Question about Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
My lawnboy 10304 runs about one minute and shuts down. Any ideas?
It starts easily. runs about one minute and stops. Will not stop unless I prime the second start. Will run less that a minute and stop again. I hace fresh gas with 32-1 mix.I assume I have a fuel flow or carb problem. Your thoughts please.
  • Anonymous Mar 31, 2014
    lawnboy run great for awhile then shuts down after it cools it will start then work for awhile the shut down again
  • 3 Answers
It sounds like it is 2 stroke.
Carefully remove the carb bowl, by undoing the brass bolt.
Examine the brass bolt for a small pin-hole in the side.
Use a piece of corn-broom NEVER anything else !!! and poke the hole(S) to make sure they are clear.
Blow out with air if available.
You can use this method to clean out all the carb orifices carefully.
Hope it helps,
Andy.
Posted on Jul 16, 2009
Don't worry William, your gas mix is correct, the older lawnboys were gas/oil mix at a 32:1 ratio. Have you cleaned your air filter, take some of your mixed gas and put it into a can, and soak the air filter for a few minutes, then swish it around and kinda of ring it out. That was my problem before. Besides that, I am not sure what else to tell you. Hope that works.
Posted on Jul 05, 2009
    Problem Solver:
  • 15 Answers
Change the primer bulb it got a air leak
Posted on Jul 17, 2012
    Problem Solver:
  • 12 Answers
Are you saying that your mower has a 32 to 1 mix of oil and gas? if you are it should be a 4 cycle motor, because push mower motors are normally 4 cycles and you don't have to mix the fuel and oil together for a 4 cycle motor. there should be a separate place to put the oil from the gas.
Posted on Jun 15, 2009
  • 2 stroke Jun 10, 2011
    of course its a 2 cycle. Lawn Boys were famous for thier 2 cycles
Hi My 2005 Same Dorado 85 Tractor. It starts from cold easily first time around. But once the engine has been running for several minutes it stops.
sounds like you could have a coolant temp sensor issue. If it senses the engine temperature higher than it actually is, it will tell the engine computer to shut down.
Also I'm not showing an 05 Eldorado, if you could give the correct information for your car, it would be very helpful
Feb 15, 2017 | Cars & Trucks
My lawnboy push mower was running and then suddenly stopped and won't start back
check to see if the spark plug is getting spark. prime the carburetor to see if you have a fuel problem. does it have fuel in it? if it starts back up after it cools off change the spark plug
May 30, 2016 | Garden
My lawnboy runs for one minute then shuts down, wait a minute and it starts up again
try and run it with the gas cap loose the vent might be plugged
Jun 08, 2012 | Garden
Briggs and Stratton
clogged fuel line. the choke restricts air flow if it runs fine choked it is probably getting too much air to run properly. those 2 seconds it is most likely running off a surplus of fuel from priming or something of that sort.
Check fuel lines and fuel filter for obstructions. I reccomend replacing fuel filter also. If this does not help is may be a fuel issue in the carburetor.
Feb 08, 2012 | Garden
I PUT A POTATO IN FOR 6 MIN. AND AFTER ABOUT 2 MIN. IT SHUTS DOWN AND A MIN OR SO LATER IT STARTS UP AGAIN ,BUT THE TIME STILL COUNTS DOWN AND THE TURNTABLE IS STILL TURNING, AND YESTERDAY I HAD TO UNPLUG...
it sounds like it is overheating. but if only stops for a minute or so dont know if that would be enough time to cool off.When you start it up can you hear the fan running? does it keep running when it shuts down? if it's not running then thats the problem If the fan is running and shuts down when it shuts down then try shaking the door when you start it up the next time or you can try it the first time just to eliminate it being a faulty interlock switch. let me know about what you find about these two ideas.
Sep 02, 2009 | Sanyo Microwave Ovens
I have a 1987 commercial lawnboy walk behind mower that has stopped running. I gradually lost power over the summer and now it will not start. I have installed a new plug and filter earlier in the spring....
I would try and remove carb and clean it thuroughly. You can soak the parts in solvent or equivelant. The carb would be right after the air filter tube to the intake of engine.
Aug 25, 2009 | Garden
2001 Lincoln LS Cruise Control stopped working
could be the module behind the airbag
Jun 26, 2009 | 2001 Lincoln LS
1997 golf cl 1.8 L Starts ok then dies. ok above 1900 rpm
Sounds like censor issues. Have diagnostics run on the vehicle to find the culprit.
Apr 25, 2009 | 1997 Volkswagen Golf
Unit shuts down and restarts for no reason
check all cables ide connectors .the problem may lie in the processor loose hsf or broken pins.if not irregular power supply .
Nov 26, 2007 | Gigabyte Giga-Byte: GA-8VM800M-775...
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series -  Sens - A - Speed Walk Behind Mower - 10685 Logo
1,891 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
Jim Parker
Jim Parker
lnbn1975
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
