Question about Samsung SCH-a930 Cellular Phone
Keeps entering and leave service area
My phone took an unfortunate trip in a toilet, hit the side pretty hard. I quickly got it out removed the battery and dried it. left it for a day for water to get out. When i first turned it on it could not find service. After removing the battery a few times the phone now enters service area and then leaves it quickly. Within 30 seconds it will enter and leave service area. I can not receive or make calls with it like this.
  • 35 Answers
You need to replace the circuit board or if possible replace the micro antena located on the circuit bored so i suggest u find yout nearest cell tech. and have it checked out and replaced
Posted on Jun 15, 2009
Keep getting pop up that says..unfortunately, google play services has stopped. also unfortunately, the process com.google.process.gapps has stopped.
Hi John,
Try this...
Go to Settings menu->Scroll to Applications->Manage applications->Open All tab->Scroll down an find Google Play store->Click Open play store->Clear data, clear cache and uninstall updates.
Feb 29, 2016 | LG Cell Phones
Leaking water at bottom centre both sides atbottom of base
call a good plumber your wax seal has gone the trip
Apr 13, 2015 | Home
My mothers toilet will not flush, its like theres no suction, when flushed the water in the bowl goes down very slowly but not all the way down to the hole and when it does its very slow weak suction. I...
Try getting a bucket full of water and dumping it pretty rapidly into the toilet bowl. This is essentially what happens when the toilet is flushed normally, but it removes the variable of how the water is being delivered from the tank to the bowl. It should swirl and go charging down the drain, quickly leaving the bowl with very little water. If it does not act that way, then problem is definitely that the drain is obstructed. When you snaked it, you probably used a fairly short snake (about 10 feet?). Try a plunger - use a good one not the kind designed for sinks. Flush multiple times and get vigorous with it. If that doesn't clear it you will have to remove the toilet and use a much larger and longer snake (50 ft or more). good luck, Al K
Dec 31, 2010 | Home
Razr phone just fell out of back pocket into toilet. I took of back cover & removed battery. What next?
Dry the phone, battery, sim card, etc. with cloth and wrap each piece, phone and accessories, in newspaper. Place a few handfuls of rice into a plastic bag and then place the wrapped phone in the bag with rice. The newspaper wrapping avoids direct contact of rice with your phone because the dust from the rice can get into the small areas of the phone. The newspaper and rice will absorb moisture. Leave it there (with the bag open) at least 24 hrs.
May 19, 2010 | Motorola Mobility RAZR V3
The toilet comes with a hard body flapper which utilizes a pretty straight-forward gasket. The gasket material failed within 3 months. The Korky that I purchased will not function properly. Impossible to...
We have just recently purchased one of the American standard cadet at home depot from a discount flyer and had it for about a day and took it back.
We Did not notice Any thing like a strong flush.
RECOMENDATION:
Take it back.
Home Depot sells a Kohler Toilet 1.6 Gallon Flush Install
This is all it said it was. It saves water for sure and has a quick flush.
We liked it so much we purchased two of them because everyone in the house only wanted to using our bathroom.
Hope this tip helps
David
Feb 21, 2010 | Eljer TOILET RND IN BOX WHT -...
Hi i'm pretty sure my son has just flushed a baby wipe down the toilet and now my saniflo is making strange noises and doesn't appear to be working properly, how can i check if the wipe has become tangled...
Hi, Had this myself with my son a while back!
*** STEP 1 ... DISCONNECT THE MAINS POWER SUPPLY!!!! ***
You'll need to drain the main toilet bowl of water and remove the toilet bowl away from the sanoflo. This may require that you also empty the cistern and stop the water from entering it (do you have an inline valve to the cistern supply pipe?)
When you have emptied the water and removed the toilet bowl there should be a large Jubilee clip attaching the saniflow to the WC waste outlet. Loosten this and remove it so you can see into the saniflo where the WC waste goes.
You should be able to see the object and reach it with your hands. I would suggest wearing some rubber gloves to protect your hands from getting gunk in cuts etc.
If you cannot get to the object, you'll need to empty out the other pipes to the Saniflo and remove the unit. When you have done this you'll need a star driver to open up the unit and get to the object inside. I would suggest that since most of the saniflo range have an internal grille to stop objects such as this actually hitting the macerator that you should be able to reach it just by disconnecting the WC waste connection
If this helps please leave feedback
Feb 08, 2010 | Saniflo 013/003/005 Sanibest Toilet with...
Keys Not Working after Water
there is an area under the track ball that goes bad if it get's wet. Cleaning that area with a brush can sometime get it up and running again. If you're out of warranty try to remove the trackball and clean the area below it if necessary. There is a Blackberry Repair Guide that shows how to open a Blackberry and remove the track ball yourself.
May 28, 2009 | RIM BlackBerry? Pearl 8120 Cellular Phone
Toilet keeps flushing itself, its is a bemis toilet. its been doing it since i put sum of that bloo stuff you get although i took it out straightaway.
Replace the flapper. It seem to have been damaged. It that does not cure the problem by itself you may have to replace the flapper seat also.
Jan 15, 2009 | Home
Plz help with chocolate phone
there is problem in u r mobile , now u have contact lg care center
Oct 27, 2007 | LG CHOCOLATE VX8500 Cellular Phone
Samsung SCH-a930 Cellular Phone Logo
326 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
