Question about Sony Cyber-shot DSC-W55 Digital Camera
When I turn on my DSC W55 the lens does not open all the way. Is better to fix it or buy a new camera?
    Novelist:
  • 107 Answers
It usually cost more to repair digital cameras than investing in a brand new one. Before you decide to trash your camera and buy a new one try this.
Some dirt somhow gets on the outside of the lense and they would prevent the lense from opening or closing 100% as it normally does.
Clean around the lense and turn your camera off and on a few times. If the lense opened out 100%, you should be able to take pictures as you usually did. If NOT
turn on the camera and help the lense to open up by pulling the lense out NOT too hard. If the lense goes up and down you follow the lense motion (up and down and turn). If the lense opened up 100%, then turn the camera on and off a few times, it may work now.
If you have dropped the camera, some mechanical part of the lense mechanism is broken or disslocated. In that case, the lense has to be opend from the camera, inspect for broken parts or loose parts, and clean it up. If you put it back on the camera, it may work. Remember opening the lense is the absolute last thing you want to do. Most likely, you would make it worse than, before opening it.
If you decided to buy a new one and trash this camera, please send the camera to me. I will pay to you ONLY your shipping cost. I would try to fix it and learn more about the problem your lense have. I would be able to help the next person with the same problem better. my email address pourmp@yahoo.com.
GOOD LUCK !!!!!!!!!!!
Posted on Jun 15, 2009
My Sony cybershot dsc-w55 won't take pictures! I
Your lens is stuck due to either being banged or bumped or there is dirt/grit inside the lens gears. The lens needs to be replaced, but buying a brand new lens is out of the question. Sony will charge $125 just for the lens assembly, it's crazy.
A refurb lens can be installed for about $75 including return shipping. You should check the replacement cost of a used camera and see which is cheaper in the long run.
Hope this helps!
Thomas Drayton
Owner, Darntoothysam.com Digital Camera Repair
Jul 25, 2011 | Sony Cameras
Hi I have a sony cybershot DSC W55 BIG PROBLEM
if you have guarantee change the lcd screen .. it is quite easier.. but the cost for changing is nearly 3/4 of the camera so better buy a new camera..
May 30, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
DSC-WW220 CAMERA LENS IS NOT GETTING OPENED ,whenver i open lens comes out later it gets in and on screen it dispalys to do on and off
Its problem in lens.There is one part its called sensor it fix on lens it need to be clean.After cleaning your camera will work properly & there will no massage Turn the power off and on again
Feb 26, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
When using camera, the lens will not come completely open or clos
You have broken last (black) gear in opening/closing mechanism. Common problem. Need new gear or fix missing "tooth".
Sep 19, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Camera lens doesn't open- message turn the power off and on again
Dropping it may have damaged the lens barrel. You probably need service.
Aug 12, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Lens does not work..how much for a new one sony cybershot dsc-w55
DSC-W55 requires lens assembly under following part number..
1-788-363-12 Optics Unit (ED13A)Above part is available in Part Store for $73
Mar 06, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Twisting the lens on the Sony DSC W55
hi there
take the end furthest from the camera and twist to the left then the right very gently and pul gently also do not force it you must be carefull with it. it is usually just grease or dit trapped inside the movement
Sep 18, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Sony cypershot DSC-W55 keeps giving message to turn on and turn off again. Seem like the lens isn't working
i acutally used to sell this camera all the time. this usually happends when the gears that allow the lens to come in and out are either damaged or not lined up. you're gonna have to put it up for surgery either through sony or a local camera shop. with newer and cheaper camera technology out there combined with high labor costs and camera parts, youre better off buying something else.
Sep 12, 2008 | Cameras
Sony dsc-w55 fell and the lens is stuck
Use bit more force to push or pull the lens as lens has been damaged. If applying bit more force lens goes to working, u saved $$$ otherwise, new lens option is always available at Sony repair shops.
May 30, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
148 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
