Question about Premier MP4 Digital Media Player
Accidentally changed language
I accidentally changed the language on my Premier MP4 to some kind of chinese.   How far down do I find English so I can change it back.
Re: Accidentally changed language
Go to setting(the gears). Then go down to the 4 line. Finally just go to the second line and you're done.
Posted on Jul 06, 2008
0 characters
3 Points
How do I change language on Apple MP4 16gb multimedia player
1. Open Google Translate:
2. Type "Settings" in the left text box on the Google Translate page.
3. On the right side next to the languages, click the little triangle that points down and choose "Chinese" to see the letters/symbols that match the lettering for the "Settings" on your device. Choose that option on your device.
4. Go back to Google Translate and type "Language" to see the letters/symbols that match the lettering for the "Language" on your device. Choose that option on your device.
5. Once you are in the language settings, you should be able to choose "English".
Oct 26, 2015 | Apple MP3 & Digital Media Players
How do i change my language from chinese to english on my chinese mp4 player
Welcome to Fixya. Can you provide the make and the model of the mp3 player so that we can check if it is possible to change the language.
May 26, 2011 | MP3 & Digital Media Players
I purchased a mp4 media player in hong kong. Please can you tell me how to change the language from chinese to english
This forum has listed the Chinese names for the menu options you are looking for (I could not directly paste the Chinese characters here). Clicking on them should allow you to change the player's language.
Mar 05, 2011 | MP3 & Digital Media Players
How do I change the language settings on my sansa fuze + mp3 player? When I first started it up, I accidentally hit the chinese button and need to change it to english instead.
Press the menu button. Scroll to the Settings (four vertical slider controls) and press the OK button (the middle of the round "joystick" control). Select System Settings (the last item on this menu) and press the OK button. Select the sixth item on this menu and press OK. Select "English" and press OK.
Dec 24, 2010 | MP3 & Digital Media Players
Ipod in chinese dont know how to switch back to english.
If you accidentally set iPod nano to use a language you don’t understand
You can reset the language.
1 Press and hold Menu until the main menu appears.
2 Choose the sixth menu item (Settings).
3 Choose the last menu item (Reset Settings).
4 Choose the first item (Reset) and select a language.
Other iPod nano settings, such as song repeat, are also reset.
Note: If you added or removed items from the iPod nano main menu (see “Adding or
Removing Items on the Main Menu” on page 11) the Settings menu item may be in a
different place. If you can’t find the Reset Settings menu item, you can restore
iPod nano to its original state and choose a language. See “Updating and Restoring
iPod Software” on page 69.
Good Luck and Please Rate FixYa!
Jan 18, 2009 | Apple iPod nano
You can go one of three ways. From the music/headphones icon, press down 3x (to get to settings); right 1x (to enter settings); down to the fourth option/line (observe the scroll bar to make sure you count from the very top) right 1x (to enter the languages menu). You will find your own language in plain text. It should work unless your setup is different or I miscounted somewhere. If that doesn't work, try updating the firmware. By doing that, it will ask you which language you would like to use on your Clip. If either of those do not work, plug your Clip into the computer. Then go to my computer under the start menu, find your mp3 player under the list (should be under 'devices with removable storage', or something to that effect). Right click on the mp3 player icon, and click "format". Go with the format it suggests, then reinstall the firmware from there. It will be like starting from square one.
Nov 15, 2008 | SanDisk Sansa Clip MP3 Player
Change the settings
i got one off ebay just a few fays ago and the language was stuck in chinese, so after just testing the MP34 i found out how to change the langauge into English.
Click into the 'two rotating items',
Then, go down to the 4th settings, i.e 04/11. This is Languages.
After entering that, click into the 2nd option. i.e 02/25. This is English settings.
And hopefully it should be done.
Mar 30, 2008 | Apple iPod nano 3rd Generation
Changing the Language
i need to know which language are you seeing
Mar 02, 2008 | SanDisk Sansa Clip MP3 Player
Everything in Japanese characters!
I had the same problem when I first got the player and selected another language. I looked at the booklet and figured when first turning it on, hit the down arrow 3 times, then select, then hit the down arrow 4 times then select is how I got to English setting.
May 22, 2007 | SanDisk Sansa e130 MP3 Player
Premier MP4 Digital Media Player Logo
236 people viewed this question
Top Premier MP3 & Digital Media Players Experts
Are you a Premier MP3 and Digital Media Player Expert? Answer questions, earn points and help others
