Question about Samsung LN52A550 LCD TV
LN52A550 Samsung TV will not power on
I have a 52" Samsung LCD TV (model # LN52A550) and it will not power on? The red light does not come on or anything. Can this be related to the blown capacitors in the power supply as it is for the other model samsung TVs....
SOURCE: Samsung LCD TV LN40A650 - Service Mode
1. Turn off the TV
2. Press "info" then "Menu" then "mute" and then "Power" on your remote (As fast as possible).
The TV will now start up in Service Mode
Breinholm / Denmark
Posted on May 24, 2008
SOURCE: When I start up my Samsung 52 it has a VERY long delay
Are you retarded? remote batteries? Sounds like your power supply is toast.
Posted on Dec 11, 2009
  • 927 Answers
SOURCE: Samsung model LNT5271f excessive relay cycling before full power
Howdy,
Yes, it is very easy to repair. Solder iron wattage should be at least 300 w.
The PSB is the center Board (towards left) after you remove the back off the TV. Remove the shield that covers the Boards and remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Good Luck, big IRISH.
Posted on Dec 28, 2009
Testimonial: "Great fix"
  • 927 Answers
SOURCE: Which Replacement Power Board for LNT4665F Samsung LCD TV?
Howdy,
It would be a lot cheaper if you just replace the two caps that have gone bad. Just get a cheap solder pencil from the store and about an inch of solder and you are in business.
The Power Supply Board is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thaks for using FIXYA, BIG IRISH.
Posted on Jan 02, 2010
  • 308 Answers
SOURCE: samsung ln40a530 blinking red light, no video
Blinking lights are usually an error code. Do you have a manual that will decode the number of blinks? Its not always the power supply.
Posted on Apr 21, 2010
I have a Samsung LN52A550P3FXZA 52 inch TV. When pressing the power button, the TV clicks for a long period of time but will eventually turn on. Please help with any solutions. Thanks!
You likely have a power supply capacitor(s) that has gone bad. This is an easy fix, and I suggest you search youtube for "samsung capacitor" and you should get some good videos how to repair it if you can solder. If not, any friend who can solder can probably help you repair this with a couple dollars worth of parts form Radio Shack.
Dec 26, 2010 | Samsung LN52A550 LCD TV
Samsung 52" LN52A550... tv makes clicking sounds, and won't turn on! HELP
This is a known problem due to the bad capacitor(s) on its power board. Samsung will fix it for free. If you want to fix it yourself, go to Youtube and search for "Samsung clicking"...
Aug 18, 2010 | Samsung LN52A550 LCD TV
Watching ln52a550 and picture went blank. Hooked 32" samsung up and everything works fine. Anything I should do before contacting warranty service?
This model has had problems with electrolytic capacitors on the power supply which will cause your problem. I've fixed several of them by replacing these caps. The caps will most likely be bulged or mushroomed on top if they are bad. This is the most common problem that I have found on this model.
If it is in warranty, then I would just contact Samsung and they will send a tech out and he will fix it for you at no cost.
Jul 30, 2010 | Samsung LN52A550 LCD TV
My Samsung LN52A550 LCD TV will not stay on.
The ticking noise usually comes from the power section of the tv. Usually it is a capacitor failing. As far as the cost of repair this can go either way ie cheap or expensive. It will dpend on what exactly has failed and if it requires a board replacement or just a part.
I'm going to assume this isn't under warrenty anymore. It is covered if it is. You need to get some repair estimates from Samsung and any tv repair shops. Then keep and eye out for a replacement. Make sure you include any shipping costs or other costs when you are totaling up the estimates. If it gets close to the replacement cost then you will have to choose if you want a new tv or have a repair done.
Jul 07, 2010 | Samsung LN52A550 LCD TV
My samsung t.v. 52 inches will not come on it
My tv is brand new samsung 32 inches lcd. I accidently press power button several times and now i dont see any red dot. when I use my remote control, i see red dot but thats all
Jun 19, 2010 | Samsung LN52A850 52 in. LCD HDTV
Fried Cable Box and TV not working
hi first call you cable company and let them that your cable box cought firer then call samsung cause you have a year if anything happens just know that you may have to pay for repairs
Jan 09, 2009 | Samsung LN52A550 LCD TV
My samsung 52" flat lcd hd tv
yours DLP TV not a LCD.
LCD has on one light with red.
If the DLP likes that.
1st -- check the thermostat
2nd -- check the power board.
Jun 10, 2008 | Samsung 52 in. LCD Flat-Panel HDTV
Samsung LN52A550 LCD TV Logo
122 people viewed this question
Jerry Greenberg
Jerry Greenberg
