Question about Video Game Consoles & Games
I have a playstation 3 via TV. I'm not getting sound. I checked the TV remote control to see if the "mute" was on by accident...it was not. I double checked the connections....still no sound.
  • 13,433 Answers
Depending on what it is connected now, try another way of connecting it. also note that playstation 3 doesn't automatically adjust what connection it gives signal on, so you will have to connect the cables and then use the old cable to go into the settings and change the output from hdmi to svideo for example.
if I remember right pressing the power button for 30 seconds should cause the console to reset the setting and beep.
please try another way of connecting it.
Posted on Jun 15, 2009
How do I restore sound on my tv ?
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Aug 10, 2015 | Televison & Video
Why no sound?
http://electro-medical.blogspot.com/
May 15, 2015 | Televison & Video
I accidently changed my tv channel i have dish how do i get my dish back
Meshell Coles,
I would be happy to help get this fixed! If the TV is connected via a Coax cable, try changing it to 3 or 4 if TV1. If it is TV2 try 60 or 73. If the receiver is connected via a RCA (Red, Yellow, White) cable, HDMI cable, or Component (YPbPr), make sure the receiver is on the correct input.
If you have any other questions, just let me know!
Tommy Faust
DISH Social Media Representative
Sep 02, 2012 | DISH Network Televison & Video
No sound on tv but volume is up
If you have an older style television and you have cable-then you have 2 remotes-somehow,the tv part went on mute but when you check your sound with the cable remote-it shows high level of bars which makes for confusion!Get out the old tv remote &select your menu then sound &take it off mute----You'll probably see see--sound off! Turn sound on and adjust your sound bars with same tv remote till just a bit more than 1/2 way up.That way you will not have to use cable remote to make it louder-much.In case,you forgot where you put your tv remote& only have cable one--think you can still get it off mute--byshutting down the cable part(which you have probably done several Xs by accident)---and then with cable light not coming on-right- only the tv light =try & adjust with cable remote by pressing mute button-should see MUTE go off!Then bring your cable button back into play and should be all set to go.If that does'nt work and your tv is still a tube tv might need a new part.But hope it was the simple problem.& that I managed to help you.Bye.
Aug 17, 2012 | Televison & Video
My samsung smart tv shows a mute indicator that just kills the sound but the only way to get it back is to unplug the att pvr and wait 4-5 minutes
this not a problem coming from Remote control, this a problem from yuoTV smart.contact your supplier TV, and get touch ONLINE help via chat.
God bless you
Jul 02, 2012 | Logitech Harmony One Advanced Universal...
No sound coming from TV....recently relocated and ran TV from cable box, have lost remote to TV and now cannot get sound to work...picture good just cant get sound?
I think you are muting the the remote before you relocated...you need a remote to un-mute the sound of your TV...this cannot be done using the volume control in your TV unless you have the remote...if you loss the remote...buy a universal remote control
Sep 21, 2011 | Fujitsu Plasmavision P42VCA30EH 42 in....
Adding remote control activated ''mute'' to TV headphone jack
Generally when the head phone jack is inserted the speakers will get disconnected automatically.
If you are going to use external amplifier you can try the AV sockets. Opening the TV you may require the special screw drivers some times.
Jul 07, 2010 | Televison & Video
Was trying to mute the sound on tv when I accidentally hit another button. The t.v turned to snow and caption read to press SAT button. I pressed it and all I got was snow and no sat. reception. Can you...
If your recvr connect to tv via coax then put your tv on chan. 3 or 4 to reagin pic, if it a tv 2 location try cahn's 22 60 or 73 or run a auto program or auto tune.
Oct 10, 2009 | DISH Network IR Remote Control
No volume on my Samsung 50" flat screen
Go check up the settings. First disconnect all appliances and then reconnect when power off. Configure connection when power on.
See your manual. You use the analog tuner or digital cable or satelte receiver to watch TV. If external digital decoder check your settings there. They are independend and might be low or muted sound level or incorrect setting.
Apr 14, 2009 | LG 42LC2D 42 in. LCD HDTV
Whats the tv remote code if i have a direct tv + remote.
The Directv remote isn't capable of fully emulating the native remote of the Symphonic Combo. You can get limited functionality though.
1. Move Remote slider to "AV1" position.
2. Hold down mute and select until you get 2 flashes of the green light, then release both keys.
3. Enter 20821 and observe 2 more flashes of the green light.
Next lock the volume controls to this device.
4. If you have moved the remote's slider from the AV1 position, move it back. The slider should remain on AV1.
5. Hold down mute and select until you get 2 flashes then release both keys.
6. Enter 993 and observe 2 flashes.
7. Press and release THE SELECT KEY and observe 2 more flashes.
You can control the TV's power using the big power button under the device selector.
Oct 23, 2007 | Symphonic WF20D4 TV
Video Game Consoles & Games Logo
16 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
