Question about Dryers
Loud noise After turning dryer on it makes a huge loud roaring noise. Panels have been pulled off and couldn't figure out where it is coming from specifically.
  • 744 Answers
OK, not too sure about this, but...about the only thing that will make a dryer make the sound you describe is a diconnected vent pipe or a problem with the vent fan. Check to see if the vent pipe is connected first.
Posted on Jun 15, 2009
I have a 2001 Chevy Malibu. There is a loud roaring noise around the vacinity of the front driver's side wheel (it sounds like from the inside) the more speed you pick up the louder it gets. We have...
Might be the backing plate is touching brake rotor, have it checked and if plate is too close to rotor pull it away , it will make huge noise while driving, make sure about that.
Oct 11, 2013 | Chevrolet Cars & Trucks
Dryer is making a loud roaring noise when on but still works fine
Hmp..Maybe there's a part of the dryer need to be fixed.. Make sure to contact the service provider of that product,,k
Jul 15, 2012 | Kenmore 800 7982 Dryer
Dryer is making a loud roaring noise. Drum still is turning and clothes dried. But noise is getting louder.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Dec 14, 2010 | Kenmore Dryers
We have a Frigidaire FER211AS2 dryer that started making a loud humming/roaring noise. Hubs replaced the bearing and drum belt. The noise isn't quite as bad but it still makes the same noise. What could it...
Check the alignment of the belt. Humming/roaring noise usually comes from a bearing, so your husband got it right to change the bearing and belt.
Now, he just needs to make sure that the belt is aligned right and the bearing is properly seated. Also check for rubbing marks around the travel area of the drum.
Oct 09, 2009 | Dryers
Hi, my GE model DBXR463ED1WW dryer is LOUD!
Roaring could be an over firing burner or fan related. Squeak or rumbles are bearings. Is the noise all the time or only when the burner is on? Eric
Jun 20, 2009 | GE DBXR463EBWW Electric Dryer
Loud Roaring Noise
This sounds like a noisy wheel bearing, they really can get loud, but quite when u turn because the weight comes off the wheel..
Mar 19, 2009 | 2002 Chevrolet Cavalier Coupe
Kenmore dryer makes roaring oise when the drum turns
I have the same problem. I thought originally it was the seal around the drum but we pinpointed it to the fan motor. We think there is something wrapped around the fan motor or the bearings is going out.We would have to take everything out the drum and belt and motor to get to the problem. If you take the back panel off and take the lint trap off you can turn the fan and you can hear the loud noise. We tried spraying wd-40 around the fan pin but don't get any on the motor. It will burn it up if you do that. But it didn't work so you will have to take everything out.
Feb 01, 2009 | Kenmore 62602 Electric Dryer
Roaring Sound During Operation of Dryer
Does the roaring sound occur after the machine warms up? If so, it could be a bad drum bearing. the heat from the dryer causes it to expand in its housing and, since it may been defective, could start "roaring". If so, The dryer drum shaft/bearing assembly will need to be replaced
If however, the roaring is immediate upon start up then u may have a bearing in your dryer motor. The entire motor may have to be replaced.
Dec 07, 2008 | Whirlpool LER4634J Electric Dryer
Loud roaring noise
jack up front of car get hold of tyre an see if u get any play if u do u may get away with nipping them up a bit
Nov 19, 2008 | 1999 Mitsubishi Galant
Dryers Logo
96 people viewed this question
Top Dryers Experts
Marvin
Marvin
