Question about Bosch 24 in. SHU43 Built-in Dishwasher
Our Bosch SHU 4300 dishwasher does not drain fully
Our slightly old but rarely used Bosch SHU 4300 dishwasher does not drain fully after it shuts off. Was looked at twice by local authorized Bosch repair shop ($50 per visit!) who "fixed" it temporarily both times by unsticking the impeller, but the problem reoccurred with the next use.
  • 98 Answers
There is a recall on the control board of many of these models, butyour problem is likely not related. A sticking impeller indicates that the pump may be failing, but you are welcome to try my guide to help. It is here. Thanks!
Posted on Jul 19, 2009
I have a SHU5305us/u12 and my front door lettering got erase. anyone have a picture or a manual that tells me what each button means.
Cycle Interruption
As a safety feature the dishwasher will automatically turn itself off whenever the door is opened. However, if the door is opened quickly while in a wash or rinse cycle some water may splash out of the dishwasher. For this reason it is recommended that the machine always be switched off before opening the door.
To Interrupt a Cycle
1. Press the on/off button to stop operation.
2. Wait at least 10 seconds (or until the water noises stop) before opening the door.
To Resume a Cycle
1. SHU/SHI models, close the door and press the on/off button.
2. SHV models, push the on/off button and close the door.
Changing a Cycle
For Bosch dishwasher models SHI 6800 and 4320, SHU 5300, 5310 and 6800 press the program button of the desired cycle TWICE. For all other Bosch dishwasher models, press the program button of the desired cycle ONCE. The chosen cycle button (or the light above it) becomes illuminated, showing that it has been selected.
* SHU 3030 and SHU 3130 models do not have program lights.
Cancelling a Cycle
Each control panel shows which buttons to simultaneously push to cancel a cycle. Refer to your dishwasher to find the cancel drain buttons on your particular model.
1. Press the indicated buttons at the same time and hold for approximately 3 seconds.
2. When the drain pump noises stop and the LED display or clean light indicate that the end of the cycle has been reached, the dish
washer is reset.
3. Press the on/off button to turn the dishwasher off.
4. The dishwasher is now ready to run a selected cycle. Add more detergent if necessary.
Dado
Oct 05, 2015 | Bosch Dishwashers
Want drain or pump water
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Dec 13, 2010 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Looking for a service manual for Bosch shu 4300 dishwasher
http://kitchen.manualsonline.com/manuals/mfg/bosch/shu_4300.html
Just try out this site.
Nov 28, 2010 | Kitchen Ranges
My Bosch dishwasher stays running in the wash cycle, will not shut down or dry and sanitize the dishes.Checking the fault codes both the power scrub and the reg wash lights flash. Model SHU33A02UC
A solution to this problem would be to sell me your dishwasher. The law firm for which I work is looking to acquire an old unrepaired Bosch SHU 33 dishwasher for some ongoing litigation. If you (or anyone else with this model Bosch) could send me some details regarding your dishwasher, you may be able simply to buy a whole new dishwasher. My email is JFraser -at- jshlawmi.com.
Thanks!
Aug 10, 2010 | Bosch 24 in. SHX33A02 / SHX33A06...
Drain does not fully expell the water
Here is a tip that I wrote that will help you with your problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
May 13, 2010 | Bosch 24 in. SHU6802UC / SHU6806UC...
Impeller is going bad. What will cost to fix on a Bosch shu 9990
Hello there
Normally you will want to get the impeller kit for this it will include the seal for the impeller
Drain & Wash Impeller Kit - Comes with drain & wash impeller, pump seal, chopper, gaskets, screw and instruction sheet.
Part Number: AP3115180
Our Price: $29.00
this is a quote from parts select.com
and is usually a fairly normal price
ok hope this is very helpful for you
Best regards Mike
Jan 06, 2010 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Bosch SHU 43C06 UC17 dishwasher the dishwasher is just draining with no water in the tub, and is not filling, it does not seem to begoing out of drain mode
water in the bottomof the base remove side panel and dry out the bottom base . the float is up . thats why its in drain mode. bosch old tech speaking.
Oct 10, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU 43C02 UC14 Dishwasher
if you have no leaks, leave the machine alone.if you have, thats a different story.you possibly have a flow switch. close your tap slightly so as to reduce water pressure. Less water will be used.{flow switch detects amount of water filled in a determined time}
Jun 03, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
1,032 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
