Question about Necvox RE-8169D 8 All-In-One Motorized System Car Video Player
NECVOX RE-8169DVD ' No Disc' Error Message
DVD Player is giving the 'no disc' error message. Various discs have been tried, they spin, the screen goes black and then reverts back to the original NECVOX screen with the message 'No Disc' in the top left hand corner. Tried disc cleaner but this made no difference.
Any suggestions ?
  • caman Mar 03, 2008
    have the same problem - have cleaned the lens - help !
  • 709 Answers
Hi
I think you can see the lens of the DVD's laser.  If so get some glass cleaner, and a Q-tip.  Dampen one tip of the Q-tip with the glass cleaner and clean the laser lens.  Use the dry end of the Q-tip to dry the lens
Posted on Oct 31, 2007
DVD spinning slow and get a 'No Disc' message
The problem sounds like the spindle motor is about to go out completely. If a disc does not spin or does not spin at it's proper speed the optical lens reading laser can not read the disc and you get a "no disc", or "disc not recognized" error message. On average a dvd will spin 3 times faster than a regular cd will. The following pictures will show you what these components look like.
Check around your local area to find what a service technician will charge to replace the part. On average it will usually cost between $60-90 dollars most of which is labor.
I hope this gives you some idea of what the problem is and how to solve it.
If you would not mind, please rate my help. I would greatly appreciate it. Thank you
Feb 07, 2010 | Televison & Video
Disc error message
Sounds like dirty laser pick up. Try a cd cleaner run through it to clean dust etc off. They can be purchased from any electronic sellers.
Jan 11, 2010 | Zenith Televison & Video
Unknow Disk - Please check disk again ERROR MESSAGE. Have tried previous burn disks the work no problems in the DVD player..... BUT disks I have burn as of today keep coming up with the above error...
The problem is you need to replace the laser assembly if the disc is spinning and not being read, or if the disc isnt spinning, you need to replace the mpeg printed circuit board attached to the laser assembly. Good Luck.
Jul 18, 2009 | GPX PDL805 Portable DVD Player
Getting "Bad Disc" message after Loading message...
If you've had it a long time and used it often, could be the lens is dirty or something wore down and it should be trashed since newer players have more features like usb ports.
Oct 17, 2008 | Astar PD-3060 Portable DVD Player
Error message H07
The spindle motor is defective. Open the cover and see if the disc spins when it loads. If it doesn't, give it a spin in a clockwise direction immediately after loading the disc.
Apr 05, 2008 | Panasonic DVD-RV32 DVD Player
Disk error with Kenwood DV-605 multi-disc DVD player
Try the following
when the error is on the screen, press the number 1 key on the remote, this should take you to the fist chapter of your DVD no matter which region it is
Miguel
Jan 03, 2008 | Kenwood DV-605 Multi-disc DVD Player
Open message when closed/disc wont spin
I figured it out, it was the little plastic sensor stick that tells the unit that the lid is closed therefore reading the disc. cheap piece of plastic that has surely snapped on many a unit. good luck replacing it. i rigged it though problem solved
Sep 16, 2007 | Necvox RE-8169D 8 All-In-One Motorized...
Necvox RE-8169D 8 All-In-One Motorized System Car Video Player Logo
295 people viewed this question
Top Necvox Car Audio & Video Experts
xxxxxx xxx
Are you a Necvox Car Audio and Video Expert? Answer questions, earn points and help others
