Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave sounds like it is working but it does not heat and it smells like hot wires
  • 6,784 Answers
HI, this is a failed Magnetron heating device. replace this part asap if possible. it has failed.
Posted on Jun 15, 2009
I have Danby microwave, the food does not heat and there is smells like some thing is burnt. I have opened it and the high voltage transformer does not look burnt.
What is happening is that the magnetron is shorted, causing the high voltage transformer to overheat. That is what you are smelling is the insulation getting hot. When the magnetron shorts out, it makes a loud buzzing sound. Replacement magnetrons costs almost as much as a new oven so it rarely makes sense to fix.
Mar 09, 2011 | Danby DMW902 Microwave Oven
Our microwave has stopped working for the second time in two years. When you try to heat something, it hums but not quite like it is heating. There is also a funny smell.
SAFTY FIRST
UN -PLUG IT,,,,, THAT "FUNNY SMELL" SOUNDS LIKE IT IS SHORTING OUT
PERHAPS THE MEGATRON HAS GONE BAD, THE MEGATRON IS THE
HEART OF ANY MICROWAVE
AS A EX- FIREMAN, I KNOW FROM FIRST HAND EXPERIENCE THAT
"A FUNNY SMELL " OR " UN-USUALL SMELL COMING FROM AN ELECTRICAL
ITEM IS A SIGN OF DANGER
Feb 05, 2011 | GE Profile Spacemaker JVM1871 Microwave...
Does not heat, hot or burning wire/plastic smell. Louder noise than noise than normal.
Sounds like you have a bad magnetron. Not much worth replacing in these over-the-range microwaves except the fuse. Repair will cost as much as a new one and the high voltage circuit of a m/w is not somewhere I would recommend a DIYer to mess around in.
Dec 28, 2010 | Maytag MMV1153A Microwave Oven
Heat element not working
Well, if there is not heating the food and making a loud buzzing or humming sound when it is on, then the magnetron has failed. It typically shorts out and fails. The magnetron for this cost $140 plus the cost of the service call, you're better off buying a new oven. Hope this helps.
Jul 07, 2010 | Frigidaire FMV156EM Microwave Oven
Heard a pop and then an electrical smell. Unit is working but a faint electrical smell occurs each time unit used. Should I continue using it? It is built in with a trim kit.
No that is a very dangerous situation. What is sounds like is you had a short that blew apart but not completely damaging the wires. You should unplug, and open it if its out of warranty and inspect the wires. If the wires are partially burned it can heat up and cause an electrical fire.
May 19, 2010 | Panasonic NN-S541 Microwave Oven
My microwave is not heating and I smell wire
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
jkllkj
Dec 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Smells like burnt wires
It is very possible it may have burnt wire or burnt capacitor. Remove unit, remove top cover and look inside to see if you see any burn marks or burnt wires. Also check fuse to see if it is good or not.
Aug 07, 2009 | Whirlpool MH1141XM Microwave Oven
Ge spacemaker microwave oven sounds like it is working but is not heating. It also smells like hot wires.
may need an interlock switch, located behind control panel. For otr models, remove the grille and you will find a screw that holds the panel on, remove it and lift up on the panel before pulling out to keep from breaking tabs, switches will be to your left behind the door. for counter models, the case needs to be removed. If there is no sign of scorching at the switches, you may need a magnetron.
Jun 16, 2009 | Microwave Ovens
Was using it last night to heat something up. When almost done, microwave made a zizt type of sound and went off. I turned it back on and it continued cooking, but I started smelling burned plastic or
More common then you think, i have gone through a couple microwaves in the last ten years, they both failed very similar to what you describe. One popped the breaker one day, reset the breaker and it worked again but had an odd smell to it. I took it apart and couldn't find anything burnt or melted so i tossed it and got a new one, i didn't want a microwave burning the house down! I would suggest unless your really tied to that microwave that you just replace it for safety sake. Four years or forty years old don't matter anymore, i had one microwave, LG brand, that died two months after the warranty expired and it would cost more to repair it then replace the thing!
Jan 11, 2018 | Panasonic NN-H964 1200 Watts Microwave...
Motor sounds differently, smells like something is getting hot, won't heat the food
Do you have good air flow coming out of the vents?
If for some reason the cooling fan stopped working, it can cause the magnetron to overheat and be damaged.
If you don't still have your manual, you can download it here:
http://www.geappliances.com/service_and_support/literature/
It will address ventilation issues.
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 06, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
62 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
