Question about Black & Decker Drills
A friend of mine droped his 18v drill and the front of it fell apart with the gears in it and now he wants to put it back together. maybe with blue prints?
    Sergeant:
  • 384 Answers
Sounds like he broke the tool case and can not be fixed..
Posted on Jun 16, 2009
Gears fell out.took apart to replace balleries. can not put the gears back
The gear box of cordless tools is generally and comparatively simple. If you are sure all the parts are present I suggest you engage a member of the family who has the tenacity for jigsaw puzzles to assemble it.
Jun 26, 2015 | Drills
Craftsman drill model 315
If it just fell apart the do not waste your time putting it back together as it will only fall apart again when you are working. Just get a new chuck.
Jun 28, 2013 | Drills
Drill fell and broke now trying to put it back together gears and all,require help
Unfortunately on that model they do not service any of the transmission parts separately so there is no exploded view. Here is the parts diagram. You may end up having to buy a new trans assembly.
DeWalt DC987K diagram
Aug 10, 2012 | Dewalt DC988kar XRP 3 - speed 1/2" 18v...
I have to bang the bottom of the battery yo make the drill work
could be loose prongs on batt. or drill,take off battery and see if prongs wiggle with your finger.had problem before was trigger though.voids warrenty if you take apart to try to fix.Very hard to put back together properly
Oct 07, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
I have 3 of these and all of them have a problem after a while that they slip the clutch even when it is selected to the drill position, can the clutch be adjusted?
I just took mine apart and it appears that you have to replace the entire transmission. It is an easy job and the part is about $34 much cheaper than a new drill. Really, it is one third the price of a battery. Just take the 4 screws out that hold the metal case to the plastic clamshells, slide the front of the drill off, pull the transmission out of the rear of the drill put the plastic piece with the gear indicator on the new trans, if needed, slide the new trans into place, spin the motor if needed to get the output to line up with the planetary gears, slide the front of the drill back into place, rotate the chuck to align the shaft  with the transmission output, put the 4 screws back in, enjoy.
Might want to replace the brushes while you are in there as well. I am going to consider this the dewalt version of an oil change
Dec 29, 2009 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Tool will not function, led flickers by trigger when attemting to use.
There is something making the motor turbine stick, i just fixed mine that was doing the same thing.
Remove the four screws holding the clutch/driver assembly on the top/front.
Use a pliers to rotate the motor gear shaft in the center of the shell until it moves freely, being careful not to damage the gear. mine was sticking in one spot so i just rotated it back and forth until it worked itself loose. There is most likely metal shavings or dirt clogging it and preventing it from rotating. I would clean any debris from inside before putting it back together and grease the moving parts if needed.
Attach a charged battery and pull the trigger in foreward and reverse positions to see if the drill works ok. Mine works like a charm now. One of my batteries is shot though, not sure if it had anything to do with the stuck motor turbine.
Dec 05, 2009 | Milwaukee Tool Milwaukee 2601 22 18V Li...
Need diagram to reinstall tranny fell apart when for dc988
http://www.ereplacementparts.com/
Try this place, one of the sites I use for documentation.
Nov 14, 2009 | Dewalt 18 Volt Dc988 Hammer Drill,dc825...
How to put my drill back together
I would recommend going to Dewaltservicenet.com and typing in your model number to get a parts explosion. If you get that and still have problems let me know along with the model number and I will try and help
Jul 28, 2009 | Dewalt 18V Compact Drill/Driver and Impact...
Fell apart!!
the transmission comes in assy. all u can do is to match the gear & test every small installed. if it's dw997 see www.erplacementparts.com for your guide how to re-assemble.
if dw988 trans diagram see similarity on how to put it back.
Aug 16, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Gears
u did see what model but see www.ereplacementparts.com might help you
Jul 05, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Drills Logo
73 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
