Question about Canon MultiPASS F50 All-In-One InkJet Printer
Check document error when I try to fax a document
I get a check document error when I try to fax a document. No problem recieving faxes, just cannot send them.
    President:
  • 2,306 Answers
You should try a copy to see if it prints OK, when the scanner goes out you sometimes get a black page and your fax machine knows it looks like way too much data.
Posted on Aug 13, 2009
We have a HP 1050 fax machine. Usually when we send something, it displays send ECM and the number of pages. Occasionally it displays send G3 and the number of pages. I can't find anywhere in the user...
this is just the transition speed and line condition and you dont have to worry about it , the machine will give you an error code if the faxes dont go through alturnativly contact the reciever of the fax to check that they have recieved it
G3 means poor line condition
Apr 09, 2010 | HP 1050 Plain Paper Inkjet Fax
CANT RECIEVE A FAX,from hp officejet v series BUT COULD SENDone
follow the document from te below link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01669610&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=441125&lang=en
and i think this should work for you ............... any further assistance let me know i will surely try my best to help you ................ thank you
HAMID
Oct 20, 2009 | HP Officejet 5610 All-In-One InkJet...
Same problem
press the setup button and scroll down to tools.
in tools there should be an option that says run fax test.
that would give you a printed page as to which part of the hardware of the printer or the fax line failed.
What your error code means is(look below)
Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Jun 18, 2009 | HP OfficeJet K80 All-In-One InkJet Printer
Sending fax
If you sending the fax over the memory, fax can scann doc. while dialing, or in the same time, but if you sending directly (on-hook dial) fax is sending the document while beeing reeded.
You may try to check the phone lines, browse the documents before sending,clean the original document feed rollers,...
if fax sudenly stops and wrinkle the orig. documents there is problem in scanner area
Jan 16, 2009 | Canon FAX-JX200
CHECK CARTRIDGE
when trying to copy or receive a fax machine will flash printer error and send out blank page i replaced the ink cartridge and blue air tho it but nothing seems to help
Oct 03, 2008 | Sharp INKJET FAX UX-A1000
Send Fax Issue
I have a brother intellifax 770 and I bought it used so their for I do not have the owners manual and I am having trouble setting it up and getting it to work. I can fax out but I just can't recieve faxes I can fax my daughter but when she faxes me she gets an error of 388 but she is able to fax and recieve faxes so we know her end is not the problem.
Aug 20, 2008 | Brother IntelliFAX 4100 Laser Fax
Intellifax 775
Lift up the document feeder (where the keypad is) and look for something blocking the paper path.
Jun 19, 2008 | Brother IntelliFax-2820 Laser Fax
Can not transmit faxes
do you have a seperate fax line? if so check the fax line.
also in the fax menu set up your fax to phone/fax mode, and set up all your fax info.
if you have distinq ring you need to set up your # of rings.
Feb 22, 2008 | Canon FAXPHONE L170 Plain Paper Laser
Canon fax 2060P not recieving faxes
It seems that the protocol is failing. Just check, by printing a receive report. If there are errors it is after the check frame. If no errors, it is failing before the check frame. In either case, 1st aid is to listen using a handset for noise or static on the line. If the line is clear, then you will have to call service to change the tx/rx attenuation.
Dec 06, 2007 | Canon LaserClass 2060P Plain Paper Fax
Can't recieve a fax
i have fax L100 ,i can send a fax but i cant recevie a fax error is communication error (003F)
Oct 24, 2007 | Canon FAX L-120 Plain Paper Laser
Canon MultiPASS F50 All-In-One InkJet Printer Logo
159 people viewed this question
old marine
old marine
