
I hooked a used unit up turned it on and got 3 beep any answers
this indicates that the backup freeze timer terminated the freeze cycle. Stayed in freeze cycle 60 minutes. Causes can be: stuck float switch, water valve leaking incoming water, and the more extreme can be hot gas valve leaking, txv not feed properly, low refrigerant charge, or bad compressor. Usually one of the first 2 items are the root cause.
Aug 21, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Heating & Cooling Logo
46 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
