Looking for a replacement condensate pan for a Carrier Series 28 indoor cooling coils. Original has become brittle and leaks.
  • ziemba1 Jun 16, 2009
    Thank you for your response. Since the a/c unit works fine I'm trying to resolve the leak issue only. I've see various replacement condensate pans online and I thought maybe I could find one for my unit. If in fact I do need to replace the coil can you recommend an appropriate one. Thanks
  • Ken Bledsoe May 11, 2010
    They don't really sell replacement pan's for a coils. Most of the time have to replace the a coil.
    Sergeant:
  • 340 Answers
Local carrier dealer should be able to order will need model and serial #
Posted on Jun 17, 2009
Ice on coils of heat pump not cooling
Which coil?, indoor or out? Indoor coils freeze due to clogged filters, low freon, blower motor not working. Outdoor coil freezing could mean, in rare cases in cooling mode, reversing valve not shifting.
Oct 02, 2013 | Carrier 52CQ-312-4 Comfort Series Heat...
Carrier ductless condensation leak
look at the base of the pan where the hose meets the pan for blockage to the drain
Aug 27, 2012 | Carrier XHB123D X/Y Series Heat/Cool Air...
Where is the drain pan on a carrier weathermaker 8000?
Hello, the drain line will be located under the unit near the condenser coil. Sometimes it can get blocked and the condensate will settle toward the front of the unit and leak from the unit. Also, make sure the unit is tilted back in the window about a 1/4 inch aswell.
Jul 11, 2012 | Carrier XHB123D X/Y Series Heat/Cool Air...
WATER LEAKING FROM GOODMAN UNIT, NO AIR COMING OUT
! shut it down but leave the indoor fan on. check the filters and replace as needed. It also appears the drain is plugged or iced up. If ou can access the indoor coil you can service the drain and run some hot water thru the pan that catches the condensate. If you can see your indoor coil and you see a "lint blanket" on the indoor coil you will have to vacume it off as well. I hope this helps let me know Jon
Aug 05, 2011 | Goodman CLQ36AR49 Air Conditioner
My drain pan is leaking
You need to access the evaporator coil on the inside of your air handler and unplug the drain for the condensate. It should be the 3/4 inch line, if the 1/2 inch line is capped then it is not doing anything and has probably been abandoned.Open up the unit and clean the drip pan and drain hole where the 3/4 line starts. This should clear up your water leak problem.
Also
Water leak due to dust block in air filter,cooling coil,drain pan and blower wheel.
Jun 29, 2011 | Carrier 38CKC060 Air Conditioner
I have eight Carrier AHUs all with carry-over problems from the chilled water cooling coils. Their face velocities are all over 2.5 m/s although the AHUs will be down rated during commsiioning to eliminate...
Most I've seen are made of foam. Such as about an eighth inch thick by 1-2 inch wide, black insulation foam tape. This is between the pans and frame, on the bottom side of the pan, where it sits on the metal frame. Not all coils have this that I've seen.Not sure what you mean by...how the joint is made
Mar 25, 2017 | Carrier Heating & Cooling
Water in the drip pan- what is causing it?
I assume you are talking about the indoor unit. One function of the a/c system is to dehumidify the air. Condensation forms on the cooling coil and runs to the drip pan. There should be a drain line on the drip pan that drains the pan outside. These sometimes become clogged causing the water level in the pan to rise. Try some mild drain cleaner to open the line. Hope this helps. Let me know what you find.
May 21, 2010 | Carrier 38CKC036 Air Conditioner
I have a carrier split unit model#38HDL024311. It's dripping out the front of the unit. When I turn it off, There's a stream of water out the front also.
Where is water dripping? Out the outside unit or inside? Evap. Coils (indoor coils) condense when cooling so it is necessary to have a condensate drain hooked up. If the unit is leaking out of something besides the drain like out of the coil case then you have a blockage in your condesate line either in the drain pan under the coil or somewhere in the line that leads to your drain. blow the line both ways with nitrogen or pull the line out and clean it with a hose.
Jul 29, 2009 | Heating & Cooling
Leaking aircon
THERE IS A TUBE OR CHANEL FROM THE FRONT EVAPORATOR DRAIN PAN THAT RUNS TO THE BACK OF THE UNIT INTO THE CONDENSER PAN. IT IS ALWAYS ADVISABLE TO THOUROUGH LY CLEAN ALL COILS, AND DRAIN PANS AND DRAIN LINES ANUALLY. IF THAT TUBE OR CHANEL WAY GETS PLUGGED IT WILL CONSTANTLY DRIP IN THE COOL MODE.,
IF YOUR A/C IS 110V MOST ALL ARE ABOUT 5,000 - 7,000 BTU''S ALL SHOULD RUN ON A SEPERATE CIRCUIT OR NOT HAVE ANYTHING ELES PLUGED IN ON THAT CIRCUIT.
MOST ALL WINDOW UNITS HAVE THE BTU'S RATING ON THE TAG INSIDE THE UNIT. THESE SMALL UNITS REQUIRE COMPLETE REMOVAL FROM THE WINDOW OR WALL FOR CLEANING. ONLY LARGER UNITS 10,000 AND ABOVE SLIDE OUT OF THE CABINENT FROM THE FRONT.
90% OF A/C I HAVE REPAIRED IN 40+ YEARS WERE DUE TO PLUGGED DRAIN LINES A DIRTY COILS. THEY MUST BE ALL CLEAN BEFORE I COULD START TO DIAGNOSE ANY PROBLEM BECAUSE THE PRESSURES VARY IF THE COILS ARE RESTRICTED WITH DIRT, ETC.
Feb 08, 2008 | Heating & Cooling
Water is filling up in drain pain
My suggestion is to NOT pull the plug on the drain that should be covered with a sign that says...do not remove plug. Water is supposed to be kept in the pan. The interior wheel then helps the water keep the condenser cool....Ron
Sep 22, 2007 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
150 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
