Question about LG LX5550 Cellular Phone
How do I reset the phone to default settings?
Need to reset this telephone to default settings.
    Sergeant:
    Champion:
  • 240 Answers
In your menu, most likely under "settings" is master reset. This will remove all contacts as well though if that is what you want? If you do use this you will need the code which is in your manual.
Posted on Jun 15, 2009
Unlock code or hard reset for a samsung SPH-M270.
From the Main screen, press the
MENU/OK Key
TOOLS + SETTINGS
Settings
Reset/Delete
2.
Enter the Lock Code at the prompt. The
default lock code is the last four digits of
the telephone number assigned to your
phone. The first time you access this
setting, you'll be prompted to change the
Lock Code.
3.
Use the
Navigation Key
to highlight
Reset Phone
, then press the
MENU/OK
Key
4.
At the prompt, confirm the reset by
pressing
RESET
Aug 18, 2017 | Samsung Cell Phones
Unlock Panasonic KX-TSC35SUW Digital Telephone System
Not sure if this would help, but won't hurt to try..
1.
Connect to the Web UI
a.
Connect the Phone and a PC to the network
b.
Check the IP address of the phone using a handset.
[Menu]->[IP Service]->[Network
Setting]->[IP Settings]
c.
Enable the phone's Web UI using a handset
[Menu]->[IP Service]->[Network Setti
ng]->[Embedded Web]->[On]->[Save]
d.
Enter the IP address in a PC's Web Browser.
example: Enter "http://192.168.1.68"
in the address bar of Internet
Explorer
e.
Enter Authentication ID and password
Password:cspass
f.
Now you can upload new Firmware
into the phone using Web browser.
Note: The phone's http server port will automatically close after idle time of 30
minutes.
2.
Factory Reset
a.
Move to Maintenance - Re
set to Defaults screen.
b.
Click [ Reset to Factory Defaults ]
c.
Please wait.
The Base unit will reboot automatically
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
Apr 23, 2014 | Panasonic KX-T7636BK Digital Telephone...
BT Aura 1500 Quad telephone - calls list freezing
BT gave me solution, which (so far) seems to work:
Reset the software of the telephone to default settings...
On any handset - 1. Press 'menu' 2. Scroll to 'settings' & press 'ok' 3. Scroll to 'base' & press 'ok' 4. Scroll to 'reset base' & press 'ok' 5. 'System PIN' will be displayed - enter '0000' (unless you have altered the default pin number) 6. Press 'ok' 7. Press 'yes' 8. Switch the main base station off at the power & remove the batteries from all handsets for approximately 30 minutes .
This didn't reset my address book (thank goodness) but did reset some other settings, such as time/date, OGM, group ringtones etc.
Jan 15, 2013 | Lands Phones
Factory Reset for ATL IP200 Telephone
To Factory Reset an ATL IP200-
1) Unplug the power and wait for 10 seconds
2) Hold * Key on the phone
3) While holding the * key, plug the power back in - You will see a * and two bars
4) Press #5*5 to reset and reboot it.
Default Password is - 12345678
Unfortunately, it's after this point that I get stuck as it tells me to press the Local IP button, then put that into a network-linked computer's internet as a URL (to go into the settings) and then the IP doesn't work!
Jan 13, 2012 | ATL Telecom IP300 IP Phone
Foemat code
*#7370# - Soft Reset/Format - erases all telephone memory.
-or-
*#7780# - Default factory settings (Hard Reset) .
Oct 06, 2011 | Nokia 1208 Cellular Phone
I forgot my four digit code to unlock my samsung sch u820
Steps to Restore Phone
This will return phone to the default settings and permanently erase all user data, including pictures,videos, music, messages, contacts and downloaded applications stored on the phone.
  1. From a Home screen, touch Menu ? Settings & Tools ? Phone Settings ? Security. Enter the lock code when prompted. The default lock code is the last four digits of your telephone number.
  2. Touch 5 or Restore Phone.
  3. At the prompt, touch Yes to reset and restore default settings, or No to return to the Security menu.
http://www.resetcellphone.com/how_to_reset_Samsung_sch-u820-reality
May 04, 2011 | Cell Phones
When i dial a number the phone cuts off and restarts
Please try resetting the phone to default settings and it should work. The default code should be the last 4 digits of your phone number unless you have changed it.
Restoring Phone Memory to Factory Conditions
This returns all settings to their factory default value and erases all user data including pictures, video, music, messages, contacts and downloaded applications stored on the phone.
  1. From the home screen tap MENU.
  2. Tap Settings & Tools.
  3. Scroll th screen up and tap 7.Phone Settings.
  4. Tap 5.Security, You're prompted to enter the lock code.The default lock code is the last four digits of your telephone number.
  5. Enter the Lock Code and tap DONE. The security menu appears in the display.
  6. Tap 5.Restore Phone. A prompt appears in the display asking if you wish to restore default settings and erase all user data including pictures, videos, music,messages, contacts, and downloaded applications stored on the phone.
  7. Tap Yes to reset and restore default settings or tap No to return to the Security list.
Mar 15, 2011 | Samsung Glyde SCH-u940 Cellular Phone
Load default Delta file message
Problem My handset displays either LOAD DELTA FILE or LOAD DEFAULT DELTA FILE. What should I do?
Solution(s) Tip 1 of 2
If the handset is not responding normally, you may need to reset your telephone system. Complete the following steps to reset the telephone system:
Step 1: Disconnect the power to the telephone base.
Step 2: Disconnect the handset battery.
Step 3: Wait a few minutes and then reconnect the power to the telephone base.
Step 4: Reconnect the handset battery
Step 5: Wait about one minute for the handset to re-establish a link with the telephone base and then test the phone again.
Nov 16, 2009 | AT&T 650530003417 Cordless Phone
I don't know the voicemail password; I am trying to reset it to the default
you will need to log in from a main phone or phone with LCD screen and go to the set you need to set to default in the menu...this maybe only be done through your vendor unless you know the system password to get into the configuration mode.
May 29, 2009 | Comdial Impact 8024S Corded Phone
I hav my n70 problem my phone is hanging when i got to txt, my download music & pic are lost so wat are we going to do.... thanks irma
Consider either doing master reset or reinstalling the phone software
Key codes
*#7780# - default factory settings
*#7370# - soft format — erases all telephone memory.
[Green] * 3 - hard format — if only the telephone memory is formatted, puts back the attitudes and reboots
Feb 21, 2009 | Nokia N70 Cellular Phone
LG LX5550 Cellular Phone Logo
56 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
