Question about Simmons Outdoor AETEC 2.8-10x 44mm WA (2.8-10x44 mm)
I have a Simmons Pro Hunter 4-12x40 AO Serial 7716 that I inherited and the caps on the direction setting in the middle are missing. Do have them so I can replace them?
Programming Simmons 119326c
instructions for simmons prohunter model 119422 camra
Mar 19, 2014 | Simmons 7MP Pro Hunter Trail Camera, Night...
I have a Simmons Model ATV 4515 rifle scope. other
Your scope has 5 adjustments:
1. Eye piece focus - used to focus on the reticle.
2. windage adjustment - should be on the R side of the scope, adjusts lateral impact point.
3. Vertical adjustment - the top turret. Adjusts vertical point of impact.
4. Power ring - adjusts the magnification of the scope.
5. AO ring - Parralax adjustment - used to focus the scope at specific distances. Most markings are not exact, you should set it at the range you are shooting and fine tune focus when you look through the scope.
Sep 06, 2013 | Optics
Have no idea how to set up the sight on my air gun
I don't have this particular model. Chances are, those are not "knobs" but caps. Remove the caps as you would remove the caps from a pill bottle. Underneath, you should find the adjustment dials for windage and elevation,
You can download a generic Simmons scope manual here:
http://www.simmonsoptics.com/downloads/manuals/archive/HSI_Simmons%20Generic%20Scope%20Adjusting%20Instructions.pdf
Apr 04, 2010 | Simmons 511070 4x32 22 MAG Riflescope -...
I inherited a simmons crib, model number 1320 93
My father in-law helped me put it together since he initially put it together 7 years ago.
Dec 31, 2009 | Simmons Mattress Baby Gear
Capacitor wiring on a ao smith M#-C48L2N134B1.
contact A.O Smith they should be able to supply you with a schematic.
Oct 20, 2009 | Pool & Spa
Some of the assembly parts for a Simmons Little folks crib were lost in a move. If I inventory what parts are missing would I be able to purchase new ones?
We do service most of the hardware on Simmons cribs and may be able to help you with the replacement items you need. Please call us when you are with the crib at 800.205.9642 or 800.772.1041 for direct assistance.
Sep 30, 2009 | Simmons Mattress Stockton - Pecan Crib
Simmons model 229060 drop rail is falling out
There should be a couple of little plastic clips (curvy) on the bottom of the rail, last stop before the floor. If one or both are either missing or broken it will simply fall out. Call Simmons directly (www.simmonskids.com for the phone number) and they can sell you the pieces. Mine came in about 3 days and they're very easy to replace.
I hope this helps!
Mar 29, 2009 | Simmons Mattress Venetian 229060-52 Crib
Simmons crib
you've got to be kidding??????????????????????????
Dec 16, 2007 | Pali Katie Crib
Simmons Outdoor AETEC 2.8-10x 44mm WA (2.8-10x44 mm) Logo
731 people viewed this question
Top Simmons Outdoor Optics Experts
Marvin
Marvin
james laughton
james laughton
ray gallant
Are you a Simmons Outdoor Optic Expert? Answer questions, earn points and help others
