Question about Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
How do i get leaves out of the pool. I've tried using the vacuum but it clogs the filter. And my filter barley even sucks. whats the problem?
  • 93 Answers
First use yor mesh net to remove as many as you can then put your vac head with hose in water take the open end of hose put over pool and use a wet vac on end to get primed remove wet vac as soon as you get water out of vac hose this will save you filter
Posted on Jun 16, 2009
Have you tried to run the vacum while backwashing the pool? If it helps suck up the leaves better then only do it a little at a time because you will taking water from the pool to go out on the ground.Just make sure you have a garden hose hand to replace any lost water...Are you using an earth or sand filter?
Posted on Jun 15, 2009
My 24' above groung pool with a 1.5hp pump and sand filter ssems to be losing prime when i hook up my aqua critter. If i unhook the critter the pump re-primes. Any sugguestions as to why?
Your hose either has a hole in it, at the sections at the waters surface where it is exposed to the air? Even a "Pin" hole will create the symptom you are experiencing.
Or... there is a clog in the unit itself.
It appears that you are either sucking in air, or the water flow is being blocked. The pump should pull water no problem through a vacuum hose or a suction style pool cleaner. If the pump loses prime, then "Water" flow is being restricted either physically are mixing with air.
Aug 13, 2013 | Hayward SAND FILTER, PRO SERIES
I have 7 year old Hayward ProSeries, S-244S, H/R Sand filter. I've notice that when I vacuum the pool, dirty water returns to the pool. I've backwashed and the spider gasket is fine. No sa
sand filters only have limited filtration. If the dirt is very fine such as dead algae, it will go right through the filter. Use a clarifier to help give the filter finer filtration. Do not vacuum until you can see what you are doing, then vacuum on 'waste'
Sep 19, 2012 | Hayward SAND FILTER, PRO SERIES
What is an impeller
the impeller is the most important part of the pump when motor kicks on impeller spins pulling and pushing water through it check to see if it has something glogged in it also try backwashing filter...
May 30, 2012 | Intex 2100 Gph 95 Hp Sand Filter Pump With...
What does my filter need to be set on before i vacuum my pool
For regular vacumming with these Hayward pool filters, you will use the regular filter setting. If you have a very dirty pool or heavy loads of debris, vacuum on the waste setting so that the debris will bypass the filter and not clog or litter it.
May 21, 2011 | Hayward SAND FILTER, PRO SERIES
Vacuum blows out dust/pet hair etc. when in use
try replacing the belt if you havent. it almost sounds like your getting weak aggitation. if thats not bad, check for a clog in the brushroll housing nozzle right on the inside by the tube. Replace the inside hepa filter if you havent within the last 3 months.
Jan 04, 2010 | Hoover U5753-900 WindTunnel Bagless...
Capture bagless not sucking!
Both ends of the hose will unscrew, allowing you to push out hair and fiber clogs with a broomhandle. There is a coarse filter above the dustcup which will release with a 1/4 turn counterclockwise, allowing you to remove the hair and fiber bundles trapped in the inlet. The filter below the dustcup also tends to clog. Anything more and you have to start getting out the hand tools. bgovan445@live.com
Dec 27, 2009 | Eureka 431A Optima Bagless Upright Vacuum
Reduced circulation/backwash (sand filter)
check your pool pump by putting the valve in recirculate mode.If flow is a problem it may be a clogged impeller.
Jul 05, 2009 | Hayward SAND FILTER, PRO SERIES
Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph Logo
183 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Colin Stickland
Colin Stickland
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
