Question about HP DeskJet 520 InkJet Printer
Can't get instuctions for my paper feed cleaning kit!
Have an "obsolete" deskjet 520. I also have a paper feed cleaning kit for it that has operating instructions on a floppy disk. My current computer doesn't have a floppy drive! Can anyone help me? (HP couldn't!)
    President:
  • 3,278 Answers
If you don't have a friend whose computer has a floppy disk drive, your local library may have one. Open and print out the instructions or save the file to a USB flash drive. I hope you are talking about a 3.5" floppy, not a 5.25" soft floppy !
Posted on Jun 15, 2009
  • 33 Answers
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry. Keep printer unplugged for about 2 minutes and replug and try a test print. Also make sure that you have waited long enough for the printer to heat up before giving a print job. Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Thanks
Thiru
Intermittent floppy disk drive for Husqvarna Viking Designer 1
These 3.5-inch floppy disk drives are never produced by the manufacturer of the device, but by one of a few floppy disk drive manufacturers (usually Sony) and as such, should your disk drive start to fail, you may be able to disassemble the case of the Viking Designer 1, remove the floppy drive, and insert another standard floppy salvaged from a tower-type PC, thus fixing the problem.
Since 3.5-in. floppy drives are becoming more and more scarce in modern computers (in favor of CD-RW drives) you may have a obsolete tower computer (remember Windows 98?) in your basement (or your friend's basement/yard sale/flea market/www.Craigslist.org/www.eBay.com) that could supply a useable FDD (floppy disk drive).
Oct 04, 2011 | Husqvarna Designer I
When i try to run a disk it says the disk is not formatted do i want to format it now. the disk has information on it so it has to be formatted .
It is possible that there are errors on the floppy disk or the disk was formated using a format that is incompatible with the current operating system. If the disk is readable on another system, the best solution would be to copy the files onto a portable USB flash drive, then reformat the floppy disk using a filesystem that is readable on the desired computer.
Apr 22, 2011 | SmartDisk USB Floppy Drive Titanium...
My TEAC FD-05PUB is recognized by my computer. However, it will not open a floppy disk. It says the disk needs to be formatted (even thought the disk works fine on other computers with the same operating...
Try a brand new disk put something on it and go from there the disk you may be using may be no good anymore. Try this first before getting another replacement disk I would stop using these floppy and go to a USB Stick for storage purposes since they are going obsolete. Just a suggestion! That would solve your problem using floppies for storage besides they do not hold much information compared to todays storage devices. John
Jan 15, 2011 | Teac FD-05PUB External Floppy Drive
A sheet of paper had remain in the cylinder
  1. Remove the rear cleanout from the printer.
  2. Gently remove any jammed paper or bits of paper.
  3. Close the HP Paper Feed Cleaning Kit software on the computer.
  4. Load plain paper in the printer paper tray.
  5. Press the Power button to turn the printer off.
  6. Press the Power button to turn the printer on.
  7. Try printing again. If the printer still does not pick up paper or if a paper jam occurs again, service the printer.
Other solutions customers found helpful » HP Paper Feed Cleaning Kit -- Clean the Paper Feed Rollers with the HP Paper Feed Cleaning Kit in Windows XP and 2000 » HP Deskjet, Photosmart, and PSC All-in-Ones -- 'Out of Paper' Error Message and the Printer Does Not Pick Up or Feed Paper » HP PSC 1600 and 2350 All-in-One Series Printers -- 'Paper jam: Press OK to continue' Message Displays on the All-in-One
Dec 15, 2010 | HP PSC 1610 All-In-One InkJet Printer
Where is the disk drive for a floppy disk located at on the tower
Sorry, but it appears that the EMachines model W3503 does not have a floppy disk drive installed. See this link: http://reviews.cnet.com/desktops/emachines-w3503/1707-3118_7-32178774.html
Floppy disks are obsolete at this point. If you have data on a floppy disk that you wish to retrieve, see about getting help from someone you know who might have one on their computer system, or visit a public library (you might be able to offload the floppy disk contents and e-mail them to yourself).
Most people use USB flash drives now. They are far more reliable and have enormous capacity. Definitely get one if you don't have it. The W3503 computer has several USB ports on it.
May 19, 2010 | E-Machines W3503 PC Desktop
My printer won't feed paper
To resolve the issue please clean the paper feed rollers,you will get the instructions from the link below...
http://h10025.www1.hp.com/ewfrf/wc/document?docname=..........
Apr 11, 2010 | HP DeskJet 882c InkJet Printer
Drive wont read
-is it correctly detected on your operating system.
-if yes please turn your computer of and turn it on after couple of minutes and try again.
-try to find floppy disk cleaning kit and apply it on your device.
-you may try to clean it`s lens using a piece of cotton with spirit.
-do not try to open your computer case if you don`t have knowledge on computers.
Oct 14, 2009 | Teac Floppy Drive 235HG (FD-235HG) Floppy...
What do you mean by insert a disk removable disk
Insert a removable disk, means to place in the appropriate drive one of the the following:
a. floppy diskette
(Usually a 1.4 meg floppy disk) Rapidly becoming obsolete
b. CD disc
c. DVD disc
d. Blu-ray disc
e. Thumb drives
Removable Disk
Also known as removable storage and removable media, a removable disk is a type of media that enables a user to easily move data between computers without having to open their computer.
Hope this helps!
Oct 03, 2009 | Electronics - Others
Wont grip paper on feed, keeps 'saying' paperjam
I have had this problem after printing a large batch of sheets on a heavy matte photo paper. The roller picks up a 'polish' from the surface coating and then fails to grip. I have tried cleaning the roller, with some sucess, but the best solution I have found is to feed through several blank sheets (just page throws in a Word document) of a ordinary 80 gram paper. Doing this between smaller batches of the photo printing seems to keep things flowing.
Jun 24, 2009 | HP Photosmart 2575 All-In-One InkJet...
Hewlett packerd 3310 won't paper feed. You can feed one paper at a time and use the end of a number a small pish stick to help feed it thru the paper tray!
Most likely either the pickup roller or the feed roller is worn, damaged, or excessively dirty.
You need to purchase a "paper feed cleaning kit" either from your regular HP store or from an HP online retailer. Then go here to get the step-by-step procedure. Instructions vary according to your operating system.
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?rule=29302&lc=en&dlc=en&cc=us&lang=en&product=439491
If this does not correct your feed problem, you need an HP certified technician to disassemble the printer and physically examine the parts. They may require replacement.
Mar 25, 2009 | HP Photosmart 3310 All-In-One InkJet...
HP DeskJet 520 InkJet Printer Logo
88 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
